Originally Posted by
choppstixxx
IMO wouldn't you just connect/bridge the red wire off of the yellow video connector coming from trunk handle camera to the red wire coming off the silver module. Then connect the red and black wire coming out towards the rear of the car to the fuse box in the trunk and a bare bolt for the ground? I'm surprised that it wasn't more plug and play using the silver module since it taps into the factory system.
I agree, when I purchased it I thought it would be much easier to install. So you're suggesting to connect that red wire in the front to the red wire that has the "ACC OUT" tag on it and then connect the red wire coming off the trunk handle to a fuse in the fusebox in the rear that's got auxiliary power and then of course ground is just a random bolt. is that correct?
