Results 1 to 9 of 9
    Veteran Member Four Rings jsantiago17's Avatar
    Aug 07 2008
    2004 A4 Quattro3.0L UltraSport
    Westchester, NY
    Error Code P0299 Turbo/Supercharger Underboost
    Hey guys,
    I'm an old B6 owner, but asking for a friend who has a B8. She just threw the following code: P0299 Turbo/Supercharger Underboost. She took it to the dealership and they are recommending replacing the Turbocharger Recirculation Valve and are quoting her $3,000 to do so. I've already recommended a couple of shops, but what is a fair quote for this job?
    Appreciate any help in advance.
    Jorge
    |Milltek Exhaust|Unitronic Flashed|JHM Short Shifter|Koni Sports|Eibach Pros|RS4 Rear Sway|Euro RS4 Steering Wheel|RS4 Race Pedals|Miro 111's|S4 Mirrors|
    |B6 S4 Calipers|JHM 2 Piece Lightweight Rotors|Akebono Euro Ceramic Brake Pads|Evoms CAI|Hoen Xenon Match Foglights
    http://www.youtube.com/watch?v=xccmzudcY8o
    http://www.youtube.com/watch?v=BZOJIV1y0EQ
    Veteran Member Three Rings Stazi's Avatar
    Aug 27 2019
    2012 Audi A4 S-Line, 2019 Jeep Grand Cherokee Altitude 4x4, 2017 Moomba Craz
    Michigan
    That’s absolutely ridiculous. $3000 for a recirculating valve? Fuck me....they saw her coming a mile away. You shouldn’t even have to ask that question.
    In any case if it’s an B8 it probably has a leaking wastegate.
    Look up how to fix this in the A4 B8 underboost code topic. I made a post on how to do this in about 15mins with either a large screw driver or a small pry bar.
    2012 Audi A4 2.0T S-Line
    K04 // IE Stage 3 K04 tune // USP HFC // Becker Cat-back // ECS Intake Pipe (w/modded airbox + K&N) // ECS Luft-technik FMIC Intercooler and pipe kit // GFB VTA // RS mesh grille // CF M4 style spoiler // ST rear sway bar.
    Aug 07 2008
    Westchester, NY
    Quote Originally Posted by Stazi View Post
    Yeah.... that's exactly what i said! I appreciate your insight and suggestions.
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    They probably quoted $3000 for a turbocharger
    Aug 07 2008
    Westchester, NY
    Quote Originally Posted by a4lownslow View Post
    Exactly what I'm thinking they did. Did some research after posting this and doesn't seem uncommon the stealership recommends this when this code is thrown.
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    How many miles on the car? Audi extended the warranty to 70k for this exact reason. Otherwise I would nudge the wastegate actuator bracket as was suggested, only need to move about 1/8-1/4”.
    Aug 07 2008
    Westchester, NY
    Quote Originally Posted by JLAllroad View Post
    Thanks for the suggestion.... I'll pass it along. The car has 80K miles, so out of warranty
    Jul 21 2019
    Christchurch
    You would want to replace it, and you should do it yourself. Look up videos on YouTube. And the price is gonna be the cost of a brand new diverter valve.
    Aug 27 2019
    Michigan
    Quote Originally Posted by xlee11 View Post
    It’s not the diverter valve......at all.
