For the last 2 years I've been trying to figure out why I can't freely pump gas into my tank without the pump clicking off. At first it was only certain stations and in the following months I could no longer pump at all. Not even just barely trying to squeeze the handle. It's like there is pressure that builds up and the gas wants to come back out of the filler neck. Luckily I don't have much of a commute so I've been just filling gas tanks and pouring them in every few days.
I have been searching and searching for an answer figured it was something with the EVAP system so I replace my charcoal canister recently which did nothing at all. Should have known because I had no codes. Then I found this old post from 2010 and this guy is exactly right!
See the attached picture I pulled the vent/ overflow line out and all my gas pumping issues went away. Something so damn simple, I can't believe that's all it was. You get to it through the fender liner behind the gas door.
Sent from my SM-G965U using Audizine mobile app
