Page 1 of 7 123 ... LastLast
Results 1 to 40 of 263
    Feb 07 2018
    PDX ish
    B8 s4 Avant build
    Original post in the a4 section here https://www.audizine.com/forum/showt...s4-Avant-build
    Maybe I should have posted in the Avant section.
    So I have a deal in place to buy a 2011 s4 swap for my 11 Avant. My Avant burns a quart of oil anywhere from 3-800 miles. Why it varies so much I don't know to be honest. No oil puddles or leaks, and I've had it professionally looked at and confirmed its the piston rings and not the turbo or otherwise. It also has 120k miles and needs timing done so its a time bomb for sure. I need a new engine so I've been looking at 8.5 a4 motors and S4 swaps as an option for a while so I generally have the scope.
    I will get everything I need but not the whole car, as I don't really need the interior/lights/body/glass/brakes etc. The seats of the s4 are gone and I already have the black interior and headliner with Alcantara a4 seats so while a whole car would be nice for a full s4 swap, I can live with my interior and a s4 power-train.
    I know there are a lot of question threads on this forum about s4 Avant swaps and I'm not trying to add to the hypothetical what-if pot. However, its a lot of money and its definitely not super well documented; I've read the few threads where people have done one and unfortunately the details on those threads is pretty sparse. Definitely good info and some key details, but a lot is missing.
    So with that said, here is what I know I need. Some obvious parts and some not.
    Engine
    DSG Transmission
    supercharger assembly
    engine harness
    s4 radiator
    s4 intercooler
    Exhaust -headers through mufflers
    rear valance (already have the right bumper)
    s4 rear differential
    s4 rear axels (sport diff axels are shorter)
    Additional wiring for sport diff pinned into harness
    ECU
    Gauge cluster, Immobilizer ring
    Modules
    So physically I can swap the parts. Not a trained mechanic or anything of the sort but I swamped a 5 speed jdm motor into my 4 speed auto Prelude back in the day, and added the 5 speed bits like the clutch master cylinder, clutch pedal assembly, shifter linkage etc. to get it running. Wired the gauge cluster so it was always in "park" so I could start the car, otherwise the neutral safety lock wouldn't allow it. Backyard at its finest but the end result was great and incognito except for the automatic gauge cluster. The owner of the s4 has agreed to help install this if I proceed so I'm confident we can get the parts pulled (the s4 is partially stripped already) and I'm confident we could physically get the s4 bits in.
    However, the electrical modules have me worried. Older Honda parts all swap, so it really was not an issue to get them running. I read that all modules need to be swapped. I wonder if that's true, partially true depending on the specific accessory, only true if going from b8 to 8.5 or ...?
    Per 300zx2g35's thread (https://www.audizine.com/forum/showt...-S4-Conversion) He went from b8 to b8.5 and updated the wiring harness from a b8.5 Allroad so 8.5 parts like the adaptive headlights would function correctly. In post # 50 300zx2g35 said "B8 to B8 is the easiest as you just need to swap over the motor/trans and the motor harness. No need to do a full teardown like I did. Then the model (Prestige, Premium plus) is just determined by the avant you pick up". Sounds like he is saying modules don't need to be swapped. He didn't go this route, so its not fact, but he is obviously very knowledgeable. VWrcer (https://www.audizine.com/forum/showt...ant-conversion) did a swap and said you have to do all of the modules. No explicit details and cant find a build log.
    Is there a online list of the modules? - if they just swap onto the b8 harness I could move them all over. Would have to strip the interior but it might be a little more work to save a huge headache. My car is a 2011 A4 prestige, while the doner s4 is a 2011 Premium Plus. The options are similar - Nav, 3g, key-less entry, BO. My car has push to start where the s4 does not. The s4 has the ADS suspension while my car does not. Overall pretty similar though.
    Any thoughts or forum links on the modules would be appreciated- this is easily my biggest road block. I don't want a car down permanently due to coding problems.
    300zx2g35 thread noted the following not obvious issues
    1. "Had to swap the gas tank and evap system as the A4 had 3 lines going to the engine bay whereas the S4 only had 2 plus the evap plug was different and I had already upgraded the fuel pump in the S4". Is this a a4 to S4 issue or b8 to b8.5. I can have the s4 owner look but if anyone knows.
    2. Power and ground for electric steering (b8.5 issue so shouldn't matter)
    3. Soundactor - can run the wiring
    4. Brake light switch - switch to s4 to eliminate "Implausible signal" error for sport diff
    Anyone know of anything else to consider or have threads saved with more details? I reached out to the OP's listed above and below to see if anyone will talk with me about it.
    vwrcer did a swap but most of his links are dead so I cant find details
    losik4 did a swap as well but only put up a few posts on it that I could find (http://www.audizine.com/forum/showth...1#post12663352)
    GMG swap - minimal details- https://www.audizine.com/forum/showt...32-B8-S4-Avant!!
    Thanks for any info you care to share in advance.
    Dec 29 2017
    Phoenix, AZ
    Wish I had answers for you...but I'm just here to follow along. I hope you document well. Good luck to you.
    Subbed
    2010 Avant // 2015 Allroad
    Junior Member Two Rings
    Oct 15 2019
    West Coast USA
    Here is the log for the S4 donor car.
    Code:
    VCDS
    Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: Release 19.6.1(x64) Data version: 20190529 DS308.0
    www.Ross-Tech.com
    Dealer/Shop Name:
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Friday,23,August,2019,13:38:56:59673
    VIN: License Plate: 2011 S4
    Mileage: 180300km-112033mi Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 42 46 47 52 53 55 56 5F
     62 6C 72
    VIN: WAUBGAFL4BA085768 Mileage: 180300km-112033miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CCBA) Labels:| 06E-907-551-CAK.clb
     Part No SW: 8K0 907 551 B HW: 8K0 907 551 A
     Component: 3.0T SIMOS84 H07 0002
     Revision: --------
     Coding: 0104000A240F0128
     Shop #: WSC 06325 000 00000
     ASAM Dataset: EV_ECM30TFS0218K0907551B 001002
     ROD: EV_ECM30TFS0218K0907551B.rod
     VCID: 302C055B6BCA4ACF29-8064
    9 Faults Found:
    6201 - Function Restriction due to Faults in Other Modules
     U1113 00 [096] - -
     Intermittent - Not Confirmed - Tested Since Memory Clear
     Freeze Frame:
     Fault Status: 00000001
     Fault Priority: 6
     Fault Frequency: 2
     Mileage: 180295 km
     Date: 2019.04.20
     Time: 03:37:23
     Engine speed: 2808.00 /min
     Normed load value: 0.0 %
     Vehicle speed: 23 km/h
     Coolant temperature: 99 °C
     Intake air temperature: 36 °C
     Ambient air pressure: 900 mbar
     Voltage terminal 30: 13.507 V
     Unlearning counter according OBD: 40
     Engine speed: actual: 2784 /min
     MAF_ENVD: 136.17647 mg/stroke
     Coolant temperature (unfiltered): 99.8 °C
     Engine: operating status: PUC
     Engine load: 0.000000 %
     Vehicle speed: actual: 23 km/h
    6134 - Function Restriction due to Faults in Other Modules
     U1113 00 [096] - -
     Freeze Frame:
     Fault Priority: 6
     Fault Frequency: 2
     Mileage: 180295 km
     Date: 2019.04.20
     Time: 03:37:23
    6202 - EVAP System
     P0456 00 [096] - Very Small Leak Detected
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Mileage: 179804 km
     Date: 2019.04.01
     Time: 20:45:28
     Engine speed: 1385.00 /min
     Vehicle speed: 27 km/h
     Coolant temperature: 48 °C
     Intake air temperature: 21 °C
     Ambient air pressure: 910 mbar
     Voltage terminal 30: 13.710 V
     Unlearning counter according OBD: 27
     Height correction: 907.4355 hPa
     TIA_AM_SCHA: 21.75 °C
     Coolant temperature (unfiltered): 48.0 °C
     Vehicle speed: actual: 27 km/h
     T_AST_ENVD: 154.20 s
     TEMP_CAT_ENVD[1]: 395.000000 °C
    7814 - Coolant Pump for Intercooler
     P190C 00 [045] - No Signal
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Mileage: 180295 km
     Date: 2019.04.20
     Time: 03:37:27
     Engine speed: 830.00 /min
     Normed load value: 24.7 %
     Vehicle speed: 0 km/h
     Coolant temperature: 93 °C
     Intake air temperature: 48 °C
     Ambient air pressure: 930 mbar
     Engine speed: actual: 0 /min
     MAF_ENVD: 0.00000 mg/stroke
     Coolant temperature (unfiltered): 21.8 °C
     Engine: operating status: ES
     Vehicle speed: actual: 0 km/h
    6487 - Engine Off Timer Performance
     P150A 00 [037] - -
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Mileage: 180300 km
     Date: 2010.01.22
     Time: 00:03:34
     Engine speed: 0.00 /min
     Coolant temperature: 21 °C
     Intake air temperature: 24 °C
     Ambient air pressure: 1000 mbar
     Voltage terminal 30: 11.273 V
     Battery voltage: 11.273438 V
    8933 - Secondary Air Injection System Switching Valve Bank 1
     P2440 00 [096] - Stuck Open
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 2
     Mileage: 180300 km
     Date: 2019.06.04
     Time: 20:16:15
     Engine speed: 770.00 /min
     Normed load value: 30.2 %
     Coolant temperature: 17 °C
     Intake air temperature: 18 °C
     Ambient air pressure: 1010 mbar
     Voltage terminal 30: 13.101 V
     Engine speed: actual: 768 /min
     MAF_ENVD: 283.24705 mg/stroke
     Coolant temperature (unfiltered): 17.3 °C
     Engine: operating status: IS
     Battery voltage: 13.101563 V
     STATE_LS_ENVD[1]: 2
    8934 - Secondary Air Injection System Switching Valve Bank 2
     P2442 00 [096] - Stuck Open
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 2
     Mileage: 180300 km
     Date: 2019.06.04
     Time: 20:16:15
     STATE_LS_ENVD[2]: 2
    8931 - Secondary Air Injection System: Bank 1
     P0491 00 [237] - Insufficient Flow
     MIL ON - Confirmed - Tested Since Memory Clear
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Mileage: 180300 km
     Date: 2019.04.21
     Time: 11:13:43
     Engine speed: 892.00 /min
     Normed load value: 15.7 %
     Vehicle speed: 2 km/h
     Coolant temperature: 12 °C
     Intake air temperature: 12 °C
     Voltage terminal 30: 12.999 V
     Engine speed: actual: 896 /min
     MAF_ENVD: 212.43529 mg/stroke
     Coolant temperature (unfiltered): 30.8 °C
     Battery voltage: 12.796875 V
     STATE_LS_ENVD[1]: 2
    8932 - Secondary Air Injection System: Bank 2
     P0492 00 [237] - Insufficient Flow
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Mileage: 180300 km
     Date: 2019.04.21
     Time: 11:13:43
     STATE_LS_ENVD[2]: 2
    Readiness: 0000 0000
    Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
     Part No SW: 8K1 927 156 K HW: 0B5 927 156 F
     Component: 0B5 30TFSINAR H05 0008
     Revision: --H05--- Serial number: 0000001212
     Coding: 000001
     ASAM Dataset: EV_TCMDL501 A02087
     ROD: EV_TCMDL501.rod
     VCID: 3D322C6FAC98B7A7B2-8068
    No fault code found.
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
     Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
     Component: ESP8 quattro H04 0060
     Revision: -------- Serial number: --------------
     Coding: 290D1A
     VCID: 02489F939DE6085F8F-8056
    5 Faults Found:
    00493 - ESP-Sensor Unit (G419)
     008 - Implausible Signal - Intermittent
     Freeze Frame:
     Fault Status: 00101000
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 3
     Mileage: 180295 km
     Time Indication: 0
     Date: 2019.04.20
     Time: 03:37:23
     Freeze Frame:
     Hex Value: 0x18D4
     Hex Value: 0x4212
     Hex Value: 0x121B
     Hex Value: 0x30AA
     Hex Value: 0x00FF
    01324 - Control Module for All Wheel Drive (J492)
     013 - Check DTC Memory - Intermittent
     Freeze Frame:
     Fault Status: 00101101
     Fault Priority: 4
     Fault Frequency: 2
     Reset counter: 4
     Mileage: 180295 km
     Time Indication: 0
     Date: 2019.04.20
     Time: 03:37:23
     Freeze Frame:
     Hex Value: 0x10C4
     Hex Value: 0x4212
     Hex Value: 0x1228
     Hex Value: 0x50AB
     Hex Value: 0x00FF
    01766 - Brake Control Module - Regulation Difference
     000 - - - Intermittent - MIL ON
     Freeze Frame:
     Fault Status: 10100000
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 3
     Mileage: 180295 km
     Time Indication: 0
     Date: 2019.04.20
     Time: 03:37:24
     Freeze Frame:
     Hex Value: 0x01C4
     Hex Value: 0x4292
     Hex Value: 0x121D
     Hex Value: 0x01AB
     Hex Value: 0x00FF
    00778 - Steering Angle Sensor (G85)
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 4
     Mileage: 180299 km
     Time Indication: 0
     Date: 2019.04.20
     Time: 04:34:52
     Freeze Frame:
     Hex Value: 0x1700
     Hex Value: 0x4006
     Hex Value: 0x121C
     Hex Value: 0x2EAF
     Hex Value: 0x00FF
    00473 - Control Module for Elect. Park/Hand Brake (J540)
     Freeze Frame:
     Fault Status: 01101101
     Fault Priority: 6
     Fault Frequency: 1
     Reset counter: 220
     Mileage: 180300 km
     Time Indication: 0
     Date: 2010.01.22
     Time: 00:03:12
     Freeze Frame:
     Hex Value: 0x0000
     Hex Value: 0x4082
     Hex Value: 0x0032
     Hex Value: 0x028A
     Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
     Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
     Component: BCM2 2.0 H05 0434
     Revision: 00002001
     Coding: 090100
     VCID: 76A0F343C12E24FFB3-8022
     Subsystem 1 - Part No SW: 8K0 959 754 BB HW: 8K0 959 754 BB
     Component: FBSAUDIB8 IDG H71 0083
     Serial number: 0513000088231012
     Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
     Component: J764 ELV MLB H37 0042
     Serial number: 2310000060735006
    Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
     Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
     Component: KLIMA 3 ZONEN H08 0180
     Revision: C1000000 Serial number: 01221120101243
     Coding: 66102000
     VCID: 004C959B93EA1A4F99-8054
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
     Freeze Frame:
     Fault Priority: 7
     Fault Frequency: 1
     Reset counter: 5
     Mileage: 180300 km
     Time Indication: 0
     Date: 2010.01.22
     Time: 00:03:10
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
     Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
     Component: BCM1 1.0 H30 0392
     Revision: 10030001 Serial number: 00000000862308
     Coding: 26001091063CAF212700080300003D0D0F9CD24802010161000000
     Shop #: WSC 57623 000 1048576
     VCID: 3C34216BBF82BEAF85-8068
     Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
     Component: WWS 191110 H06 0070
     Serial number: SWF10110195249
     Coding: 00FD11
     Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
     Component: RLS H04 0003
     Serial number: 11160683
     Coding: 025028
     Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
     Component: E1 - LDS H08 0090
     Serial number: 00000000000611100685
    5 Faults Found:
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
     012 - Electrical Fault in Circuit
     Freeze Frame:
     Fault Status: 01101100
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 220
     Mileage: 180300 km
     Time Indication: 0
     Date: 2010.01.22
     Time: 00:03:00
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 220
     Mileage: 180300 km
     Time Indication: 0
     Date: 2010.01.22
     Time: 00:03:00
    01496 - Bulb for Fog-Lamps; Left (L22)
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 219
     Mileage: 180295 km
     Time Indication: 0
     Date: 2019.04.20
     Time: 03:38:00
    01500 - Bulb for Fog-Lamps; Right (L23)
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 55
     Mileage: 162419 km
     Time Indication: 0
     Date: 2018.08.08
     Time: 21:01:00
    02258 - Door Opener Transmitter
     004 - No Signal/Communication
     Freeze Frame:
     Fault Status: 01100100
     Fault Priority: 3
     Fault Frequency: 62
     Reset counter: 254
     Mileage: 138711 km
     Time Indication: 0
     Date: 2017.01.22
     Time: 18:31:00
    Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
     Part No SW: 8K0 919 475 Q HW: 8K0 919 475
     Component: PARKHILFE 4K H06 0070
     Revision: 11001001 Serial number: 51201031900783
     Coding: 20010D
     VCID: 47DE4E87F644ED7718-8012
    Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
     Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
     Component: AirbagVW-AU10 H41 0610
     Serial number: 003GLD0GVDYI
     Coding: 303837354230303030304A55304C384B3053
     ASAM Dataset: EV_AirbaECUVWAUDI010 003010
     ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
     VCID: 45C2448FC448FF67EA-8010
     Seat occupied recognition:
     Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
     Component: BF-Gewichtss. H02 0040
     Serial number: 5810000R1000001YA2
     Crash sensor for side airbag: driver side:
     Serial number: 6334MSME58612664B
     Crash sensor for side airbag: front passenger side:
     Serial number: 6344MSME58614275C
     Crash sensor for side airbag: rear: driver side:
     Serial number: 6352QSME08791E0CS
     Crash sensor for side airbag: rear: passenger side:
     Serial number: 6362QSME0C792434J
     Crash sensor for front airbag: front passenger side:
     Serial number: 63832SME73764336$
    1 Fault Found:
    9443859 - Driver's Front Airbag Crash Sensor
     B101A 15 [137] - Open or Short to Plus
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Mileage: 180300 km
     Date: 2010.01.22
     Time: 00:03:11
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
     Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
     Component: Lenks.Modul H17 0014
     Revision: -------- Serial number: 90372JKF000TJ
     Coding: 000036
     VCID: 3E302B63A99EACBFAB-806A
     Component: E221 - MFL H02 0010
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
     Part No SW: 8K0 920 981 Q HW: 8K0 920 981 Q
     Component: KOMBIINSTR. H08 0258
     Revision: 00000000 Serial number: EJG45P8CA
     Coding: 8B1709008300D705020000
     VCID: 41CA509FD860D347D6-8014
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
     Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
     Component: GW-BEM 4CAN-M H09 0117
     Revision: EC000056 Serial number: 5600E10B0382DA
     Coding: 00C303
     VCID: 03469A9782FC015784-8056
     Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
     Component: J367-BDM H07 0170
     Serial number: 10006963101110
    1 Fault Found:
    03041 - Energy Management Active
     Freeze Frame:
     Fault Status: 00100000
     Fault Priority: 7
     Fault Frequency: 26
     Reset counter: 5
     Mileage: 180300 km
     Time Indication: 0
     Date: 2019.05.29
     Time: 10:27:13
     Freeze Frame:
     Bin. Bits: 10000
     Voltage: 11.70 V
     Count: 9
    Address 22: AWD (J492) Labels: 8K0-907-163.clb
     Part No SW: 8K0 907 163 A HW: 8K0 907 163 A
     Component: 4 Wheel Drive H10 0025
     Serial number: 000311100001115
     ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
     ROD: EV_AllWheelDiffeQSPCAN.rod
     VCID: 2E101B2371FE5C3F3B-807A
    1 Fault Found:
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
     U1017 00 [008] - -
     [ESP - Steuergerät nicht verfügbar DRC_CAN_ESP_01_SYS_ST]
     Intermittent - Confirmed - Tested Since Memory Clear
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 2
     Reset counter: 5
     Mileage: 180295 km
     Date: 2019.04.20
     Time: 03:37:23
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
     Part No SW: 8T0 959 793 G HW: 8T0 959 793 G
     Component: TSG FA H09 0302
     Coding: 011C03204000410001
     Shop #: WSC 54593 001 1048576
     VCID: 4DD27CAF1438072722-8018
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
     Revision: 00002001 Serial number: 0138804594
     Coding: 0106023A00FA440480B0013200000000
     Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
     Component: GTO BF H01 0080
     Serial number: 00000000000000716226
     Subsystem 2 - Part No: 1K0 951 605 C
     Component: LIN BACKUP HO H05 1501
     Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
     Component: J245 PS039 H07 0041
    4 Faults Found:
    02743 - Bulb for Brake/Turn Signal Light; Right
     012 - Electrical Fault in Circuit - MIL ON
     Freeze Frame:
     Fault Status: 11101100
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 220
     Mileage: 180300 km
     Time Indication: 0
     Date: 2019.06.08
     Time: 14:58:57
    02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 220
     Mileage: 180300 km
     Time Indication: 0
     Date: 2019.06.08
     Time: 14:58:57
    02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 220
     Mileage: 180300 km
     Time Indication: 0
     Date: 2019.06.08
     Time: 14:58:57
    02742 - Bulb for Brake/Turn Signal Light; Left
     Freeze Frame:
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 220
     Mileage: 180300 km
     Time Indication: 0
     Date: 2019.06.08
     Time: 14:58:58
    Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
     Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
     Component: DSP Prem H10 0190
     Revision: 00010001 Serial number: 34804001627401
     VCID: 7AB8E773F536409FD7-802E
    1 Fault Found:
    02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
     011 - Open Circuit
     Freeze Frame:
     Fault Status: 01101011
     Fault Priority: 5
     Fault Frequency: 22
     Reset counter: 220
     Time Indication: 0
     Freeze Frame:
     Voltage: 12.40 V
     Temperature: 33.0°C
     Temperature: 33.0°C
     Bin. Bits: 00000100
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
     Part No SW: 8T0 959 792 G HW: 8T0 959 792 G
     Component: TSG BF H09 0302
     VCID: 4CD471ABEF220E2F35-8018
    1 Fault Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
     012 - Electrical Fault in Circuit - Intermittent
     Freeze Frame:
     Fault Status: 00101100
     Fault Priority: 3
     Fault Frequency: 1
     Reset counter: 219
     Mileage: 180295 km
     Time Indication: 0
     Date: 2019.04.20
     Time: 03:37:24
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
     Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
     Component: EPB Audi B8 H09 0100
     Revision: 00000003 Serial number: 10000000664976
     Shop #: WSC 00000 000 00000
     VCID: 3424094B97D276EF4D-8060
    1 Fault Found:
    01321 - Control Module for Airbags (J234)
     013 - Check DTC Memory - MIL ON
     Freeze Frame:
     Fault Status: 11101101
     Fault Priority: 4
     Fault Frequency: 1
     Reset counter: 220
     Mileage: 180300 km
     Time Indication: 0
     Date: 2010.01.22
     Time: 00:03:12
     Freeze Frame:
     Voltage: 11.10 V
     Count: 80
     Speed: 0.0 km/h
     Hex Value: 0x0260
     Hex Value: 0x0001
     Hex Value: 0x0101
    Address 55: Headlight Range Labels: 8K0-907-357.clb
     Part No: 8K5 907 357 B
     Component: Dynamische LWR H02 0010
     Revision: 00000001 Serial number:
     Coding: 0000004
     VCID: 393A387F70B08B879E-806C
    2 Faults Found:
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
     010 - Open or Short to Plus - Intermittent
     Freeze Frame:
     Fault Status: 00101010
     Fault Priority: 2
     Fault Frequency: 1
     Reset counter: 5
     Mileage: 180300 km
     Time Indication: 0
     Date: 2010.01.22
     Time: 00:03:15
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
     Freeze Frame:
     Fault Status: 11101010
     Fault Priority: 2
     Fault Frequency: 2
     Reset counter: 220
     Mileage: 180300 km
     Time Indication: 0
     Date: 2010.01.22
     Time: 00:03:15
    Address 56: Radio (R) Labels: Redir Fail!
     Part No SW: 4G0 035 082 HW: 4G0 035 082
     Component: Radio U SIRIU H51 0052
     Revision: AB001007 Serial number: 471KZ0A7544331
     Coding: 020007010000000001
     VCID: 5DF28CEF44D897A7D2-8008
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
     Part No SW: 8T1 035 664 C HW: 8T1 035 664 B
     Component: H-BN-NA H49 0116
     Revision: -------- Serial number: 490K40A7592177
     Coding: 010200000206A1EF05000B0E000000030000
     VCID: 383C3D7B8BBA928F61-806C
     Subsystem 1 - Part No: 8R0 060 884 P
     Component: NAR 2010 0407
     Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
     Component: DU7 High H43 0084
     Serial number: 9466K30A0259765
     Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
     Component: E0380 Bedient H08 0100
     Serial number: 00000000307403
     Subsystem 4 - Part No: 8R0 060 961
     Component: CD-Database 1886
    Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
     Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
     Component: TSG HL H06 1401
     Coding: 010C03204000210001
     VCID: 56E093C321EE44FF93-8002
    Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
     Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
     Component: J772__Rearview 0040
     Revision: --H04--- Serial number: 525PA8-J0991OS
     Coding: 1000006
     VCID: 383C3D7B4BBA928F61-806C
    Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
     Component: TSG HR H06 1401
    End----(Elapsed Time: 01:47, VBatt start/end: 11.5V/11.4V. VIgn 11.4V)-----
    Feb 07 2018
    PDX ish
    Log from my car
    Code:
    Wednesday,23,October,2019,18:34:12:42404
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
    Data version: 20190114 DS296.0
    www.Ross-Tech.com
    VIN: WAU4FAFL1BA089434   License Plate:
    Mileage: 200010km-124280mi   Repair Order:
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
              62 6C 6D 72
    VIN: WAU4FAFL1BA089434   Mileage: 200010km-124280miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AD    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H19 0003
       Revision: E1H19---
       Coding: 010C010A290F0160
       ASAM Dataset: EV_ECM20TFS0118K2907115AD 001006
       ROD: EV_ECM20TFS0118K2907115AD.rod
       VCID: 71BCDCA0E12340CF613-8024
    3 Faults Found:
    5658 - Fuel Pressure Sensor (G247)
              P119A 00 [096] - Malfunction
    4105 - Bank 1; System too Lean at Idle
              P2187 00 [096] - -
    4201 - Fuel Level too Low
              P1250 00 [096] - -
    Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
       Part No SW: 8K0 927 158 K    HW: 0BK 927 156 N
       Component: 0BK 20TFSIUSA H08 0010
       Revision: --H08---
       Coding: 001112
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMAL551211 001013
       ROD: EV_TCMAL551211_001.rod
       VCID: 3E26379CE0FDEFB7AC1-806A
       Coding: 1D0D18
       VCID: 025E836CD4054B57889-8056
       Part No SW: 8K0 907 064 CH    HW: 8K0 907 064 CH
       Revision: 00002001
       Coding: 0D0200
       VCID: 78AAE18482D91187A6D-802C
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Serial number: 2310000059186012
       Revision: C1000000    Serial number: 01261120101728
       Coding: 64102000
       VCID: 005A8964DA0959479ED-8054
       Revision: 10030001    Serial number: 00000000867518
       Coding: 26001091063CAF010000080300003D0D0F1C460802010161000000
       VCID: 3C223D94F661FDA7825-8068
       Component: WWS 261110  H06 0070
       Serial number: SWF10110260084
       Coding: 00FD11
       Serial number: 11169252
       Coding: 025028
       Serial number: 00000000001911100996
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
       Revision: 11001001    Serial number: 51201032403040
       Coding: 200103
       VCID: 47C85278BFA7AE7F1F7-8012
       Serial number: 003GLD0GWR0%
       VCID: 45D45870852BBC6FEDB-8010
       Serial number: 5810000R1000001Q1H
       Serial number: 6334MSME5A21503CB
       Serial number: 6344MSME3D5331046
       Serial number: 6352QSME257A5736M
       Serial number: 6362QSME01761F1AJ
       Crash sensor for front airbag: driver side:
       Serial number: 63732SME31774C20Z
       Serial number: 63832SME32772208V
       Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
       Component: Lenks.Modul   H07 0156
       Revision: 00000000    Serial number: 20101129000094
       Coding: 000037
       VCID: 49CC5440A9B3580F093-801C
       Component: E221 - MFL  H03 0003
       Part No SW: 8K0 920 981 C    HW: 8K0 920 981 C
       Component: KOMBIINSTR.   H23 0258
       Revision: 00100000    Serial number: EJB216LCA
       Coding: 8B1611000300D705020000
       VCID: 333016A8DB3F32DF53F-8066
       Revision: EC000056    Serial number: 5600E10B11007D
       Coding: 00C303
       VCID: 03508668CB1F425F83F-8056
       Serial number: 1000952C221110
    Address 36: Seat Mem. Drvr (J136)       Labels:. 8T0-959-760.clb
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0074
       Revision: AA000000    Serial number: 00001002211822
       Coding: 00581B00000000000000
       VCID: 3B203E88F36FFA9F8BF-806E
       Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000110728933
       Coding: 011C13204E00410001
       VCID: 4ACE6B4CACB55317009-801E
       Revision: 00002001    Serial number: 0135858819
       Coding: 0126023A20BA741580B0023200000000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000329732
       Component: J245 PS133  H07 0041
       Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J394 PS229  H07 0041
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 28
                        Reset counter: 246
                        Mileage: 191358 km
                        Time Indication: 0
                        Date: 2019.06.03
                        Time: 18:05:09
       Revision: 00010001    Serial number: 34804001817901
       VCID: 7AAEFB8CBCD50397D09-802E
       Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0000110630894
       Revision: 00000003    Serial number: 00000000804701
       VCID: 343215B4DE3135E74A5-8060
       Coding: 0000004
       VCID: 392C2480F553C88F993-806C
       Revision: AB001007    Serial number: 471K10A7545168
       VCID: 5DE490100D3BD4AFD5B-8008
       Component: H-BN-NA       H51 0116
       Revision: --------    Serial number: 490K00A7594216
       Coding: 010200010006A1EF41000B0E000000030000
       VCID: 382A2184C259D18766D-806C
       Serial number: 9466K.0A0263329
       Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
       Serial number: 00000000690385
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000110640554
       Coding: 010C13204000210001
       VCID: 45D4587085ABBC6FEDB-8010
       Revision: --H04---    Serial number: 525PA8-J0891VL
       Coding: 1000007
       VCID: 382A2184CE59D18766D-806C
    Address 6D: Trunk Elect. (J605)       Labels: Redir Fail!
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Component: J605  Master  H50 0330
       Revision: --------    Serial number: 8K9827851A
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Component: J756  Slave  H50 0330
       Serial number: 8K9827852A
    Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-795.clb
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000110640568
    End----(Elapsed Time: 02:00, VBatt start/end: 11.7V/12.0V. VIgn 12.0V)-----
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Following for interest.
    From my reading, it seems that everyone so far has gone the route of complete interior strip and harness/module swap to avoid any coding etc. issues.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Sep 06 2017
    05 Subaru LGT (HTA71)
    MA
    Following for science
    > S4 Swapped B8 Avant <
    > 2015 Glacier White allroad P+ (RIP) <
    Established Member Two Rings ColoAllroadJeff's Avatar
    Mar 23 2017
    We've got a Land Cruiser, VW Eos & '72 Winnebago
    Lakewood, CO
    Following along...fellow Allroad 3.0T swap dreamer here. I think he definitely needed the brake switch out of the S4 - that hung him up a little on 300Z's swap. Post up pics - can't wait to see the progress!
    22 Etron-S
    21 RS6 Avant
    20 Q3 Turbo-blue!
    13 Allroad with a bunch of mods
    Feb 07 2018
    PDX ish
    So the thread I originally started had some discussion on keeping my zf8 and just swapping the motor which is interesting but I think past my ability. I think you would need a sq5 to make the swap work as the ecu would expect to see a zf and not the dsg a s4 ecu would.
    In looking into this I stumbled upon this a4 to s5 v8 swap. https://www.audizine.com/forum/showt...-s-B8-A4-Build
    Interesting but it looks like he ran into major issues with modules, which is my big fear here.
    Quote Originally Posted by Zingrox View Post
    I've run into some issues with the manual conversion and the ECU. Apparently the ECU, upon seeing any issue with any module I have, will entirely cut communication to it and not reinstate it again. This includes my entire transmission 🙄 so now I'll have to go about wiping the module and long coding a lot of things before putting it back in together. Unfortunately, wiping an ecu isn't as easy as it sounds, and requires Audi Germany to send you the ECU files (immobilizer included) through a secure connection, that not even the dealership can do themselves. So it's an ordeal to say the least
    I'll get past it, no project would be good without some difficulties I guess. Plus, it has helped me learn quite a bit about all this
    followed up by
    Quote Originally Posted by Perry01 View Post
    Would an ECU from the donor vehicle or another S5 with a MT work?
    That is what I am currently using, actually. These ecu's however are setup so they can only be used with their own exact car setup and nothing else. This includes everything from instrument cluster to the window motors (no joke). Everything is module based, and it will refuse to communicate with anything it has an issue with. I'm working on changing that currently, but otherwise it wont even pay attention to my entire transmission control unit because it doesn't like it. Entirely wiping it, or "virginizing" it is what I hope to do, and I've gotten in contact with some pretty experienced and knowledgeable people about it. It would think that the trim levels of the car as is should be the way it should be, and run entirely like OEM with immo and all.
    The build is gonna happen, whether the dang ecu wants to dance or not! I did just get my rear diff in, unfortunately not sports diff. That requires a whole gaggle of additional parts and wiring, since it is electrically actuated. Ill just have to manage without it. I also told the car that it isn't getting washed until it drives itself out of my garage, so right now its absolutely filthy. Might motivate it a little.
    Thanks everyone for the support, I'm really happy you all like it and I like the suggestions thus far!
    Then this
    With any luck I will have a big one soon. Spent almost 4 months waiting for a new ECU to recode, which arrived Monday. Here's to hoping!
    then this gem
    I'm using the S5 ecu for the car, the one meant for the v8. The car will think it's an S5, in a way. The ECU only really needs the body harness for start authentication, and otherwise only pays attention to the engine. So recoding takes care of that part. The guy who I was originally going to have recode the ECU has been really sketchy and difficult to get a hold of. The shop with my car, the one who was in touch with the guy to recode it, has also had enough of it. So the shop bought the software and jumped through the hoops to do so. He intends to do it himself from now. Now I have thus far told him to take his time, for the sake of cost, which is why this wasn't all done very timely
    Anyway, long story short, same shop (av autoworx) intends to recode the ECU for me, and will be able to do so for anyone in the future. Virginization of the ECU, if from the same chassis, will allow it to work with whatever setup you have
    It all would have been done much sooner, but the guy who was originally going to recode it spent a bunch of time wasting everyone's time
    But then it all goes to shit. No need to quote it all but tldr is shop didn't come through with a solution to start the car, and likely tubed the car by leaving the windows down and the car outside.
    He was obviously trying to fit the 4.2 in a car without changing any of the original a4 modules, but I think its a good example of why EVERY module should be swapped.
    Feb 07 2018
    PDX ish
    Quote Originally Posted by Novarider View Post
    You could source the motor/ecu from a Q5, SQ5, A6, Q7. I think there are more just can't think of them right now.
    But I have a local owner who has a damaged s4 and we're working out the finer points of the deal. Without that deal, Id be bidding on wrecks where I'm uncertain if the wiring harness for my avant will mate up nicely to all the modules in say an a6. Thats a big gamble. At this point there are a few swaps completed with the DSG and its all known to work. Its not like the DSG is a bad transmission, but I agree all things equal the zf8 would be my preference.
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Since you want people to only respond in this thread I'll repost my original response here.
    I'm curious why nobody has done just a motor swap and keep the ZF8 transmission. The ZF8 is in the Q5 3.0T and SQ5. It can easily take the HP the 3.0T puts out and is IMO a far superior transmission to the S4 DSG. This whole swap would be much cheaper if you did just the motor. Less parts to buy and much less labor. Unless there is something I'm missing?
    2011 A4 Avant Prestige S-Line
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    You would still need the rear differential from an S4 though, no?
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by avantagg View Post
    If you wanted the sport diff sure but otherwise no.
    For the ecu can't you go into it with vcds and tell the ecu what motor is installed? Why couldn't you just change the 2.0 to the 3.0 and leave everything else alone?
    Mar 28 2009
    Minneapolis, MN
    I agree with you that I'd rather have the ZF8 than a DSG*, but I think you're asking for problems if you swap a 3.0T from a DSG-equipped donor into a 2.0T car with a ZF8. Totally speculation, but I think if you took a 3.0T and ZF8 from a Q5 or SQ5, you'd be golden. Plus, since the Q5 has a hatch, maybe you could even avoid a lot of the sedan-to-wagon harness headaches. Maybe?
    *Personally, if I ever went through a 3.0T swap, I'd do a manual swap at the same time.
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Good question. I wish there were some more documentation on this swap out there. I plan on holding onto my avant for a while and would love to convert at some point. It seems like the easiest route would be B8 to B8. Subscribed for more info.
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Excellent logic Sean. They are essentially very similar cars. Instrument clusters might be different shape though? I know the MMI control panel and shift knob is exactly the same.
    Jul 02 2017
    Knoxville TN
    You can use vcds to go in and change what transmission is installed can't you? Can you not change what motor is installed?
    Feb 07 2018
    PDX ish
    In Zingrox's thread linked above once the ECU saw the wrong transmission (or saw a 6 speed manual when it was expecting a auto) it cut communication and refused to reconnect. That doomed his project.
    I think if you ran a VCDS scan, even without starting the car, that communication would occur before you had the opportunity to enter any options. Maybe not if access the module first, but I don't know how you stop the vehicle from doing its own internal check, so you can get far enough into VCDS to change anything. Maybe I'm wrong but since there was no factory option for a 3.0 s4 mated to a zf that its likely to cut out immediately. With the SQ5 its probably flagged by the system if they don't come back as expected, but probably more of a soft code issue vs locking you out since both the 3.0 and zf are supported configurations. Complete speculation.
    The real question is what modules trigger complete cut off of communication if they're flagged, vs. which modules can fault but still be coded/fixed? Million dollar question. If someone would just crack the ECU this all becomes moot and swaps become trial and error.
    Oct 15 2019
    West Coast USA
    The 3.0t from a Q5 or A6 with the ZF8 is an interesting concept and definitely one worth diving into for future builds.
    My concern using a Q5 would be that the 3.0t wasn't available until the facelift in 2012. I don't know much about the Q5 though so maybe it kept the hydraulic power steering? If not, that route might be better suited for a swap into an Allroad.
    The SQ5 is equipped with the DSG so it would be a moot point to go that route IMO.
    The main issue with swapping the 3.0t comes from the fact that its ran by SIMOS 8.4 or 8.5 depending on year. Few have figured out how to crack the immobilizer on it and those that have done it are most definitely not sharing their secrets. Compare this to anything running on MED17 which can be shipped to speedosolutions and the immobilizer can be defeated for $150. Maybe even less if a shop can do it locally.
    When I get the chance, I'll take a look in VCDS on the S4 and see if you can change the transmission its attached to. Something tells me it would be quite a bit more involved than just changing the coding though. A harness swap might be necessary depending on whether the ZF8 and DL501 have the same plugs. That could be an issue as well if the swap is into an A4 avant because of the power steering. Not so much on an Allroad.
    I started this thread in B8 A4 Tech in hopes that someone with experience retrofitting modules can chime in as to which ones are absolutes.
    Feb 07 2018
    PDX ish
    Quote Originally Posted by MagoAmado View Post
    Once the 3.0 swap is properly documented akin to what lettuce did for his b8.5 2.0 motor swaps, diving too deep into the pool is just asking for things to go sour. Think the right track is establish baseline straight swaps from a single wrecked vehicle, then work on individual components. Would be sweet if someone from Pacific German or forum members who have done it would share some more details on what they did. Mostly it seems super hush hush.
    Mar 28 2009
    Minneapolis, MN
    B8 s4 Avant build
    The B8.5 SQ5 had a ZF8, not a DSG.
    Oct 15 2019
    West Coast USA
    I stand corrected. It does look like the TDI in the rest of the world got the DSG. My mistake.
    Established Member Two Rings 300zx2g35's Avatar
    May 03 2016
    SoMD
    See responses below. Also, I shot you a text at the number you sent me in PM.
    Quote Originally Posted by hardfive View Post
    Engine
    DSG Transmission
    engine harness
    s4 radiator
    s4 intercooler
    ECU
    Modules
    (This list looks good. Not 100% on the need for all the modules. From what I was told, the ECU only looks for the cluster and possibly the steering column as part of the immobilizer system. Best way to get all the hard parts is to drop both the front and rear subframes, that way everything comes out as one piece)
    (From what I was told by a couple people who went the B8 to B8 route, the only things needed were the cluster and possibly the steering column and that was only for the immobilizer system. This also probably applies to going B8.5 to Allroad (B8.5) as most of the wiring/modules will be the same)
    (The modules should all swap over to the B8 harness. I know the Allroad harness I used (B8.5) all my modules swapped over onto so I don't see why B8 would be any different. But again, from my research, as long as you're not making a major change, i.e transmission swap to manual, you shouldn't need all the modules. They wouldn't hurt to have just in case, but shouldn't need them. The biggest offender I could imagine, would be the CAN gateway module, but again, I was told it wasn't needed for B8 to B8)
    1. "Had to swap the gas tank and evap system as the A4 had 3 lines going to the engine bay whereas the S4 only had 2 plus the evap plug was different and I had already upgraded the fuel pump in the S4". Is this a a4 to S4 issue or b8 to b8.5. I can have the s4 owner look but if anyone knows. (This I believe was only a matter of going B8 to B8.5)
    2. Power and ground for electric steering (b8.5 issue so shouldn't matter) (Definitely a B8.5 only issue)
    3. Soundactor - can run the wiring (This is really only if you want it. The car can do without it by pulling the fuse for it. I was going for the full OEM affect which is why I wired it in)
    4. Brake light switch - switch to s4 to eliminate "Implausible signal" error for sport diff (This was a surprise to me as the part numbers were the same. Makes me think the module knows the serial number of the brake light switch)
    2021 Nardo Gray RS5
    2015 Allroad RS5
    2014 Matte Daytona Gray RS7
    1st B8.5 US Avant Conversion
    2014 B8.5 S4 Prestige Avant
    Feb 07 2018
    PDX ish
    Quote Originally Posted by 300zx2g35 View Post
    I thanked you via PM a while back but I'll do here as well as your input is appreciated. I'll reach out if (more like when really) I have more specific questions.
    I have purchased a few needed items that were missing or damaged from the doner S4
    PLM V2 heat exchanger, test pipes, DSG service bits, new motor mounts. Just about have everything I need.
    Trying to schedule the time off from work for early December to get this done.
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Nice. Good luck with the swap. Can't wait to see the results.
    Senior Member Three Rings Sharper_Image's Avatar
    Mar 21 2013
    Warwick, RI
    Subscribed. I have a B8 avant that i wanted to do the swap on but i couldn't find any information regarding the control modules. I thought i would need a complete b8 s4 to swap everything over and because i don't have a garage it would be difficult to do, no storage space for an extra vehicle in my driveway. I kinda gave up on the idea and put up the avant for sale to buy a b8.5 S4/S5. Because of the CEL p0088 ive got not hits, so if this thread goes well i might just keep the avant and do the swap.
    Nogaro Blue B7 2.7T swap SLine 6spd manual | K04 Stage 3 | DTM bumper conversion | Air lift V2 | 19" Peelers
    Brilliant Black B8.5 | SQ5 | Red interior | Bone stock |
    Estoril Blue C7 S6 | IE Stage I ECU | IE TCU tune | AWE Track | 034 lowering links | 20x10.5 |
    B8.5 S5 Gone
    B8 Avant Gone
    C7 A7 11.3 @ 120 Gone
    Feb 07 2018
    PDX ish
    Quote Originally Posted by Sharper_Image View Post
    We have a complete S4 doner; I think we're going to swap modules just to make it easier and reduce the likelihood of communication issues. I'd like to say were going to not have to swap modules but I just don't know if that's at all reasonable. So you dont need a full car, but you would need drivetrain, exhaust, and wiring to steal the modules.
    If anyone in the Portland Oregon area wants to bust a few knuckles were gonna tear into this starting next Wednesday 12-18 and go through 12-22. If we don't finish we'll meet back up in the days after Christmas. I'm fully committed to bribing anyone interested with beer and pizza.
    Feb 07 2018
    PDX ish
    2011 S line Prestige A4 Avant - 3.0t swapped
    EPL + 034 Stage 2+ DP ECU tunes| EPL TCU | CTS 187/57 | Roc-Euro Intake | PLM V2 Heat Exchanger | HR coilovers | Front BBK SPM Alcon 375mm | Rear BBK Voshmod 356mm| Milltek full resonated exhaust | test Pipes | 034 Endlinks | RS5 FBSW | 3g+| Deval CF Diffuser| BFI Knob | P3 Gauge| S4 Panda seats| Beaufort Aluminum Trim | RS5 Piano black MMI | S5 gauge trim
    Feb 07 2018
    PDX ish
    Huge props to MagoAmado dude is legit. Could turn this I to a buisness.
    Sent from my SM-G973U1 using Audizine mobile app
    Jul 02 2017
    Knoxville TN
    It would be quite popular if they charge a reasonable amount. Most shops quote 100 hours of labor which is insanely high. There are documented cases where people have done it in their garage in a weekend.
    Established Member Two Rings zgastin's Avatar
    Mar 13 2016
    1986 F250 (barn find full restoration), 2015 F56 4 door Mini Cooper S
    Rochester NY
    Hey all, I have a thread going in the b8 S4 section currently. I am in the middle of this too. 2012 a4 and s4 with a manual trans. The s4 is stripped out, the a4 motor is out. I'm hopefully going to get the 3.0 into the avant this weekend.
    I have been posting videos of the progress so if you want to follow along another build, feel free.
    I'm trying to put out as much info as i can on the process so we can get more people doing this. Let me know if you have any questions on your build and good luck!
    Sent from my SM-G960U1 using Audizine mobile app
    Feb 07 2018
    PDX ish
    I've watched your videos. Definitly want to get some good info out there for everyone to see and build the wagon audi should have.
    I'll reach out if need be but I think were getting close to the final push. Were about 85% done, maybe a bit more. Down to electrical mostly.
    Quote Originally Posted by zgastin View Post
    So yesterday and today we
    Pressure washed motor and differential, hand scrubbed with dawn
    Pressure washed engine bay, also hand scrubbed with dawn
    Dropped rear axle and swapped s4 limited slip and s4 axels
    Swapped s4 specific parts onto the block
    New motor mounts
    Test pipes - audi studs suck ass. 1 broke (luckily in half with enough exposed to remove, and another almost did. Hard to get threads to engage. Got NAPA ones that were Way better).
    Dsg service with new filters, gasket, bolts, cleaned out pan. Fluid needed to be changed but no metal bits or concerns. Was able to pump on 5 quarts of dsg fluid back in.
    Power steering
    Removed hatch interior and rear seat
    Pulled center dash piece around shifter
    Swapped s4 shifter assembly
    Installed bfi knob
    Put rear subframe and suspension back on
    Mounted 3.0 engine and transmission
    Hooked up electrical and cooling lines (not all)
    Radiator, ac condenser
    Front axels
    034 endlinks
    S4 drive line
    I'm sure I'm forgetting a few things20191220_132949.jpeg20191220_132915.jpeg20191220_135459.jpeg20191220_135509.jpeg20191220_135518.jpeg20191220_153107.jpeg20191220_155628.jpeg20191220_155615.jpg20191220_170458.jpeg20191220_174956.jpeg
    Feb 07 2018
    PDX ish
    Here is the location for the hole for the differential. This matches (pretty close, maybe not exact) where the s4's is. The heat shield on the a4 has a bulge for the wiring, but you need to drill a hole in the body. I used a 1 and 3/4 bit and the grommet from the s4 wiring fit perfect.
    Only 4 bolts hold the rear subframe but it's heavy enough with weird weight distribution we needed 3 jack's to get it up and bolted into place
    .20191220_195323.jpeg20191220_195329.jpeg20191221_134304.jpeg20191221_134348.jpeg20191221_134359.jpeg20191221_134434.jpeg20191221_135056.jpeg20191221_145528.jpeg20191221_151453.jpeg
    Feb 07 2018
    PDX ish
    Feb 07 2018
    PDX ish
    Last Moar! For the night. Mobile app limits 10 pics per post...20191221_203137.jpeg20191221_212827.jpeg20191221_215002.jpeg20191221_215009.jpeg
    Mar 13 2016
    Rochester NY
    Wow you are cruising over there. How many people are helping or is it just you?
    I'm pretty much alone aside from some help form my wife to push heavy stuff around.
    I am currently swapping the engine cradle/subframe from the a4 to the s4 since the s4 was dented in the crash. Then I can hopefully get the motor in.
    Feb 07 2018
    PDX ish
    Just me and Magoamado. His knowledge on this car and mechanical skill is impressive so that has helped tremendously. Would fully recommend him to anyone around thinking of doing this.
    Awesome your wife is willing to help out but I can see the struggle as we needed both of us and 3 Jack's to get the rear subframe back in.
    Your still making great progress so huge thumbs up.
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    AWESOMENESS! I cant wait to go for a ride!
    I'm as cool as a cucumber in a bowl of hot sauce.
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    This is awesome, thanks for posting all the detailed pics.
    Feb 07 2018
    PDX ish
    Hot hot teaser video!
    https://youtu.be/YC0iN1gx7ec
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    There it is indeed!
    2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2013 Phantom Black C7 S6 Stage 3 | 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
