Results 1 to 14 of 14
    Junior Member One Ring
    Apr 19 2020
    HONG KONG
    Air suspension level indicator in MMI ADS menu
    Does anyone know how to enable the air suspension level indicator for A6 C7.5 with adaptive air suspension in MMI ADS menu by VCDS or OBDELEVEN.Just like the A6 allroad has a five bar indicator on the top left corner
    Aug 14 2019
    Tampa
    Do you have a vcds from the allroad?
    18 S6
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    There is good info on the german forums/ fb groups if i recall myself. Kinda forgot but i tought it involved flashing your suspension or mmi module (and there i backed up a bit and chickened out). Would still love to have it as a visual (ideally integrated in my FIS module menu).
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Apr 19 2020
    HONG KONG
    Quote Originally Posted by Audisthesia View Post
    Don’t have yet. Recently I saw the C8 A6/A6 avant with air suspension has this level indicator in the bottom right of drive select menu. So I'm curious why the C7 platform doesn’t have.
    Aug 14 2019
    Tampa
    Quote Originally Posted by DJY1993 View Post
    Well, c8 is newer, its naturally going to have things c7 doesnt.
    18 S6
    Apr 19 2020
    HONG KONG
    Quote Originally Posted by Dasquade View Post
    If i understand correctly as you mean, itÂ’s not a
    simple work such as change some code or adaptation for control module to active this level indicator. There is a YOUTUBE channel called MtlCarGarage (MtlLine),they uploaded a video about lowering the A6 suspension height ,I leave a comment to ask the same question and hope they can make a video to show the demo about this function,but they only replied me a “yes”. So I’m still trying to find ways to active the indicator but it seems not a easy way to do.
    Apr 19 2020
    HONG KONG
    There is a YOUTUBE channel called MtlCarGarage (MtlLine),they uploaded a video about lowering the A6 C7 suspension height ,I leave a comment to ask the same question and hope they can make a video to show the demo about making level indicator appear in MMI. But they only replied me a “YES”. May be it’s too complex to active it.
    Aug 14 2019
    Tampa
    The vcds method to lower air suspension c7/7.5 is on pretty much every audi Form....Ive yet to see anything about level indicator on any of them..
    18 S6
    Sep 07 2010
    Belgium
    ->posted in the vcds topic
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    This post piqued my interest.
    I tried looking for something in VCDS that would allow for display of level control. I tried Level Control, 5F, Instruments, CAN, Cent. Conv. etc. etc. I could not find anything.
    Perhaps it is something that can be enabled in the Green MMI menu screens? Unfortunately that is something I don't have much details or experience in messing with.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Sep 07 2010
    Belgium
    Quote Originally Posted by gk1 View Post
    Like i posted above....nope, only works if you flash your AAS module and load it with the allroad files with VCP. Still some other things you need to correct (the fb post wasn't complete). I'm sure more info on it can be found on motortalk.de forums but it sucks a little to search and translate etc...Definatly not a quick job but would be nice.
    Aug 06 2014
    NJ->CO
    OK cool. Thanks.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Apr 19 2020
    HONG KONG
    I just make the level indicator appear in drive select,the step like you said delete control unit 34 factory data and flash allroad files. I also add allroad mode in drive select,but there is a new problem, As the picture shows when I choose allroad mode,the white line it is in the middle of the car mode menu(under auto and comfort). Under normal circumstances the white line should at left of the ALLROAD characters.
    Apr 19 2020
    HONG KONG
    Thank you everyone for answering my questions. It seems that the steps are complicated and I have to give up.
