I recently had my clutch switch fail, to get the car home I used a jumper wire. Worked fine, but after replacing the clutch switch I am still getting a starter interlock short to ground fault. I have to hold the key to start it vs being able to just bump it and it runs the starter itself until the engine is running. Curious if I may have accidentally cooked a relay or something? I did replace the aftermarket clutch switch I put in with a new OEM one as well to ensure it wasn't just a bad aftermarket part. Cars a 2007 RS4.
