Excelerate Performance presents the AWE AirGate™ Carbon Intake Suite for the Audi 8V RS 3 and Mk3 TT RS
The largest constant diameter intake system available for the Audi 8V RS 3 and Mk3 TT RS on the planet
Colossal 4.5" carbon intake tube
30% increase in filter surface area over stock
Designed, engineered, and tested in-house at AWE
Max gains of 7 hp and 3 ft-lbs of torque at the wheels (S-FLO Open Carbon Intake System, stage 1+ software)
Max gains of 17 hp and 7 ft-lbs of torque at the wheels (S-FLO Closed Carbon Intake System, stage 1+ software)
Increase in overall airbox volume
Completely modular design allows multiple configuration options and an upgrade path
Available as S-FLO Carbon Inlet Tube, S-FLO Shortie Carbon Intake (open element), S-FLO Open Carbon Intake System (open element), and S-FLO Closed Carbon Intake System
Intoxicating turbo spool and diverter valve sounds
S-FLO Closed Carbon Intake System optimized to capture significant amount of ram air over stock, and allows entire air filter to be utilized
Bespoke CNC laser-cut stainless support bracket included
Features the washable and oil-less high-flow S-FLO Filter
Perfect integration with OEM inlet ducting
Retains stock mounting locations for OE fit
Genuine 2x2 carbon fiber construction
UV-stabilized resin and clear coat
Perfect fitment, guaranteed
AWE No Check Engine Light Guarantee
The Options
S-FLO Carbon Inlet Tube:
S-FLO Shortie Carbon Intake:
S-FLO Open Carbon Intake System:
S-FLO Closed Carbon Intake System:
We have the largest IN STOCK inventory of AWE!
PM me today for you AWE needs!
