Results 1 to 9 of 9
    Senior Member Two Rings Epic-A3's Avatar
    May 05 2019
    Pennsylvania
    Built engine hard to start, fouled plugs after 10mins of running
    Just got my engine together, A3 BPY. S3 injectors and Autotech hpfp upgrade. Using Eurodyne Maestro editing suite. It's very hard to start, I definitely smell gass while cranking but it wont fire. I pulled plugs after about 10mins of running and they were fouled already. I'm not sure why. Now after driving it home, it just cranks and cranks. I haven't pulled the plugs again but I'm sure I'm gonna find more fouled plugs. Any ideas? Its flashed to stage 1 now, do I need to put it at stage 2 for this setup to start better? Any ideas are welcome. Here is my engine mod list, it's a good bit so I'm hoping somebody here has more experience in real time with a similar set up.
    2006 Audi A3 2.0T FSI- BPY Engine code
    PARTS OWNED or MODIFIED-
    -new cylinder head- p&p
    - 1set titanium nitride coated intake valves 1mm over size
    -1 set hollow sodium exhaust valves 1mm over sized
    - Super Tech springs and retainers
    - new intake and exhaust camshafts
    - new rocker arm- Melling
    - newlifters- Melling
    -new custom turbo ko3 ported outnto k04 size & exhaust manifold p&p
    -Forge wastegate and (tuning kit with 12 lb spring installed)
    -turbo muffler delete
    -Aluminum and silicone intercooler pipes
    - Silicone coolant piping
    -cold air intake
    -runner flap delete
    - pcv delete- catch can
    -a/c compressor delete
    -forged 4340 H beam connecting rod & ARP bolts
    -forged pistons A4 BPG machined flat
    -king racing connecting rod bearings
    - king racing crank bearing
    - king racing thrust washer
    -water pump metal impeller
    -3in. SS Down pipe catless
    - DV upgrade
    -Stop Tech drilled slotted rotors ( front )
    - S3 intercooler
    -S3 injectors
    - race radiator
    - Eurodyne Mastreo tuning suite
    - H&R front sway bar
    - Sensors- MAP, Coolant, Oil pressure, Air intake temp,
    - IE adjustable cam gear
    - new valve cover
    - Arp head studs
    - Stage 2 clutch kit
    - Billet dog bone mount
    - new lower subframe mounts and insert
    -RS4 fuel pressure regulator
    -Ferrara lifter shims
    - new coolant reservoir black caps for it and washer
    - Arp camtower bolts
    - Autotech HPFP upgrade
    P&P ( port and polished)
    Sent from my SM-G950U using Audizine mobile app
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Timings off maybe?
    Sent from my SM-G960U using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    May 05 2019
    Pennsylvania
    Yes in a way I'm sure, down to tune as far as I can tell.
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Are all the plugs fouled or just one? Maybe an injector failure in the open position?
    Injector seal failure at the intake manifold? You shouldn’t smell fuel in the cabin...like at all. Figure out where that’s coming from and maybe you solve this quick.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    May 20 2017
    New Hampshire
    And your car should start and idle with a stock tune so it doesn’t really matter what “stage” you flash it back to. Stock would be best to eliminate any tuning issues. But you’re smelling fuel so I doubt it’s software related.
    May 05 2019
    Pennsylvania
    Found a fuel line I didnt clamp on good enough and it seeped when cranking. That's fixed. All the plugs were fouled, some a little worse then others but nothing notable in difference.
    Jan 06 2012
    Riverside
    I don't know how to tune for it but your runner flap delete is likely contributing heavily to your starting issues if you are not specifically tuned for it. I would also assume you may have more than one issue but eliminating the runner flaps will make the car very hard to start even when everything else is in order.
    2014 Audi A8L 3.0 TDI - malone stage 2 305hp/490ftlb
    2013 VW MK6 Golf R - APR 302hp/297ftlb
    2008 GTI EFR7163 - 480 whp
    Jan 16 2011
    Earth
    AFAIK the runner flaps should not affect anything at all removing my buddy has them removed on per advice of my friend who is a tuner for one of the major companies for Audi performance mods.
    Been running this way for over a month now no issues at all. I have heard of other people deleting them on b6s back when I had 3.0 and never heard of any issues except a slight tiny slight performance loss which is not even really noticable.
    May 05 2019
    Pennsylvania
    Thanks for the tips, I've had the runner flaps out much longer then alot of the other mods. The only time it runs poorly with the runner flap delete is during the 90 sec warm up period. APR has a specific tune for it. I how ever run Eurodyne. Regardless the delete cause no I'll effect except a little flutter for the 90 sec, then it leveled right out.
    I got the information for the S3 injectors, and have put it on stage 2 to compensate for the hpfp. I had a member of the forum that worked with revo to walk me through some stuff. Apparently the front 02 sensor not being in can mess with it pretty bad. The rebuilt engine turns over smooth and sounded pretty good when it was running. Should be able to give it another try next weekend for start up. Still scratching my head why rpms aren't showing on the tack while cranking. No codes. So gotta sort that out.
