Page 2 of 7 FirstFirst 1234 ... LastLast
Results 41 to 80 of 265
  1. #41
    Established Member Two Rings 300zx2g35's Avatar
    May 03 2016
    SoMD
    Looking good!
    2021 Nardo Gray RS5
    2015 Allroad RS5
    2014 Matte Daytona Gray RS7
    1st B8.5 US Avant Conversion
    2014 B8.5 S4 Prestige Avant
  2. #42
    Feb 07 2018
    PDX ish
    Took most of the week off for the holidays. We're about done. Engine in and runs. Found a cracked lower radiator fitting so we will hopefully wrap it up tomorrow.
    Driver seat, rear seats, and back cargo area did need to be removed but the dash didnt. Got the modules figured out; we elected not to do the central airbag module so we'll see if that needs to come out. (EDIT - IT DOES NEED TO COME OUT)
    All that's left is fill and bleed coolant, bleed brakes, and tighten suspension. Bilt on front bumper, tail lights and a few misc interior pieces and were there (bumper not attached yet)20191227_181158.jpeg20191227_191018.jpeg20191228_102712.jpeg20191228_102647.jpeg20191228_102734.jpeg20191228_102743.jpeg20191228_152528.jpeg20191228_152519.jpeg
    Sent from my SM-G973U1 using Audizine mobile app
    2011 S line Prestige A4 Avant - 3.0t swapped
    EPL + 034 Stage 2+ DP ECU tunes| EPL TCU | CTS 187/57 | Roc-Euro Intake | PLM V2 Heat Exchanger | HR coilovers | Front BBK SPM Alcon 375mm | Rear BBK Voshmod 356mm| Milltek full resonated exhaust | test Pipes | 034 Endlinks | RS5 FBSW | 3g+| Deval CF Diffuser| BFI Knob | P3 Gauge| S4 Panda seats| Beaufort Aluminum Trim | RS5 Piano black MMI | S5 gauge trim
  3. #43
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Nice work!
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
  4. #44
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Fantastic!!
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
  5. #45
    Feb 07 2018
    PDX ish
    Start and idle
    https://youtu.be/kPyjsUl5KZc
  6. #46
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by hardfive View Post
    Start and idle
    Cmon we need longer videos!
    2011 A4 Avant Prestige S-Line
  7. #47
    Feb 07 2018
    PDX ish
    Me too! But with no coolant I cant run it too long with the water pump dry. Tomorrow. No more teases I promise.
  8. #48
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    Great work!
    2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2013 Phantom Black C7 S6 Stage 3 | 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
  9. #49
    Feb 07 2018
    PDX ish
    So we got the radiator inlet from audi installed and.... found oil cooler hose after the radiator had a crack in the rubber and a drip leak. Ugh.
    Audi parts closed sunday. 3 auto parts stores later Napa let us in the back to look at the various hoses as there was no match in the system we found an almost exact match 3/4 to gradual 90 bend reduced to 1/2 hose. Perfect fit but unfortunately 2x the oem audi hose.
    Seahawks vs 49ers so time was limited. Got the coolant system filled and bled and the ac charged. Tomorrow we'll bleed brakes, fill trans with last of fluid, tighten suspension and it's down to coding. Car ran at 3k rpms to bleed cooling/heater core for 5-10 min and it performed flawlessly.
  10. #50
    Established Member Two Rings zgastin's Avatar
    Mar 13 2016
    1986 F250 (barn find full restoration), 2015 F56 4 door Mini Cooper S
    Rochester NY
    How much wiring did you have to swap? I'm working on splicing in the clutch sensor stuff on mine for the manual trans swap but the dsg looks like it might have been a little easier.
    Sent from my SM-G960U1 using Audizine mobile app
  11. #51
    Feb 07 2018
    PDX ish
    Quote Originally Posted by zgastin View Post
    The only new wiring was for the sport diff everything else used my original Avant wiring body harness. obviously the engine used the s4 harness but theres only 2 connectors and that went fine.
  12. #52
    Feb 07 2018
    PDX ish
    Quote Originally Posted by Novarider View Post
    OK this one is longer. Maybe we'll finish tonight, and maybe this is overkill, but here she is running while bleeding the system. About 1 minute at about 3k rpms. Test pipes on a stock exhaust.
    Excuse my inability to hit and stay at 3k initially. It was cold and I was a bit excited.
    https://youtu.be/kgA1XJBN95U
    I said it before but Magoamado has been pivotal to getting this all done, so huge props to him.
  13. #53
    Feb 07 2018
    PDX ish
    Can I get MotherFu@$ing drumroll please.
    https://youtu.be/MeQZSayixmA
    https://youtu.be/Z1h1Oq5lj_E
    Sorry they're not pro videos with b roll but Ive been up since 5am and I I cant sleep (not at a time like this!) so I had to get this out.
    Sport diff is in and fully functional.
    Exhaust is a bit chirpy as one stud broke off a downpipe (the dreaded passenger side one to boot) so it's a bit leaky and the rear lift gate is refusing to fully shut and latch properly as it's a sedan now living as a wagon body with no idea it has a hatch or how to use it. Trunk interior still out too so a few loose nuts/bolts for good measure.
    Otherwise my codes are all very pg, and mostly related to component protection on my driver seat memory. Lost my keyless entry and push to start but that's something I'll get working in time I'm sure.
    I need the standard incandescent avant tail lights adaption info 180-205 if anyone can grab me there's as the s4 had led tails so mine aren't coded correctly. We got them to half work, which is enough to drive for now.
    I was only able to get 6 of the 7 liters of dsg fluid in the trans so if anyone has a trick for cramming the last liter in I'm all ears.
    Thanks to everyone who helped with info or just support. Big thanks to those who did this before like 300zx as they blazed a trail and showed this can work. And an absolutely ginormous thanks to Mago as he really made this come togeather and was a great guy to wrench with.
    I've put togeather a spreadsheet of the modules we changed (and didnt) and what codes that got us and how we solved them but it will take some time to get ironed out and clear. Cliff notes is major component modules do need to be changed but a lot of them are pretty accessible.
    I'm gonna go stare at her creepily for a bit then sleep for two hours and drag my ass to work.
    10/10 worth it.20191230_223504.jpeg20191230_230548.jpeg20191230_231047.jpeg
  14. #54
    Dec 29 2017
    Phoenix, AZ
    Nice work!
    2010 Avant // 2015 Allroad
  15. #55
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    B8 s4 Avant build
    Amazing. Well done man! Thanks again for sharing all the info.
    2 questions, would
    you mind sharing the module list?
    And do you think the trunk is a coding issue vs wiring issue?
    I see more swaps coming in 2020! Enjoy that new ride.
  16. #56
    Feb 05 2008
    Kenmore
    B8 s4 Avant build
    Yes!! Congrats, job well done.
  17. #57
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    AWESOMENESS!!!!
    I'm as cool as a cucumber in a bowl of hot sauce.
  18. #58
    Junior Member Two Rings
    Oct 15 2019
    West Coast USA
    Quote Originally Posted by avantagg View Post
    2 questions, would
    If the module has its own address in VCDS it most likely has to be swapped if there is an equal module available from the s4.
    If you don’t have a VCDS cable you may want buy one or find a friend with one because it is a tool that is 100% necessary to successfully accomplish this job.
    Wiring harness is identical so long as options are and there’s no need to pull the harness out unless your a masochist.
    The tailgate module (6D) was showing up as “unregistered” or something like that after the swap. Definitely a coding issue and possibly BCM2 part number specific compatibility issue. For instance, the BCM2 that came in the s4 didn’t even have the pins in it for the keyless system.
  19. #59
    May 03 2016
    SoMD
    Congrats on getting this all completed!!
    Tedious but worth it!
    2021 Nardo Gray RS5
    2015 Allroad RS5
  20. #60
    Feb 07 2018
    PDX ish
    Quote Originally Posted by k.sigota View Post
    Nice work!
    Quote Originally Posted by Quattro 4 Life View Post
    Quote Originally Posted by BeerBrent View Post
    AWESOMENESS!!!!
    Quote Originally Posted by 300zx2g35 View Post
    Thanks y'all. Very appreciative people are following along and I can share in the experience.
    2 questions, would
    Yeah I'll share it but I want to make sure whats in there is accurate. At one point I thought I was getting an error because the sports diff wasn't coded correctly, but we changed those modules so I was just making a wrong and silly assumption. Want to make sure its all accurate. But like Magoamado said if it has a VCDS address, its probably best to change it. Coding and adaptation will take way longer to figure out then just switching whats there.
  21. #61
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    B8 s4 Avant build
    Makes sense. Do you guys have any idea how to get the tail gate working? Sounds like everything else is pretty much buttoned up?
  22. #62
    Senior Member Two Rings DG7's Avatar
    Jun 02 2012
    B8.5 S4 Avant, 8V S3 SB, F36 435i, F56 JCW
    California/Tuscany
    This is one of the reasons why I'd be compelled to sell mine. It's not as special anymore since more people are making them. It's a great car for sure.
  23. #63
    Feb 07 2018
    PDX ish
    Sorry I made your car less special for you? I guess? I dont think anything would make mine feel less special but I'm sure there is a market if you decide to sell.
    Quote Originally Posted by DG7 View Post
  24. #64
    Feb 07 2018
    PDX ish
    The tailgate is probably just going through all the modules in vcds and making sure sedan has been changed to avant for the body. 300zx confirmed his just worked so it's probably just a switch somewhere that's on the "off" position so to speak.
    The keyless entry is probably just a matter of having my bcm reprogrammed at audi with the s4 vin. The s4 bcm that's in the car doesent have the pins but if mine gets recorded, which is easy for audi to do, it's just a matter if my old keys can be matched to the s4, or if I'll need new keys. Audi keys are special to say the least.
    Otherwise it's my component protection on my driver seat that's causing a few systems to error. Systems talk so an error in one can trickle out.
  25. #65
    Jun 02 2012
    California/Tuscany
    No!!!! lol, not you at all. What you've done is quite impressive. It's the impending amount of newly built B8 S4 avants that will soon pop up that makes it feel less special. That's my personal opinion.
    Don't get me wrong, I love driving my S4 avant. My only regret is that I didn't do it sooner. Anyway, kudos to you for the accomplishment. Now can we get some real photos of this beast of yours?
  26. #66
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Special? Sure. An S4 swapped avant is still fairly rare, but Im pretty sure there have been at least a dozen documentations of these completed as of this year. Even more if you search Facebook groups. Some builders are just being more open about the process.
    So, as someone who’s been keenly interested in taking on this project for quite some time, i commend the two authors of this thread for the thorough amount of information they have chosen to share with the enthusiast community.
    And for what it’s worth I’d love to see someone RS5 swap an Allroad. That would be pretty special.
  27. #67
    Feb 07 2018
    PDX ish
    I dont know if I have the ability to take great photos, and Portland weather sucks right now, but I did give her a bath and she was looking pretty good this afternoon.IMG_20191231_150750_01.jpeg
  28. #68
    Feb 05 2008
    Kenmore
    This is inspiring me to figure out the 3.0T swap into the B7. Only a couple examples so far...
  29. #69
    Jun 02 2012
    California/Tuscany
    Sofa King nice in white. Looks sharp!
  30. #70
    Feb 07 2018
    PDX ish
    Got my tail lights coded correctly so yay.
    Working on the litigate. The switch in the driver door still open the hatch, and thats an electrical connection.
    In VCDS if I leave the hatch open, and test the function, it will close the door (pretty hard might I ad but at least I can get it fully closed).
    So its definitely a coding or similar permission issue
    Found this in a thread where liftgate stopped working. May be nothing but Im putting it here until I figure this out
    "There are 2 trunk latch control modules that need to be replaced as a set (pair) but I don't think this is a common failure. If it works intermittently maybe you just have a flaky switch or loose connection. Did you check the wiring into the switch? Or try to spray electric switch or contact cleaner into the switch itself? Could just be a dying switch."
    Ok I get it there is a motor that lowers the litigate and a second one that pulls it closed. Hmm.
    Been all through the coding and still dont see an issue.
  31. #71
    Jul 02 2017
    Knoxville TN
    Did you save a full scan of your avant before the swap?
  32. #72
    Feb 07 2018
    PDX ish
    Yeah it's in post 4.
    So at this point the module says it has no errors or codes. I have a can bus error that I havent identified, so at this point I'm going to concentrate there I guess.
    Otherwise I'm down to
    Airbag (not sure probably something for audi to clear)
    Parking brake (it works fine though)
    Can
    Driver memory seat (component protection)
  33. #73
    Feb 07 2018
    PDX ish
    If I hold the close button on the liftgate for 5+ seconds my tail lights flash but I dont see any change. Anyone know what that does?
  34. #74
    Jul 02 2017
    Knoxville TN
    It adjusts the height the gate stops at. The height you hold the button at is the height it remembers.
    https://youtu.be/1Gqlo4Xyyfw
  35. #75
    Feb 07 2018
    PDX ish
    Interesting. Good info thanks.
  36. #76
    Mar 28 2009
    Minneapolis, MN
    I agree. Your car is no longer special. I’ll do you a favor and take it off your hands so you don’t have to deal with it anymore.
  37. #77
    Jun 02 2012
    California/Tuscany
    Shoot me an offer, I'll consider it.
  38. #78
    Feb 07 2018
    PDX ish
    Blasphemy.
  39. #79
    Veteran Member Three Rings skifreak85353's Avatar
    Sep 23 2015
    Arlington, VA
    I’ll better his offer. You really don’t want to deal with that thing anymore
    ____________________
    2014 Audi Allroad Prem+ Moonlight Blue | Neuspeed Power Module | 19" S5 Rotors + 10mm H+R spacers + PS2's | 19" S4 Peelers anthracite + 25mm/30mm H+R spacers + Blizzaks | Stasis RSB | Alu Kreuz | Avant S-Line springs | 20% tint | Vag Com mods | RSNav CarPlay
    2009 Volvo XC90 V8 R-Design
    2013 Subaru WRX Limited (Satin White Pearl) - Gone but not forgotten
    The Instagram the_radifier
  40. #80
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    It's must feel good to accomplish a project that most say it can't be done! Great work!!
    I've been thinking about this swap for the longest time when I had my B8. When I saw this in PNW section, I had to stop by and applaud you.
