Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 151
  1. #41
    Senior Member Two Rings hawaiian punch's Avatar
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by A1 A2 German View Post
    If you reroute the intake: A 90 downwards off the turbo inlet, a short straight (~5"), to a 45 degree flipped upside down to one more short straight, add the cone to that. This will place the intake cone under the passenger headlight angled 45 degrees downward, on the forward side of the rad support, exposed to fresh air, 100% out of the bay. Basically sits above the cold side fmic piping (for those with a fmic)
    1) You will need to make either a ~3.25" square or round cut through the radiator support so the 3" short straight pipe can poke through. You do not need to remove the rad support.
    2) You can run a full size filter, yet a short version like this:
    https://images.app.goo.gl/jibSHTzbDLwcY7wN9
    In your case you may point need to point the 90 off the turbo towards the headlight area as you're turbo inlet sits next to your valve cover. My turbo sits directly behind the headlight so I point straight down.
    Yeah that’s a good idea thanks! I was contemplating deleting the AC freeing up some space and little weight. Having AC in the summer is really nice though, but I don’t really daily it much anymore so it wouldn’t be the end of the world.
  2. #42
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    For thought, you don't gain anything but lose alot deleting AC. The AC system will not be in the way of the ic pipes or mentioned intake.
    EDIT: You're not going to be noticeably faster or now beat cars you couldn't otherwise.
  3. #43
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Haha yeah I knew it wasn’t going to make me any “faster” but it sounds like more trouble then it’s worth. For that intake setup would I add the maf in as the short straight in between the 90 off the turbo and the 45 ?
  4. #44
    Feb 28 2005
    Tempe
    If running a DV you buy a T straight with a ~1" nipple and place it were you see mine:
    https://images.app.goo.gl/Sek5yGTT6uRq6AYb7
    If not running a DV place the maf in that location as will get a chance for the air to even out. When air goes through a cone filter the inside flow is turbulent/non linar...further away from the cone by the time it hits the maf gives it a chance to even out. However, I haven't seen issues yet other set up people have, having the cone off the maf.
    Or, if you want to be trick and run a dv, buy the Tee straight and weld a maf flange ($10) in front of the barb: https://images.app.goo.gl/22tKCrhCuvywLT9f8
    You'll still need a small straight down towards the bottom, but will be blank if you weld a maf flange to the T-pipe (maf MUST sit into of dv).
  5. #45
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    Basically you want the MAF as far from the filter as possible , DV far from the MAF as possible , but the MAF as far away from the turbo wheel as possible too, balance them out. Good thing with Bosch MAF's is that they can measure reverse flow so if one of them is not perfect it will work but dont place them too close together.
  6. #46
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Cool thanks, easy enough it’s starting to get warmer out by me one of these weekends I’ll have to tinker around with it.
  7. #47
    Jul 05 2016
    Bloomfield NY
    If you're interested I have a couple 01es that need the 1/2 shift collar rebuild for sale!
    Sent from my SM-G960U using Audizine mobile app
  8. #48
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    Just stopping in to say great build so far! I used to have a Laser 1.8TQM Avant myself. Miss it!
    // 2001.5 Pearl White B5 S4 Sedan 6MT
  9. #49
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by zatch_303 View Post
    Thanks man I appreciate it! Should have never got rid of it haha, Stay tuned it’s never done!
  10. #50
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by Fattyalx View Post
    Thanks man I’ll keep it in mind but I think I’m going to run with the 01a for now I got a few stashed away that should last me for a while
  11. #51
    Mar 15 2018
    Europe
    If you are interested I can get you some diesel top gears for both 01e or 01a too.
  12. #52
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by Blazius View Post
    Cool I sent you a pm!
  13. #53
    Veteran Member Three Rings A4TQS's Avatar
    Feb 17 2013
    B7 2.0T Quattro Sline
    Europe
    Looking good.
    EU Sline seats | H&R 20mm rear spacers |Shell V-Power NITRO+| Castrol Edge| Interior leds | VAG Mods | R8 oil cap | RS4 Pedal set | K&N Air filter | Rear lip spoiler | R8 red coil pack | ECS boost gauge | Continental Premium Contact 6 | LED City Lights | 034 Turbo Inlet Hose | Nokian WR A3 | License plate leds |
  14. #54
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by A4TQS View Post
    Looking good.
    Thanks man! I appreciate it
  15. #55
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Started getting an exhaust leak the other day decided to mess around with it yesterday and found this...
    I ordered some new flanges, going to drop them off at the boost source once they are in. I’m thinking about dumping it out the fender lol
  16. #56
    Oct 16 2016
    2013 Z71 Hoe
    New York
    I also received my new steering wheel from Reggie’s customs wheels earlier this week, I’ll probably stick it on over the weekend.
  17. #57
    Established Member Two Rings rzyao's Avatar
    Jan 05 2020
    Massachusetts
    Quote Originally Posted by hawaiian punch View Post
    yeesh, that's a pretty nasty crack. what did it sound like?
  18. #58
    Oct 16 2016
    2013 Z71 Hoe
    New York
    It was really just a low rpm exhaust leak like a ticking noise, once the gate opened up you couldn’t hear anything else lol it was getting worse and worse throughout a few days of daily driving though
  19. #59
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Been pretty busy lately especially with all this non sense going on but I did get my wastegate all fixed and finally got around to throwing the new wheel on. Looks nice has a weird feel wasn’t use to it at first but I like it.
  20. #60
    Veteran Member Four Rings reece_2212's Avatar
    Apr 22 2016
    Alberta, Canada
    Wow that steering wheel is awesome! Looks just like the new flat bottom wheels and those feel great in the hand.
    '96 A4 2.8QM - (RIP Avocado) <3
    '01 A4 1.8tQM - GT2860RS Elim, 550cc, APR Carbonio, Clutchmax Stage 2 w/ SMFW, APR FMIC, IE Rods - Bilstein B8, Tein S Tech, 034 Trans Mounts, ECS Poly Snub, Stern Engine Mounts - B7 A4 Front Brakes, C5 S6 Rear Brakes, Stoptech Stainless Lines - eBay SS, 3D Printed Shifter Cage, JHM Linkage Bushings -
  21. #61
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by reece_2212 View Post
    Yeah it’s made thicker like a newer “R8” wheel I never felt one to tell honestly lol thanks though I appreciate it!
  22. #62
    Junior Member One Ring slhopf's Avatar
    Mar 04 2020
    Southern Indiana, US
    It's a fine looking car! I have a laser red '99.0 sedan, nearly stock with a 2.8 30v. I'll definitely take some inspiration from your cosmetic changes!
    Emotionally exhausted
    Morally bankrupt
    Laser red '99.0 A4 2.8
  23. #63
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by slhopf View Post
    Thanks man it’s never done though lol should have the headliner and few other bits reupholstered soon some new trim. I want some wheels too tints haha
  24. #64
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Went out cruising with a bunch of friends last night have to sort through my videos but here is a little run with me vs a new TTRS from like a 40/50 roll
    https://youtu.be/XPM3eTbPDDI
  25. #65
    Oct 16 2016
    2013 Z71 Hoe
    New York
    The Hawaiian Punch build
    I’ve got a friends set of rotiforms on at the moment, I’m considering buying them but just test fitting them for now haha I’m waiting on some parts that should be done soon
  26. #66
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Wheels would look better if they werent black.
    1998.5 A4 1.8TQM My Build
  27. #67
    Established Member Two Rings avantkrazy's Avatar
    Jul 17 2018
    Catskill's New York
    I thought of you when I saw this...not sure if he still has but color matched s4 side skirts....https://newyork.craigslist.org/que/p...120535092.htmlScreenshot_20200512-004004_Classified%20Listings%20Mobile%20-%20for%20Classified%20ads.jpeg
    I got 99 problems and my B5 is 98 of them...
  28. #68
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by xdewaynex View Post
    Yeah I’m not the biggest fan either haha
  29. #69
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by avantkrazy View Post
    Oh sweet thanks man! I actually have the skirts missing the other pieces to them though and door sills, I’m definitely gonna hit this guy up though thanks
  30. #70
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Yeah I’m not the biggest fan either haha I’ve been thinking of getting some ultraleggeras or maybe some rpf1’s
  31. #71
    Oct 16 2016
    2013 Z71 Hoe
    New York
    So I finally had some free time last weekend to get some stuff done to the wagon
    I got a new 60psi aem boost gauge installed all of my gauges in the center vent on an aluminum plate and used some caliper paint to try and match the rest of the interior lol
    Used some wrinkle red on the valve cover it I happy with the way it turned out, also got a few black caps for under the hood from ecs. Should have my new manifold soon, I was a little pissed when I saw IE released a few more Intake manifolds and but whateverrr
  32. #72
    Oct 16 2016
    2013 Z71 Hoe
    New York
    I’ve been pretty busy lately but I managed to scoop up some carbon fiber trim and finally got my s4 skirts on. I also got some tints, I’m still waiting on my manifold but she’s coming along
  33. #73
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Looking good!
  34. #74
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Looking good!
    Thanks dude!
  35. #75
    Oct 16 2016
    2013 Z71 Hoe
    New York
    https://youtu.be/MlJkZ9TApqs
    Bought a dragy, figured I’d test it out haha
    Still waiting on my intake manifold to be done :/ hopefully soon. Not much else has been going on I keep blowing out t3 and Wastegate gaskets but that’s about it
  36. #76
    May 07 2017
    bristol
    Happen to have any pics of the downpipe not installed?
    Sent from my SM-G986U using Audizine Forum mobile app
  37. #77
    Dec 14 2015
    02 v8 Dakota, 12 Fusion sport(wife) and the b5
    Mid Atlantic
    ahh why'd you let off lol..and maybe you should get the flanges decked and not run gaskets ??
  38. #78
    Dec 05 2007
    Audizine
    https://smile.amazon.com/Nissan-1441...d-0c3639671b2d
    https://www.ebay.com/itm/High-Temper...4/252614266635
    Thank me later. I spent a fair amount of money on gaskets and different setups (ie Trackspeed Inconel kit with Stage 8 turbo nut kit, Stage 8 turbo bolt kit, Cometic gaskets, etc). After years of trying different configurations, this route works trouble free. Nissan OEM T3 gasket, the thread lock in the link, and better hardware if you choose (I run ARP Stainless Steel M10x1.5 10-point head bolts). I don't even have to check my setup periodically. Went for a drive few months back on the backroads hard with a few other's (read: hard). I fractured a weld on a section of one of the runners on my turbular manifold. But the T3 flange and everything associated...still intact.
  39. #79
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by NicksAEB View Post
    I might be able to find one from the guy that made it but I don’t sorry
  40. #80
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by AudiSon14 View Post
    The road has a turn that comes up I didn’t want to be doing 100 going around it haha
    Its not really my daily anymore so I’m gonna start having a little more fun with it
    The plan is to get a new tubular manifold and vband everything sooner then later, so I’m not to worried about it.
