Results 1 to 3 of 3
    Jan 04 2013
    2018 Audi Q5
    Durham, NC
    2019 RS5 Sportback occasionally fails to upshift
    I bought an RS5 in June to replace a perfectly good low mileage 2018 S4. The RS5 is basically as fast 0-60 as my last Corvette (2015 Z51). The only problem I have had to date is the occasional failure to upshift, e.g. 6 to 7, 7 to 8 when the tach is showing 1750 rpm or even higher. The failure to upshift cannot be summoned on demand, so the dealership has no clue as to how to fix the very intermittent problem. The only common factor in the sporadic failures to upshift is ambient temperatures > 90 degrees F. It's almost like the engine thinks it can provide better cooling by running faster. Has anyone else had this happen to them ?
    Established Member Two Rings douglasjboehme's Avatar
    Jul 22 2015
    1995 Land Rover D110 2.8TDi SW, 2016 Sepang Blue 6MT S4
    Blue Bell, PA
    I've only ever had it go longer when I've confused the transmission. When I click the paddles, it always shifts for me.
    2018 RS5 | Misano Red | All Options | AWE Touring Cat Back, BBS CH-R Nürburgring Edition Wheels
    Dec 01 2017
    Dallas
    I have a S4 but I have had this issue. It does seem to be a temperature thing. Its just odd because I can be in D mode and see the car in 8th at say 50 mph. I can bump the shifter over to manual, not changing drive modes (dynamic, comfort, etc) and it will refuse to shift into 8 when I tap the paddle to upshift. Not sure what the issue is and as you said doesn't do it all the time. If I had to guess, some check of the car (speed, temp, etc) isn't met, so the computer doesn't allow it to shift.
