Results 1 to 8 of 8
    Junior Member Two Rings
    Jul 21 2008
    Minneapols, mn
    Driving without cluster issues?
    I have a failed instrument cluster that I am thinking of sending to Speedosolutions to be repaired. The person I talked to who was super knowledgeable said the car can be driven with out it which since the car can't communicate with the cluster.
    Does anyone see any issues? Just trying to decide if I need a rental car for the few days it is down.
    Thanks.
    JZ
    May 22 2016
    2006 electric blue evo 9, 2jz e46, rwd b5 a4, b7 a4 sline titanium airlift 3p
    Roseville
    My concern would be inaccurate mileage. So i wouldnt attempt it.
    Sent from my SM-N950U using Tapatalk
    Jul 21 2008
    Minneapols, mn
    Well now the speedo and rev's are acting up so it is basically like driving without a cluster... ha. My understanding is it just an output device in this generation.
    Thinking this will go to Tom tomorrow for diagnosis whom seems super knowledgable and helpful.
    JZ
    Established Member Two Rings PenttisHSR's Avatar
    Dec 22 2016
    England
    Interesting to find out, as previous models had the immobilizer in there.
    I just assumed that the car would not start with instrument cluster removed, love to have a definitive answer.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by PenttisHSR View Post
    Car will start and run ok without cluster, immobilizer not related with cluster on b8(2008-16).
    btw nice avatar
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jul 21 2008
    Minneapols, mn
    So cluster is out and packed up. Car drives fine without the cluster. Going to only drive it if necessary still.
    Kind of weird Audi locks you out of Being able to adapt millage on a used cluster and puts component protection on them but you can drive without it. Ohh well.
    Sending to Tom from speedo solutions and hoping to he can work some magic. Seems like a knowledgeable guy and can do a lot of stuff Audi won’t do.
    JZ
    Jul 21 2008
    Minneapols, mn
    Just thought I would post an update. Tom from Speedosolutions did a great job getting my cluster back up and running for a reasonable cost. Plugged it back in, cleared codes and all is good now. Nice to not have a black hole in the middle of my dash.
    JZ
    Established Member Two Rings B4Audi's Avatar
    Feb 23 2020
    Delaware
    When you plugged you cluster back in did the mileage update or was it the same mileage when you pulled the cluster out?
    Sent from my SM-G973U using Tapatalk
