Results 1 to 6 of 6
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    How to peep inside Intake with boroscope?
    Hello guys, is there a way to take a peep into intake valves without actually removing intake?
    Veteran Member Three Rings IbisB7stage2's Avatar
    Mar 20 2013
    Bay Area
    you could undo the intake pipe from the intercooler, take off the throttle body, then you've got a clear path
    ~John
    B7 A4 quattro 6spd, k04 w/ meth, PSS9 coils, S4 recaros, basically everything else
    C5 S6 Avant 6spd
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Throttle body or the intake air sensor might give you a clear path.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    May 15 2019
    Bellevue, WA
    Thanks guys
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    if you have a flexible boroscope, i would think the PCV inlet connecting to the back of the intake would allow you to get in there.
    Rest assured, you're going to see a bunch of carbon.
    Senior Member Three Rings lumberwood's Avatar
    Apr 06 2016
    Hamilton, ON
    Easy to get at the middle two cylinders with a flex boroscope through the intake air temp sensor hole. A bit trickier to reach the ports of the outer two cylinders without scraping crap off the inside of the manifold and thus blocking the camera lens.
