Results 1 to 6 of 6
    Established Member Two Rings Roccorace's Avatar
    Nov 22 2015
    Minnesota
    12 volt solutions Remote Starter Install
    For passers by, there is actually a no key no cut solution for remote start for our cars... however:
    I am wondering is anyone has installed one of the 12volt.solutions remote starters on their 7 series (mine is a c7.5 RS7). It came with no instructions and there are no videos online for the 7. I am not sure what the connection location is but it is stated to be in the trunk and the solution is a piggy-back style wiring system.
    Hoping someone has done one of these.
    2017 Audi RS7 | Daytona Grey Matte
    - Milltek Non-resonated Exhaust
    - Full LED Color-change Interior Lighting upgrade
    - ECS Flush Spacer Kit
    - OBDEleven modified | Lowered 10mm | VIM | Seatbelt Chime | Heater timers
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Quote Originally Posted by Roccorace View Post
    THIS is the remote start many of us have done, you don't lose a key. Runs about $300 total for self-install.
    Nov 22 2015
    Minnesota
    I have the programming directions but not the wiring install directions. That is low res, what page is the diagram on (169 total pages)
    Sent from my iPhone using Tapatalk Pro
    Aug 14 2019
    Tampa
    The wiring hardness I assume you mean? It all plugs into the BCM which is in the right rear of trunk. There are some pictures of all this in thread I linked. Post #22 in that thread is the wiring harness diagram. Post #68 is an actual photo of my BCM where the harness plugs into.
    Apr 25 2022
    Tampa, FL
    Does this system void any warranty?
    Mar 23 2019
    New York
    Quote Originally Posted by atandon83 View Post
    not if you dont break anything. had a place install my system in my S6. i installed the 12 volt in the wifes SQ5. both with the remote app. same app works for both. key loss for the SQ, but not for the S6
    2018 S6 Premium+
    2021 SQ5 Prestige
    2006 S4 Cab (gone)
