Results 1 to 7 of 7
    Oct 05 2019
    MTL
    Winter wheels - sizing, need help!
    Hey community. I have a 2019 q5 sline progressiv. I’ve been looking for winter wheels but keep finding owners of the 2015-2017 models (the q5 has changed as of 2018).
    I am wondering if wheels that fit earlier models would always fit the newer model.
    Here is one for example: Audi says it’s supported until 2017 but can not confirm forment for 2018/2019. Why wouldn’t it fit??
    https://www.audiaccessories.ca/p/Audi__Q5/Cast-aluminium-winter-wheel-in-5-V-spoke-design---brilliant-silver--8-J-x-18/63619522/8R00714988Z8.html
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Both are interchangeable, with only minor differences in offset.
    Oct 05 2019
    MTL
    Thanks @sqiveWould a difference in offset require spacers? Or would the wheels in the like directly fit on a 2019 q5?
    Apr 26 2014
    DFW
    Direct fit. Spacers would only be for aesthetic reasons.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Honestly, 8"/ET39 spec looks better suited for the B9 than for the B8.5. I think you'd be happy.
    That said, have you considered buying used/take-off wheels, or even aftermarket wheels from the likes of Ben ([email protected])? Significantly much better value for your money. Good luck....
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Oct 05 2019
    MTL
    Thanks! Is Ben in Canada?
    Oct 05 2019
    MTL
    Would these also be a direct fit for a 2919 q5?
    https://www.audiaccessories.ca/p/Aud...73637A8Z8.html
