I've been chasing down my valve cover leaks over the past few weeks... New valve cover (OEM) purchased just over a year ago now. Every time I see a rubber grommet around a screw begin to get coated with oil, I'll tighten it just a tad to see if it'll stop the leak.
After work I finally had it and went straight for re-seating the valve cover... AGAIN (3rd time now). I always torque to 10 NM and do the bolt pattern correctly, however I still have these leaks pop up after a couple months.
The second I started tightening screw #12 (bottom left corner next to timing cover) it just snapped. Me being pissed off like no other I said screw it and dabbed the end of the broken bolt with super glue and popped it in. Tapping out this screw will be VERY challenging since the screws are so small and our cars are aluminum heads... So I wanted to ask you guys a couple things: 1, what would you do to get the end of the screw out? The break is flush with the head. And 2, do you think the super glue will even hold or I might not even need the screw at all? My assumption is it's gonna start leaking within the next few days. (May I also add this screw has never been coated in oil before, no extra tightening to stop a leak)
I swear I have the WORST luck with this car it's actually hilarious 😂 If there's anything good about this at all it's that my cam lobes look good 👍
