Results 1 to 4 of 4
Thread: Starting issue
    Oct 14 2019
    Georgia
    Starting issue
    I have an 06 Audi A4 2.0t FSI and I’ve had an issue with the fuel system keeping compression. When the car is cold, it can take up to 10 minutes to get the fuel pump to get enough compression to even hear it prime from the front seat. I’ve replaced the cam follower, evap module, fuel filter, and I’m stuck. Anyone have this issue before or even some advice?
    Veteran Member Three Rings Stazi's Avatar
    Aug 27 2019
    2012 Audi A4 S-Line, 2019 Jeep Grand Cherokee Altitude 4x4, 2017 Moomba Craz
    Michigan
    Low pressure fuel pump may be bad
    2012 Audi A4 2.0T S-Line
    K04 // IE Stage 3 K04 tune // USP HFC // Becker Cat-back // ECS Intake Pipe (w/modded airbox + K&N) // ECS Luft-technik FMIC Intercooler and pipe kit // GFB VTA // RS mesh grille // CF M4 style spoiler // ST rear sway bar.
    Oct 14 2019
    Georgia
    Quote Originally Posted by Stazi View Post
    Is there any way to test it or is it worth it just to buy a new one since it’s at 145k
    Aug 27 2019
    Michigan
    You can check the duty cycle using VCDS.
