Results 1 to 6 of 6
    Rest in Peace Four Rings adam's rotors's Avatar
    B9SQ5 | B9S4 | HD FXLRST
    THREE (3) NEW EXCLUSIVE adam's rotors PATTERNS AVAILABLE NOW!
    coming up on 14 years in business we keep changing, improving, and adding to our catalog...
    we're the only company in the world doing what we do, made-to-order customizable factory fit replacement rotors with options unlike any.
    over those years we've grown from 5 patterns, to 7, to 10, 14, 17, and now a total of 20 unique pattern options, most of which, exclusive to us!
    www.adamsrotors.com
    introducing our AR sport III & IIII [radial dimple & radial slot] & AR hex [honeycomb w/radial slot inner face]:
    [must be ordered with coated hubs]
    www.adamsrotors.com
    we've been asked alot, does the honeycomb pattern have any benefit? is it just for looks?
    sure, AR hex is more aesthetically focused...but it’s still a form of slotting and back side of these runs out new radial slot. keep in mind, slotting dissipates heat, helps avoid glazing, and adds bite...
    drilling/dimpling do nothing but look good with new-age pads, as they no longer create the gasses they were once used to help disperse. thus, we've focused most of our exclusive patterns around slotting (our double slotting specifically, which we're known for, was designed & tested in many track & endurance race scenarios) to not only keep your brakes cooler when put to the test, but look good with unique, customizable ways of implementing them on factory spec rotors.
    again, this is the 20th pattern in our catalog with plenty (a majority) of them being performance based. if you haven't already, check out ALL our patterns before you do anything...we’re offering options literally no one else does! they are available now to order and loaded into our website!
    www.adamsrotors.com
    adam | adam's rotors inc. | [email protected] | est. 2006
    customizable factory-fit brake rotors, made-to-order | adamsrotors.com
    follow/like/@/tag @adamsrotors on twitter, instagram, & facebook | #adamsrotors
    thanks for all the support so far...these have been a huge hit!
    follow us on IG [@adamsrotors] and also follow our hashtag [#adamsrotors] to see all the new patterns delivering and being installed on customer cars!
    =hump-bump=
