So my car needs rear brakes, and I generally do brakes myself, so this time won't be any different. However, I am going to swap all of the lines for SS lines and do a brake fluid flush at the same time. My question comes down to in what order do I do things? Do I swap the pads and rotors first, then the brake lines? Brake lines first? Does it matter? My concern would be if I swap the lines first, I'll end up pushing air from the new lines up through the system as I compress the piston. Not sure it would get far enough up into the system to matter, but in case it did..... For the fronts it doesn't matter, since I'll only be swapping the lines for now.
Thoughts?
