Results 1 to 29 of 29
    Junior Member One Ring
    Sep 23 2019
    Charlotte
    Lowest Offset Possible??
    Hey everyone ... looking to put on a set of aftermarket wheels on my B9 RS5 and I like the look of a deep concave wheel. I’m curios who has done the same and how low of an offset you’ve run with no issues. Obviously with this setup, I ultimately trying to obtain as low as possible in the rear and more positive in the front. Your thoughts?
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by BigPoppa3 View Post
    @jimminez@nemesis has the B9 RS5 fitment on lock.
    20x10 ET18 is quite solid.
    I'm in Wilkes - not too far from you. Let's wait to hear back from Martin.
    https://www.flickr.com/photos/martinmacz/
    Registered Member Four Rings Jimminez's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    This depends on what width of wheel you want, which size of tire you plan on running, and if you plan on lowering your car at all.
    If you answer those, I can help with determining offsets.
    Maintaining some meat on the tires, 285/30R20 on 20x10.5" ET23 works well with no rubbing and can get a good profile.
    More is always possible but you start loosing sidewall profile.
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Jimminez@Nemesis View Post
    Maintaining some meat on the tires, 2985/30R20 on 20x10.5" ET23 works well with no rubbing and can get a good profile.
    With this setup can you lower the RS5 on H&R springs as well with no rubbing? Looking to get an RS5 this weekend and wondering what wheel and tire options would be. 2nd question, I see most people get the full coiloverr setup but I would like to maintain the factory dampening, can I retain that with just lowering springs?
    Thanks,
    Jesse
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    May 16 2007
    Ottawa CA / DE USA
    Quote Originally Posted by Djpeaksd View Post
    Thanks,
    Jesse
    I see most going with springs, either H&R VRT or ABT HAS. That keeps the function of the DRC. I run ABT and love them.
    That exact set up is used on Sportback with ABT springs with no issues.
    Can do BBS CH-R in 20x10.5" ET25 with 285 and be money. That's an easy path.
    Can do custom wheels like BC Forged, HRE, Vossen is you'd like.
    Feb 01 2016
    Encinitas, CA
    Thanks for the speedy response. Maybe we can work something out when I get my car. Would want to do wheels, springs, and intake. 1 last question, I saw your partnership with that carbon company, (super cool) I saw that you said you had 1 set of carbon seat backs available. Is that the whole back of both front seats in carbon for $1,200 if my memory serves me correct? That seems like an awesome deal. Maybe its for something else and Im confused.
    Sep 23 2019
    Charlotte
    Can we run 20x10.5's with ET25, 285/30-20's, lowered 1" on H&R VTF's with 10 or 12mm spacers with no rub or issues? If so can we get a little more aggressive on either of those items?
    May 16 2007
    Ottawa CA / DE USA
    Here when you're ready.
    Seat back pricing if for the pair. Start at $1229.
    https://carbnlab.com/shop-1?olsPage=...b9-2018-and-up
    May 16 2007
    Ottawa CA / DE USA
    You wouldn't be able to run spacers with that wheel and tire combo and be lowered and have no rubbing. Maybe around ~5-8mm to be rub free at most.
    Feb 01 2016
    Encinitas, CA
    Sweet, so I wasn't crazy. Adding these to the list as well. I just need my Panamera to come back as a total loss today, so keep your fingers crossed for me!
    May 16 2007
    Ottawa CA / DE USA
    And missed about Panny getting wrecked. Everyone okay?
    Feb 01 2016
    Encinitas, CA
    Yeah everyone is ok, so that is all that matters, but it has been somewhat of a disaster so far dealing with all of this. Before and after.
    Sorry to thread jack OP!!
    May 16 2007
    Ottawa CA / DE USA
    Damn. Pretty car. Sucks that it's drama after the fact.
    Veteran Member Three Rings MVcycleart's Avatar
    Feb 03 2013
    B7 S4 Avant - SOLD:C7.5 S6 - SOLD:B8.5 S4 - SOLD:B9 RS5 SB
    Gainesville, VA
    I ended up going with BBS CH-R et 18. I have 034 springs that lowered the car a little, and haven't had any issues with rubbing at all.
    B7 RS4 Avant Clone - Complete conversion with all the fixings
    Other: 2015 Mclaren 650S Spider: MSO, Akra, HRE, Velocity Tune
    2004 MV Agusta F4 1000S
    PAST - B7 S4 Avant, B9 RS5 SB, C7.5 S6, B8.5 S4, E-tron SB
    Get busy living, or get busy dying!
    Sep 23 2019
    Charlotte
    Thanks MVcycleart. Are those 10" or 10.5" ? You run any spacers? 285's?
    May 16 2007
    Ottawa CA / DE USA
    Those are 10” and 285/30R20. Looks like no spacers not those pics.
    May 16 2007
    Ottawa CA / DE USA
    Quote Originally Posted by MVcycleart View Post
    Looks great Chris.
    Feb 03 2013
    Gainesville, VA
    BP,
    Martin has the specs nailed on the tires, and i went with et18 b/c i didn't want to run spacers. Wheels are 10" wide.
    Thanks Martin, i almost didn't post b/c it is a bit of a dagger for all the help you provided.
    May 16 2007
    Ottawa CA / DE USA
    BP,
    No worries Chris. Happy to help regardless.
    Veteran Member Three Rings idrinkv8's Avatar
    Nov 01 2008
    Would 12mm be too wide of a spacer on the stock trapezoid wheel on the RS5 without sticking out?
    Veteran Member Four Rings HP18's Avatar
    Jul 18 2004
    Orange County - CA
    I'm running 20x10.5 et25 with 5mm/7mm spacers, so effectively et20 / et18. 285/30 tires.
    No rubbing at all. i can probably go 1-2mm more.
    May 16 2007
    Ottawa CA / DE USA
    Quote Originally Posted by idrinkv8 View Post
    Nope. Will be fine.
    Nov 01 2008
    Nope. Will be fine.
    Should I go 15mm?
    May 16 2007
    Ottawa CA / DE USA
    Should I go 15mm?
    You could but might stick out past front fender. Best to do 12 front and 15 rear.
    Someone has done 15/20mm. Just a matter of what look you want.
    Nov 01 2008
    Cool man thanks! And no rubbing on h and r sport springs or 034...?
    May 16 2007
    Ottawa CA / DE USA
    With 12/15 you should have none.
    Nov 01 2008
    Awesome man thank you so much! Sorry to thread jack!
    Last question!
    With 12 front and 15 rear, how long ball seat bolts should I get? 40/43mm respectively?
    May 16 2007
    Ottawa CA / DE USA
    Last question!
    Now that you’ve acknowledged you’ve jacked the thread, I can’t help you anymore. ;)
    And yup. Can source for you if you’d like.
    Nov 01 2008
    Haha brah! Thanks as always. I’ll be calling very soon.
