So nice! Congrats, must feel good.
2012 B8 Avant (3.0t Swapped)
034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
2011 S line Prestige A4 Avant - 3.0t swapped
EPL + 034 Stage 2+ DP ECU tunes| EPL TCU | CTS 187/57 | Roc-Euro Intake | PLM V2 Heat Exchanger | HR coilovers | Front BBK SPM Alcon 375mm | Rear BBK Voshmod 356mm| Milltek full resonated exhaust | test Pipes | 034 Endlinks | RS5 FBSW | 3g+| Deval CF Diffuser| BFI Knob | P3 Gauge| S4 Panda seats| Beaufort Aluminum Trim | RS5 Piano black MMI | S5 gauge trim
I'm as cool as a cucumber in a bowl of hot sauce.
13 S4 DSG/Sport Diff/Drive Select
Gone:
06 A4 TQM APR tune
01 A4 TQMS
01 S4 Sedan MTM tune
01 S4 Avant APR tune
02 A4 3.0 Sport
99 A6 Avant, w/3rd row
01 A4 Celebration Edition, GIAC tune
Current: 2016 Audi A4 Allroad (in progress)
Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
2009 Brilliant Black A4 Avant Prestige 2010 S4 Prestige 6MT Swapped - SOLD
2012 Nogaro Blue A4 Avant Prestige
2009 Condor Gray A6 Avant Prestige - On daily duty. 240k miles and counting.
2018 Glacier White RS3 Unitronic Stg 2 ECU / TCU
2013 Allroad - Volcano Red
Wednesday,23,October,2019,18:34:12:42404 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4 Data version: 20190114 DS296.0 www.Ross-Tech.com VIN: WAU4FAFL1BA089434 License Plate: Mileage: 200010km-124280mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FL-AU48 (8T0) Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F 62 6C 6D 72 VIN: WAU4FAFL1BA089434 Mileage: 200010km-124280miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb Part No SW: 8K2 907 115 AD HW: 8K2 907 115 D Component: 2.0l R4/4V TF H19 0003 Revision: E1H19--- Coding: 010C010A290F0160 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_ECM20TFS0118K2907115AD 001006 ROD: EV_ECM20TFS0118K2907115AD.rod VCID: 71BCDCA0E12340CF613-8024 3 Faults Found: 5658 - Fuel Pressure Sensor (G247) P119A 00 [096] - Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear 4105 - Bank 1; System too Lean at Idle P2187 00 [096] - - Intermittent - Not Confirmed - Tested Since Memory Clear 4201 - Fuel Level too Low P1250 00 [096] - - Intermittent - Not Confirmed - Tested Since Memory Clear Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 8K0 927 158 K HW: 0BK 927 156 N Component: 0BK 20TFSIUSA H08 0010 Revision: --H08--- Coding: 001112 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_TCMAL551211 001013 ROD: EV_TCMAL551211_001.rod VCID: 3E26379CE0FDEFB7AC1-806A No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ Component: ESP8 quattro H04 0060 Revision: -------- Serial number: -------------- Coding: 1D0D18 Shop #: WSC 06335 000 00000 VCID: 025E836CD4054B57889-8056 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 CH HW: 8K0 907 064 CH Component: BCM2 2.0 H05 0434 Revision: 00002001 Coding: 0D0200 Shop #: WSC 06335 000 00000 VCID: 78AAE18482D91187A6D-802C Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 2310000059186012 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component: KLIMA 3 ZONEN H08 0180 Revision: C1000000 Serial number: 01261120101728 Coding: 64102000 Shop #: WSC 06335 000 00000 VCID: 005A8964DA0959479ED-8054 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H30 0392 Revision: 10030001 Serial number: 00000000867518 Coding: 26001091063CAF010000080300003D0D0F1C460802010161000000 Shop #: WSC 06335 000 00000 VCID: 3C223D94F661FDA7825-8068 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 261110 H06 0070 Serial number: SWF10110260084 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 11169252 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090 Serial number: 00000000001911100996 Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C Component: HOMELINK H01 0010 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 Q HW: 8K0 919 475 Component: PARKHILFE 4K H06 0070 Revision: 11001001 Serial number: 51201032403040 Coding: 200103 Shop #: WSC 06335 000 00000 VCID: 47C85278BFA7AE7F1F7-8012 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 K HW: 8K0 959 655 K Component: AirbagVW-AU10 H41 0610 Serial number: 003GLD0GWR0% Coding: 303837354230303030304A55304C384B3053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 45D45870852BBC6FEDB-8010 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C Component: BF-Gewichtss. H02 0040 Serial number: 5810000R1000001Q1H Crash sensor for side airbag: driver side: Serial number: 6334MSME5A21503CB Crash sensor for side airbag: front passenger side: Serial number: 6344MSME3D5331046 Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME257A5736M Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME01761F1AJ Crash sensor for front airbag: driver side: Serial number: 63732SME31774C20Z Crash sensor for front airbag: front passenger side: Serial number: 63832SME32772208V No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8R0 953 568 K HW: 8R0 953 568 K Component: Lenks.Modul H07 0156 Revision: 00000000 Serial number: 20101129000094 Coding: 000037 Shop #: WSC 06335 000 00000 VCID: 49CC5440A9B3580F093-801C Component: E221 - MFL H03 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 981 C HW: 8K0 920 981 C Component: KOMBIINSTR. H23 0258 Revision: 00100000 Serial number: EJB216LCA Coding: 8B1611000300D705020000 Shop #: WSC 06335 000 00000 VCID: 333016A8DB3F32DF53F-8066 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0117 Revision: EC000056 Serial number: 5600E10B11007D Coding: 00C303 Shop #: WSC 06335 000 00000 VCID: 03508668CB1F425F83F-8056 Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H07 0170 Serial number: 1000952C221110 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8K0 959 760 D HW: 8K0 959 760 D Component: MEM-FS H06 0074 Revision: AA000000 Serial number: 00001002211822 Coding: 00581B00000000000000 Shop #: WSC 06335 000 00000 VCID: 3B203E88F36FFA9F8BF-806E No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 M HW: 8K0 959 793 M Component: TSG FA H12 0357 Revision: Serial number: 0000110728933 Coding: 011C13204E00410001 Shop #: WSC 06335 000 00000 VCID: 4ACE6B4CACB55317009-801E No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 CH HW: 8K0 907 064 CH Component: BCM2 2.0 H05 0434 Revision: 00002001 Serial number: 0135858819 Coding: 0126023A20BA741580B0023200000000 Shop #: WSC 06335 000 00000 VCID: 78AAE18482D91187A6D-802C Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719 Component: GTO BF H06 0050 Serial number: 00000000000000329732 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591 Component: J245 PS133 H07 0041 Subsystem 4 - Part No SW: 8K0 959 591 A HW: 8K0 959 591 Component: J394 PS229 H07 0041 1 Fault Found: 02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 28 Reset counter: 246 Mileage: 191358 km Time Indication: 0 Date: 2019.06.03 Time: 18:05:09 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK Component: DSP Prem H10 0190 Revision: 00010001 Serial number: 34804001817901 VCID: 7AAEFB8CBCD50397D09-802E No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 M HW: 8K0 959 792 M Component: TSG BF H12 0357 Revision: Serial number: 0000110630894 Coding: 011C13204E00410001 Shop #: WSC 06335 000 00000 VCID: 49CC5440A9B3580F093-801C No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 00000000804701 Shop #: WSC 00000 000 00000 VCID: 343215B4DE3135E74A5-8060 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 B Component: Dynamische LWR H02 0010 Revision: 00000001 Serial number: Coding: 0000004 Shop #: WSC 06335 000 00000 VCID: 392C2480F553C88F993-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 HW: 4G0 035 082 Component: Radio U SIRIU H51 0052 Revision: AB001007 Serial number: 471K10A7545168 Coding: 020007010000000001 Shop #: WSC 06335 000 00000 VCID: 5DE490100D3BD4AFD5B-8008 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8T1 035 664 C HW: 8T1 035 664 B Component: H-BN-NA H51 0116 Revision: -------- Serial number: 490K00A7594216 Coding: 010200010006A1EF41000B0E000000030000 Shop #: WSC 06335 000 00000 VCID: 382A2184C259D18766D-806C Subsystem 1 - Part No: 8R0 060 884 P Component: NAR 2010 0407 Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604 Component: DU7 High H43 0084 Serial number: 9466K.0A0263329 Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G Component: E0380 Bedient H08 0100 Serial number: 00000000690385 Subsystem 4 - Part No: 8R0 060 961 Component: CD-Database 1886 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 F HW: 8K0 959 795 F Component: TSG HL H11 0357 Revision: Serial number: 0000110640554 Coding: 010C13204000210001 Shop #: WSC 06335 000 00000 VCID: 45D4587085ABBC6FEDB-8010 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H04--- Serial number: 525PA8-J0891VL Coding: 1000007 Shop #: WSC 06335 000 00000 VCID: 382A2184CE59D18766D-806C No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels: Redir Fail! Part No SW: 8K9 827 851 A HW: 8K9 827 851 A Component: J605 Master H50 0330 Revision: -------- Serial number: 8K9827851A VCID: 3C223D94F661FDA7825-8068 Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A Component: J756 Slave H50 0330 Serial number: 8K9827852A No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 F HW: 8K0 959 795 F Component: TSG HR H11 0357 Revision: Serial number: 0000110640568 Coding: 010C13204000210001 Shop #: WSC 06335 000 00000 VCID: 45D4587085ABBC6FEDB-8010 No fault code found. End----(Elapsed Time: 02:00, VBatt start/end: 11.7V/12.0V. VIgn 12.0V)-----
Monday,27,January,2020,11:13:55:42404 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4 Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: WAUBGAFL4BA085768 License Plate: S4 POST POLAND 1 Mileage: 182010km-113095mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FL-AU48 (8T0) Scan: 01 02 03 05 08 09 10 15 16 17 19 22 36 42 46 47 52 53 55 56 5F 62 6C 6D 72 VIN: WAUBGAFL4BA085768 Mileage: 182010km-113095miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CCBA) Labels:| 06E-907-551-CAK.clb Part No SW: 8K0 907 551 B HW: 8K0 907 551 A Component: 3.0T SIMOS84 H07 0002 Revision: -------- Coding: 0104000A240F0128 Shop #: WSC 48207 003 1048576 ASAM Dataset: EV_ECM30TFS0218K0907551B 001002 ROD: EV_ECM30TFS0218K0907551B.rod VCID: 303A19A42AA909C7797-8064 No fault code found. Readiness: 1110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb Part No SW: 8K1 927 156 K HW: 0B5 927 156 F Component: 0B5 30TFSINAR H05 0008 Revision: --H05--- Serial number: 0000001212 Coding: 000001 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_TCMDL501 A02087 ROD: EV_TCMDL501.rod VCID: 3D243090EDFBF4AFE21-8068 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ Component: ESP8 quattro H04 0060 Revision: -------- Serial number: -------------- Coding: 290D1A Shop #: WSC 06325 000 00000 VCID: 025E836CD4054B57DF3-8056 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 CH HW: 8K0 907 064 CH Component: BCM2 2.0 H05 0434 Revision: 00002001 Coding: 0D0200 Shop #: WSC 06335 000 00000 VCID: 78AAE18482D91187F17-802C Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 2310000060735006 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component: KLIMA 3 ZONEN H08 0180 Revision: C1000000 Serial number: 01221120101243 Coding: 66102000 Shop #: WSC 06325 000 00000 VCID: 005A8964DA095947C97-8054 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H30 0392 Revision: 10030001 Serial number: 00000000862308 Coding: 26001091063CAF212700080300003D0D0F9CD24802010161000000 Shop #: WSC 57623 000 1048576 VCID: 3C223D94F661FDA7D5F-8068 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 261110 H06 0070 Serial number: SWF10110260084 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 11169252 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL Component: E1 - LDS H08 0090 Serial number: 00000000001911100996 Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C Component: HOMELINK H01 0010 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 Q HW: 8K0 919 475 Component: PARKHILFE 4K H06 0070 Revision: 11001001 Serial number: 51201031900783 Coding: 20010D Shop #: WSC 06325 000 00000 VCID: 47C85278BFA7AE7F48D-8012 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 K HW: 8K0 959 655 K Component: AirbagVW-AU10 H41 0610 Serial number: 003GLD0GVDYI Coding: 303837354230303030304A55304C384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 45D45870852BBC6FBA1-8010 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C Component: BF-Gewichtss. H02 0040 Serial number: 5810000R1000001Q1H Crash sensor for side airbag: driver side: Serial number: 6334MSME5A21503CB Crash sensor for side airbag: front passenger side: Serial number: 6344MSME3D5331046 Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME257A5736M Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME01761F1AJ Crash sensor for front airbag: driver side: Serial number: 63732SME31774C20Z Crash sensor for front airbag: front passenger side: Serial number: 63832SME32772208V No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 G HW: 8K0 953 568 G Component: Lenks.Modul H17 0014 Revision: -------- Serial number: 90372JKF000TJ Coding: 000036 Shop #: WSC 06325 000 00000 VCID: 3E26379CE07DEFB7FBB-806A Component: E221 - MFL H03 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 981 Q HW: 8K0 920 981 Q Component: KOMBIINSTR. H08 0258 Revision: 00000000 Serial number: EJG45P8CA Coding: 8B1709008300D705020000 Shop #: WSC 48207 003 1048576 VCID: 41DC4C609183904F869-8014 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0117 Revision: EC000056 Serial number: 5600E10B0382DA Coding: 00C303 Shop #: WSC 06325 000 00000 VCID: 03508668CB1F425FD45-8056 Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H07 0170 Serial number: 1000952C221110 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels: 8K0-907-163.clb Part No SW: 8K0 907 163 A HW: 8K0 907 163 A Component: 4 Wheel Drive H10 0025 Serial number: 000311100001115 ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016 ROD: EV_AllWheelDiffeQSPCAN.rod VCID: 2E0607DC309D1F376BB-807A No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8K0 959 760 D HW: 8K0 959 760 D Component: MEM-FS H06 0074 Revision: AA000000 Serial number: 00001002211822 Coding: 00581B00000000000000 Shop #: WSC 06335 000 00000 VCID: 3B203E88F36FFA9FDC5-806E No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 M HW: 8K0 959 793 M Component: TSG FA H12 0357 Revision: Serial number: 0000110728933 Coding: 011C13204E00410001 Shop #: WSC 06335 000 00000 VCID: 4ACE6B4CACB55317573-801E No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 CH HW: 8K0 907 064 CH Component: BCM2 2.0 H05 0434 Revision: 00002001 Serial number: 0135858819 Coding: 0126023A20BA741580B0023200000000 Shop #: WSC 06335 000 00000 VCID: 78AAE18482D91187F17-802C Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719 Component: GTO BF H06 0050 Serial number: 00000000000000329732 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591 Component: J245 PS133 H07 0041 Subsystem 4 - Part No SW: 8K0 959 591 A HW: 8K0 959 591 Component: J394 PS229 H07 0041 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK Component: DSP Prem H10 0190 Revision: 00010001 Serial number: 34804001627401 VCID: 7AAEFB8CBCD50397873-802E No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 M HW: 8K0 959 792 M Component: TSG BF H12 0357 Revision: Serial number: 0000110630894 Coding: 011C13204E00410001 Shop #: WSC 06335 000 00000 VCID: 49CC5440A9B3580F5E9-801C No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 10000000664976 Shop #: WSC 00000 000 00000 VCID: 343215B4DE3135E71DF-8060 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 B Component: Dynamische LWR H02 0010 Revision: 00000001 Serial number: Coding: 0000004 Shop #: WSC 06335 000 00000 VCID: 392C2480F553C88FCE9-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 HW: 4G0 035 082 Component: Radio U SIRIU H51 0052 Revision: AB001007 Serial number: 471KZ0A7544331 Coding: 020007010000000001 Shop #: WSC 06325 000 00000 VCID: 5DE490100D3BD4AF821-8008 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8T1 035 664 C HW: 8T1 035 664 B Component: H-BN-NA H49 0116 Revision: -------- Serial number: 490K40A7592177 Coding: 010200010206A1EF05000B0E000000030000 Shop #: WSC 57623 123 104857 VCID: 382A2184C259D187317-806C Subsystem 1 - Part No: 8R0 060 884 P Component: NAR 2010 0407 Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604 Component: DU7 High H43 0084 Serial number: 9466K.0A0263329 Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G Component: E0380 Bedient H08 0100 Serial number: 00000000690385 Subsystem 4 - Part No: 8R0 060 961 Component: CD-Database 1886 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 F HW: 8K0 959 795 F Component: TSG HL H11 0357 Revision: Serial number: 0000110640554 Coding: 010C13204000210001 Shop #: WSC 06335 000 00000 VCID: 45D4587085ABBC6FBA1-8010 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H04--- Serial number: 525PA8-J0991OS Coding: 1000006 Shop #: WSC 06325 000 00007 VCID: 382A2184CE59D187317-806C No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels: Redir Fail! Part No SW: 8K9 827 851 A HW: 8K9 827 851 A Component: J605 Master H50 0330 Revision: -------- Serial number: 8K9827851A VCID: 3C223D94F661FDA7D5F-8068 Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A Component: J756 Slave H50 0330 Serial number: 8K9827852A No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 F HW: 8K0 959 795 F Component: TSG HR H11 0357 Revision: Serial number: 0000110640568 Coding: 010C13204000210001 Shop #: WSC 06335 000 00000 VCID: 45D4587085ABBC6FBA1-8010 No fault code found. End----------(Elapsed Time: 01:54, VBatt start/end: 12.3V/12.3V)-----------
This is my coding for anyone who needs it: Chassis Type: 8K-AU48 (8T0) Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 22 36 3C 42 46 47 52 53 55 56 57 5F 62 6C 72 VIN: WAUZZZ8K09A206155 Mileage: 79710km-49529miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 14-Susp. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1B-Active Steering -- Status: Malfunction 0010 22-AWD -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: Malfunction 0010 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAKA) Labels:. 06E-907-551-CAK.clb Part No SW: 8K0 907 551 HW: 8K0 907 551 Component: 3.0T SIMOS84 H01 0006 Revision: --H01--- Coding: 010C000C240F0228 Shop #: WSC 06399 123 45312 ASAM Dataset: EV_ECM30TFS8K0907551 A02008 ROD: EV_ECM30TFS0218K0907551C.rod VCID: 6ED3A65FB1050C3F75-803A ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb Part No SW: 8K1 927 156 AC HW: 0B5 927 156 E Component: 0B5 30TFSIRdW H03 0006 Revision: --H03--- Serial number: 0000000422 Coding: 000001 Shop #: WSC 75805 741 182736 ASAM Dataset: EV_TCMDL501 A02203 ROD: EV_TCMDL501.rod VCID: 76E38E3FC95534FFBD-8022 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AJ HW: 8K0 907 379 AJ Component: ESP8 quattro H04 0040 Revision: -------- Serial number: -------------- Coding: 296502 Shop #: WSC 06335 000 00000 VCID: 0109EDE3989B034798-8054 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 BS HW: 8K0 907 064 BS Component: BCM2 1.1 H90 0246 Revision: 00002001 Coding: 051200 Shop #: WSC 06335 000 00000 VCID: 020BE2EF9D9D185F81-8056 Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 Serial number: 0209000001587012 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8K2 820 043 T HW: 8K2 820 043 T Component: KLIMA 3 ZONEN H04 0121 Revision: D1000000 Serial number: 01171220131031 Coding: 641460C000 Shop #: WSC 06325 123 12345 VCID: 3A7B5A0FB5CD909F99-806E ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 D HW: 8K0 907 063 D Component: BCM1 1.0 H22 0253 Revision: 05022001 Serial number: 00000000207641 Coding: 260090B14030AF313F01000300001D0D4F9DC7488001016100 0000 Shop #: WSC 73830 741 115767 VCID: 306F782763B15ACF27-8064 Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB Component: WWS 141011 H06 0070 Serial number: SWF11100145166 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10380337 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA Component: E1 - LDS H07 0080 Serial number: 00000000000502091667 Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B Component: HOMELINK H01 0010 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 G HW: 8K0 919 475 A Component: PARKHILFE 8K H06 0040 Revision: 11001001 Serial number: 40040904302814 Coding: 30010D Shop #: WSC 06342 000 00000 VCID: 3D715113A4E3A7A7BC-8068 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels: None Part No SW: 8K0 907 561 HW: 8K0 907 561 Component: ACC2 H07 0080 Serial number: 00000000000000 Coding: 002B8C Shop #: WSC 06335 000 00000 VCID: 6FEDBB5BBE0F05377E-803A ------------------------------------------------------------------------------- Address 14: Susp. Elect. (J250) Labels: None Part No SW: 8K0 907 364 A HW: 8K0 907 364 Component: DAEMPFUNGS-SG H08 0050 Revision: 00000000 Serial number: 21010902160001 Coding: 070181 Shop #: WSC 06335 000 00000 VCID: 31697D2368BB53C728-8064 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H27 0410 Serial number: 0038JD1E3TMQ Coding: 30373435363030303030554A3052384B3053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_A02.rod VCID: 3C775C17B7F9AEAF8B-8068 Crash sensor for side airbag: driver side: Serial number: 6334MSME47144F40C Crash sensor for side airbag: front passenger side: Serial number: 6344MSME44244C28E Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME592208069 Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME111B093AE Crash sensor for front airbag: driver side: Serial number: 63732SME1317061EW Crash sensor for front airbag: front passenger side: Serial number: 63832SME13193B0C/ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 G HW: 8K0 953 568 G Component: Lenks.Modul H13 0013 Revision: -------- Serial number: 90319IB40003I Coding: 00003F Shop #: WSC 06335 000 00000 VCID: 3E73561FA9E5BCBFA5-806A Component: E221 - MFL H03 0004 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 930 L HW: 8K0 920 930 L Component: KOMBIINSTR. H03 0224 Revision: 00200000 Serial number: 9EC553829 Coding: 2FDF1100BE000008010700 Shop #: WSC 06335 123 12345 VCID: 36634E3F81D574FF7D-8062 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 Q HW: 8T0 907 468 L Component: GW-BEM 5CAN-M H10 0095 Revision: FB600048 Serial number: 4800F0912780AE Coding: 000303 Shop #: WSC 06335 000 00000 VCID: 4FAD1BDB1E4F25375E-801A Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H04 0150 Serial number: 19063F62220109 ------------------------------------------------------------------------------- Address 1B: Active Steering (J792) Labels: None Part No SW: 8K0 907 144 C HW: 8K0 907 144 C Component: DYNAMIKLENK. H06 0500 Revision: 50001005 Serial number: -------------- Coding: 8C0000 Shop #: WSC 06335 000 00000 VCID: 2F6D7B5B7E8F45373E-807A ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels: 8K0-907-163.clb Part No SW: 8K0 907 163 HW: 8K0 907 163 Component: 4 Wheel Drive H09 0004 Serial number: 000302090001060 ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007 ROD: EV_AllWheelDiffeQSPCAN.rod VCID: 6DD1A153BC03F7274C-8038 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8K0 959 760 HW: 8K0 959 760 Component: MEM-FS H05 0043 Revision: AA000000 Serial number: 00001001219239 Coding: 00781B00000000000000 Shop #: WSC 06335 000 00000 VCID: 77FD833BC65F4DF7A6-8022 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 8K0 907 566 B HW: 4L0 907 566 B Component: J0769_SWA_MasterH01 0050 Revision: 00H01000 Serial number: 6PZ 009 014-13 Coding: 0001202 Shop #: WSC 06342 000 00000 VCID: 36634E3F41D574FF7D-8062 Subsystem 1 - Part No: 8K0 907 568 B Component: J0770_SWA_Slave_H01 0050 Subsystem 2 - Serial number: 6PZ 009 014-33 Subsystem 3 - Serial number: 5F06.02.0900H010003CD10457ÿ Subsystem 4 - Serial number: D10457ÿ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 D HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000008455238 Coding: 011C12205E01410001 Shop #: WSC 06335 000 00000 VCID: 41892DE3D81BC347D8-8014 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 BS HW: 8K0 907 064 BS Component: BCM2 1.1 H90 0246 Revision: 00002001 Serial number: 0114353298 Coding: 013A0E22203944810230020000000000 Shop #: WSC 06342 123 12345 VCID: 020BE2EF9D9D185F81-8056 Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0080 Serial number: 00000000000001032874 Subsystem 2 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 3 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb Part No SW: 8T1 035 223 A HW: 8T1 035 223 A Component: DSP Prem H05 0030 Revision: 00005001 Serial number: 94813025481104 VCID: 2D516153748337270C-8078 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 D HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000008476978 Coding: 011C12205E01410001 Shop #: WSC 06335 000 00000 VCID: 408F28E7D311CA4FD7-8014 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 G HW: 8K0 907 801 G Component: EPB Audi B8 H08 0080 Revision: 00000003 Serial number: 00000000312445 Shop #: WSC 00000 000 00000 VCID: 3365772B92A761D75A-8066 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8T0-907-357.clb Part No SW: 8H0 907 357 A HW: 8H0 907 357 Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000020 Shop #: WSC 06334 000 00000 VCID: 306F7827A3B15ACF27-8064 Subsystem 1 - Part No: 8K0 941 329 Component: AFS-Modul links H01 S001 Subsystem 2 - Part No: 8K0 941 329 Component: AFS-Modul rechtsH01 S001 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4F0 035 056 K HW: 4F0 035 056 Component: Radio U STD H43 0074 Revision: AB001007 Serial number: 342JO087520053 Coding: 010003010000000000 Shop #: WSC 48154 001 104857 VCID: 285F90475B61120FFF-807C ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4F0 919 148 A HW: 4F0 919 148 Component: R78 DTV-JP 0150 Revision: R0H06000 Serial number: 79300600469801 Coding: 0000316 Shop #: WSC 06335 000 00000 VCID: 2B556F4B8A97391712-807E ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8R1 035 746 K HW: 8R1 035 746 D Component: H-BNT-NA H41 1036 Revision: -------- Serial number: 204H.0E7675710 Coding: 110A01010206C9EF7502CB4E00000401140000000100000002 Shop #: WSC 06325 123 12345 VCID: 3F8D2B1BAEEFB5B7AE-806A Subsystem 1 - Part No: 8R0 060 884 FE Component: ROW 2018 1004 Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604 Component: DU7 High H41 0104 Serial number: A130I80BS018464 Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C Component: E0380 Bedient H02 0030 Serial number: 00000002194568 Subsystem 4 - Part No: 8R0 060 961 C Component: CD-Database 3638 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000008438621 Coding: 010C12204001210001 Shop #: WSC 06335 000 00000 VCID: 448724F7C709D66FF3-8010 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 B HW: 4L0 907 441 A Component: J772__Rearview 0070 Revision: --H12--- Serial number: 525PA8-J9190A6 Coding: 1023007 Shop #: WSC 06342 000 00000 VCID: 377D433B46DF8DF766-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000008439311 Coding: 010C12204001210001 Shop #: WSC 06335 000 00000 VCID: 448724F7C709D66FF3-8010 No fault code found. End-------------------------(Elapsed Time: 04:53)--------------------------
2013 allroad Glacier White/Black Sport. Many Mods.
