Page 4 of 4 FirstFirst ... 234
Results 121 to 151 of 151
  1. #121
    Senior Member Two Rings hawaiian punch's Avatar
    Oct 16 2016
    2013 Z71 Hoe
    New York
  2. #122
    Sep 25 2012
    Plainfield CT
    The Avant is looking good and that thing is quick!! How's it running? Were you on E85 at the track?
  3. #123
    Veteran Member Four Rings jamerican1's Avatar
    Nov 15 2009
    2008 A4 S-Line Titanium TQM, 2000 A4 1.8tqm, 1993 Audi 90S(sold)
    VA
    Looking great man! How did you source the euro rear bumper? I need one bad lol
    Unf*ckwithable
  4. #124
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by SilverSline View Post
    Yeah I’m tuned for E50 that’s all I run, it’s great it honestly never gives me problems I don’t drive it as much as I use to but when I do I drive it pretty hard haha
  5. #125
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by jamerican1 View Post
    Thanks man!
    I picked it up from a guy on here Banderoz
  6. #126
    Sep 25 2012
    Plainfield CT
    Quote Originally Posted by hawaiian punch View Post
    Nice! It sounds pretty good too. What injectors and fuel pump did you go with to run that mix?
  7. #127
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Haha thanks, It’s got a walbro 450 and ID 1050xs
  8. #128
    Veteran Member Four Rings Stock B6's Avatar
    May 25 2018
    Noggy B5 S4
    Twin Cities
    How's the 2.8 trans? Given that the 2.8 trans is still 01A, I'm not sure if it's much stronger than the 1.8 01A. How are the longer gear ratios?
    I've blown a 1.8 01A before and don't know how long the second one will hold up lol. Love the build progress btw keep it up
    Racecar: Nogaro B5 S4
    Daily: C5 Allroad 2.7TQM
    Past: 71R E85 B6
  9. #129
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    Its not stronger, only different gear ratios and FD ratio. 01A's are piss cheap , they are a service part with high power :) The strongest trans you can put in a B5 is a diesel 01E.
  10. #130
    Oct 16 2016
    2013 Z71 Hoe
    New York
    The Hawaiian Punch build
    Thanks man I appreciate it!
    I love my v6 trans the gears feel way longer and more appropriately matched for how my car is setup. I catch myself cruising in 4th a lot on the highway by accident lol
  11. #131
    May 25 2018
    Noggy B5 S4
    Twin Cities
    Would you say the longer gears are better for racing/pulls though?
    Past: 71R E85 B6
  12. #132
    Mar 15 2018
    Europe
    Quote Originally Posted by Stock B6 View Post
    You gain more top speed vs RPM, try a diesel box, 6th gear will be like 200 mph :))
  13. #133
    Oct 16 2016
    2013 Z71 Hoe
    New York
    I only had to shift twice in a quarter mile pass and three times with a 1.8 01a. I did run a faster time at the track but it was probably a mix of things
  14. #134
    May 25 2018
    Noggy B5 S4
    Twin Cities
    What the hell does third top out at then? 120? On a side note, I found a 2.8 B5 at junkyard today, manual . Wanted to pull the trans but have no idea how to tell if it's good or not.
    Past: 71R E85 B6
  15. #135
    Oct 16 2016
    2013 Z71 Hoe
    New York
    We’ll I trapped like 108something and I was shifting right after the line. I found this post from a while back I took pics of that has the full difference in mph and rpm between the both.
    Sorry for the screenshot but That’s in order from 1st-5th, I rev a little higher then stock
  16. #136
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Took the car out for the first time in a while to go drag racing this past weekend and burnt out an exhaust valve on my first and only run( I did win though!) I felt something at the top of 4th right before I shifted to 5th I thought I blew off a hose or cap maybe it was misfiring really bad. Scanned it and kept listening to it and came to the conclusion it was a valve so it was taken apart
    and sent off to the machine shop with a set of ferrera exhaust valves that I had chillen thankfully. Probably the best worst case scenario that could have happened.
    If all goes well I should be back out there next weekend!
  17. #137
    Veteran Member Three Rings Darepoole's Avatar
    Sep 29 2015
    B5 A4 2.0 Stroker, 2016 Touareg, 1984 Pontiac Fiero,
    Saratoga Springs, NY
    That’s unfortunate but I hope all goes well at the machine shop!
    B5 A4 2.0 Stroker (In Progress)
  18. #138
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    Sorry to hear!
    Wonder why that happened. Tune off? Lean?
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
  19. #139
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Yeah I’m assuming it ran lean I wish I recorded it or even looked at my gauges I was to focused on the race though lol. I’ve had the same set up for about 2 years now its seen tons and tons of pulls, high rpm shifts, hitting the rev limiter it’s always been fine. I don’t know what kind of valves were in it so we shall see soon hopefully it’s back together for this Sunday’s event!
  20. #140
    May 25 2018
    Noggy B5 S4
    Twin Cities
    Gotcha, yeah with revving out past 7200 that makes sense.
    Yikes, sorry to hear about the valve. Any news since? One of my favorite 1.8 builds haha love seeing updates to the thread!
    Past: 71R E85 B6
  21. #141
    Oct 16 2016
    2013 Z71 Hoe
    New York
    I had the head rebuilt with ferrera valves Ive had sitting threw in another stock cam and raced it the next weekend and blew the clutch lol I have since put in a ringer racing stage 5 clutch and got about 250 miles on it. I recently purchased a 2013 Tahoe z71 I’ve been putting my time and money in to that. The wagon is super fun but the hoe is way more comfortable and easy for the NYC traffic. The wagons ac isn’t that great either lol
  22. #142
    May 25 2018
    Noggy B5 S4
    Twin Cities
    Yeah I feel that. Every B5-B7 that I’ve been in has mediocre A/C at best lol.
    Past: 71R E85 B6
  23. #143
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Haha yeah plus the roads are trash I drive like 75 miles a day I feel bad beating up my v3’s lol I will sign up for some racing events soon. You can check out NYAudiSource on Instagram for all the work and racing from this car and a few of my friends rides as well! Stuff gets posted on there way more often
  24. #144
    Oct 16 2016
    2013 Z71 Hoe
    New York
    The new addition to my crew lol 2001 volcano black avant with a full Terra cotta interior and an extra almost full set lol
  25. #145
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Terra Cotta and black look good!
    1998.5 A4 1.8TQM My Build
  26. #146
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by xdewaynex View Post
    Thanks dude I love it I stole this thing too the guy gave me soooo many extra parts and the car came with a ton of goodies on it already!
  27. #147
    Oct 14 2006
    by the lakeshore, mi
    Love both of your avants. I dig the new avant color combo!
    Current: 01 A4QM avant daily driver.
    Past: 92 ABZ 100CSQM avant, 97 A6Q avant, 93 S4, 95.5 avant, 93 S4, 91 10vt CQ, 98.5 SC'd & IC'd A4QM sedan.
  28. #148
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by speedydtp[emoji638
    [emoji[emoji6]];[emoji6][emoji6][emoji6][emoji[emoji6]]]Love both of your avants. I dig the new avant color combo!
    Thanks dude! I see you got a sick collection yourself I’m jealous! Haha
    Sent from my iPhone using ]][emoji[emoji6]][emoji6][emoji[emoji6]][emoji6]]Audizine
  29. #149
    Oct 14 2006
    Welcome.
    I used to have a nice collection. Speaking of my past rides. I sold my UrS6 avant (without a engine) to a buddy of mine and he swapped in a stock engine and did a complete black interior swap. It's actually his son's ride now.
  30. #150
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by speedydtp247 View Post
    Welcome.
    I’ve been feeling it lately personally rough spot at work in the middle of building one avant and fixing the other as a daily plus a little payment for Tahoe then insurance plus the other bills (and living in nyc lol) I’ve been feeling it.
    I’m glad to hear it went to good hands
  31. #151
    Oct 14 2006
    Hang in there.
