The car in questions is a 2008 A4 manual trans w/146k miles. Cam follower replaced at 120k (haven't rechecked yet) and car isn't tuned. The previous cam follower had 40k on it and the black coating had been worn off but no other scoring. Plugs replaced around 120k miles and coil packs previously at about 80k miles (red top R8). I did some logging and I don't think i'm getting the correct data for the fuel pressure regulator (G 103).
What led me to this was the car has stalled a few times while taking off from a stop, and while driving there's a loss of power for a second or two then goes back to normal. When this happens the engine bogs down then when it returns to normal there's an obvious kick, like bump starting jerk. At this point i'm guessing loss of power is when it's misfiring and the jerk is when the engine stops misfiring.
Here are my engine fault codes. No CEL on or flashing at any time.
Address 01: Engine Labels: 06F-907-115-AXX.clb
Control Module Part Number: 8E1 910 115 G HW: 8E0 907 115 D
Component and/or Version: 2.0l R4/4V TFSI 0010
Software Coding: 0104010A180F0120
Work Shop Code: WSC 06335 000 00000
VCID: 2643CF61915D5A7A87-8072
2 Faults Found:
001152 - Coolant Fan Control Circuit 1
P0480 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 10
Reset counter: 255
Mileage: 232226 km
Time Indication: 0
Freeze Frame:
RPM: 2816 /min
Load: 50.6 %
Speed: 104.0 km/h
Temperature: 93.0°C
Temperature: 33.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.589 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 232606 km
Time Indication: 0
Freeze Frame:
RPM: 1883 /min
Load: 9.4 %
Speed: 85.0 km/h
Temperature: 93.0°C
Temperature: 32.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.081 V
Readiness: 0000 0000
Here's one, RPMs report 0 for one instance then there's misfires on multiple cylinders. At this time I was cruising down the freeway on throttle to maintain speed.
Here's anther one, same RPMs report 0 for one instance, missfires on #1 cylinder (this reported for 25 seconds). Same, cruising on the freeway on throttle to maintain speed.
PS- for those that will mention the fan control circuit error, I've tested the fans using the output test and the primary fan isn't working, the aux fan works when the AC is running and it keeps the coolant temps in the low 90s. I'll be testing the fan itself by applying 12v directly. I had this happen on my B6 and both the fan and FCM were shot.
