Results 1 to 8 of 8
    Senior Member Three Rings Marlon177's Avatar
    Nov 04 2010
    2016 CLA250 4Matic
    NY/South Jersey
    Alignment Input Needed
    I need some input on the alignment report.
    Here is some history and mods I have.
    2012 S4 with no sport diff
    Lowered on solowerks coilovers
    About 26.2 FTG 4 corners
    AG 19x9.5 et40 with Pilot sport A/S 3+ 255/35/19
    My previous tires was also A/S 3+ and I had some inner tire wear (not a lot), and I had to replace the rear springs, therefore alignment is needed. After spending days looking up inner tire wear here, it is recommended to set the toe closer to 0 if the car is lowered. I was able to get the shop to set it to around 0.05 after 10 mins of explaining, but the tech said he can’t adjust the camber and toe in the rear any further, so I would like some input from the alignment report.
    Thank you in advance.
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    I'd like to see side to side numbers the same or at least within 1-2 and some are 3, but that's being picky. Change one thing and it changes others, so you gotta stop somewhere. Id want the front left camber be more to match the front right, and not be less than the right rear. Close enough though.
    It was that front toe that caused your tire wear. Way too much and not even close to matching. But that could be affected by the rear spring swap.
    I'm at -2 front camber with 0 toe and I don't see any wear. Rear is around -1.5 and tiny amount of toe.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Nov 04 2010
    2016 CLA250 4Matic
    NY/South Jersey
    The tech was insisting on keeping the toe at factory or 0.20 and I was like no.
    How about the rear? The toe is at 0.11 and 0.08, will I still have inner tire wear?
    I don’t know why my front changed so much after replacing the rear springs, I only raise the passenger front by 1/8”.
    Here is the alignment report done by Audi before swapping the rear springs.
    Senior Member Three Rings j23a45m's Avatar
    Feb 07 2018
    19’ Qx60, 16' s1000rr, 15’ S4, 12' X5, 10' A3
    Lacaster, Pa
    Quote Originally Posted by Marlon177 View Post
    People take an alignment rack print out, out of context. A little tire wear but your steer ahead is going straight correct we good
    [B]'15 S4 - Sepang Blue|DSG|Sport Differential|MMI|B&O Side Assist|ECS Trans Mount|ECS F/R Diff Mount|MercRacing Hx/ Divorce kit|AWE Touring Exhaust 102mm|Apr Open Carbon Fiber Intake|Iabed 82mm throttle body |35% Tint|3000k Fog LED's|OBD Eleven Mods|Macan 4-piston brembo calipers|Unitronic Stage3 Ecu/ stage 2 Tcu|Custom clear lense and painted Headlights|Ecs carbon lip and rear diffuser|Airlift 3P/H| 10.25 Rsnav|034 Track/Street density/ Sway bar| [/CB]
    Nov 04 2010
    2016 CLA250 4Matic
    NY/South Jersey
    Still looking for input.
    Feb 07 2018
    Lacaster, Pa
    Did you read what I said before. Even from factory it is set this way. All area will never read zero and your steer ahead have you going straight as well. You’ll have slight tire wear but as long as you’re going straight that’s the main point. You give a little to get a lot!
    I’ll post mine if I can find it
    Nov 04 2010
    2016 CLA250 4Matic
    NY/South Jersey
    Quote Originally Posted by j23a45m View Post
    I am asking about the rear, with the current setting will It cause inner tire wear because the tech said he can’t go closer to 0 for the toe, not going straight or not here. After spending days of reading here, going closer to 0 will not have inner tire wear.
    Feb 07 2018
    Lacaster, Pa
    The adjustments are but so much. Hit up 034 for Density line adjustable rear toe links. You get it a little better but again you will still have slight wear.
    Again from factory it’s not all zeroed out!!
