Page 7 of 20 FirstFirst ... 5678917 ... LastLast
Results 241 to 280 of 794
  1. #241
    Apr 20 2011
    Hackettstown, NJ
    Quote Originally Posted by 11A6 View Post
    Can you educate me on how a bad injector would cause burnt exhaust valve? I have the 11A6 and wondering if I should replace injectors @ 135k as preventative measure. Thanks for any light you can shed.
    It's all just speculation at this point but I think the injector went bad, caused that cylinder to run lean thus causing it to run hot and it was driven for an extended period of time because the PO didn't want to pay to fix it, and eventually burned the valve and caused loss of compression in that cylinder. I never found out for certain because I replaced the injector on that cylinder just for good measure.
    I can't say for certain because it went through 3 or 4 sets of hands within a few months before me of people probably thinking it just needed a coil and after they found out it likely needed an engine they just dumped it. Poor thing :/
    2009 Brilliant Black A4 Avant Prestige 2010 S4 Prestige 6MT Swapped - SOLD
    2012 Nogaro Blue A4 Avant Prestige
    2009 Condor Gray A6 Avant Prestige - On daily duty. 240k miles and counting.
    2018 Glacier White RS3 Unitronic Stg 2 ECU / TCU
  2. #242
    Senior Member Two Rings 11A6's Avatar
    Jan 04 2018
    Maine
    Quote Originally Posted by rand0mher0 View Post
    Ok thanks - enjoy.. I enjoy mine but seem to have a suspension alignment issue that no one can properly diagnosis. replaced rear subframe bolts and had car aligned which helped massively but now I'm hunting worn suspension items as probable cause and that's not something I can DIY at my level of knowledge but otherwise it's a great car. I see you have the S4 swap with manual. That might be the only thing I'd trade the A6 for as I miss the manual engagement.
    2011 A6 Avant Prestige w/CWP 1/20
  3. #243
    Sep 16 2020
    West Michigan
    Quote Originally Posted by Quattrocentric View Post
    Oh yeah - push to start was available as far back as '07
    My previous 2006 A6 4.2 S line had push to start.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
  4. #244
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    Reading this thread and after getting the production numbers (262 overall in 2009 and 6 Condor Gray with the light gray interior) from Audi makes me realize how lucky I am to have my A6.. lol. Figured I would never find a 3.0t for a reasonable price so I was going to settle for an 05-08 3.2... until I found this.
    2009 Prestige Condor Gray w/ light gray interior. Has every option except cold weather package and rear park sensors.. but it has back up cam (wtf Audi?). Was listed at $3900 with 193k miles and "needing a tune up" I knew it was too good to be true and expected the worst. Negotiated him down to $2900 and it was mine. Turned out it burnt an exhaust valve presumably from being driven for an extended period with a misfire from a bad injector is my best guess. $1000 in a used cyl head and gaskets later and it's been perfect and just hit 198k and doesn't miss a beat. Couldn't ask for a better daily.
    In 09 the backup cam came with the prestige package, and parking sensors were an individual option.
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
  5. #245
    Dec 31 2018
    Chevy Chase MD
    New 3.0T avant just posted. no pictures yet https://www.audibend.com/used/Audi/2...df0f3d9580.htm but the detail says its red which is impossible unless special ordered and thus 1 of 1 for a 2010 since they dropped garnet red for 2010 and 2011 MY. mine is 1 of 8 ever produced in that color. Im curious about this one. Its a prestige BTW and could possibly be a special order color.
  6. #246
    Dec 31 2018
    Chevy Chase MD
    So i could be totally wrong here, but the avant just listed was last sold by Titus Will Chevy in Washington State. I found this old picture in the depths of the internet. If this is it, its a special order color with 19 inch sport package. somebody buy it.
  7. #247
    Veteran Member Four Rings LionKing's Avatar
    Mar 09 2017
    2009 A6 Avant - 5.2L V10 Swapped, 2013 S4 Backroads Warrior
    MD
    I wonder if they will straight trade for mine
    Sent from my LM-V450 using Tapatalk
    "Exhaust Gases go in the turbocharger and spin it, witchcraft happens, and you go faster"
  8. #248
    Apr 20 2011
    Hackettstown, NJ
    Quote Originally Posted by DC Dawg View Post
    Yup that is the one.. didn't know you could even get that on these. Was also wondering how peelers would look on my a6 and now I know. Will have to pick up a set..
  9. #249
    Mar 03 2015
    I have peelers on mine, looks great in 19"
  10. #250
    Veteran Member Three Rings B. Rock's Avatar
    Jul 27 2008
    09 3.0T A6 Avant
    Huh, and interior color being 'other' likely means the 2 tone as well? I don't need 2 avants but hell that's tempting just for the color.
    09 A6 Avant 3.0t
    06 E350 4x4 Cummins swapped
    01 WJ rock toy
  11. #251
    Dec 31 2018
    Chevy Chase MD
    Quote Originally Posted by B. Rock View Post
    My sense is just black interior from what I can tell. If it was a 2011 I would buy it site unseen and figure it out later.
  12. #252
    Jul 27 2008
    09 3.0T A6 Avant
    Ah bummer. 2 tone interior and we might actually make that happen. I mean a trip to bend? Heck yes.
    09 A6 Avant 3.0t
    01 WJ rock toy
  13. #253
    Dec 31 2018
    Chevy Chase MD
    Bend is bad ass. I would love to fly out and drive that thing all the way back to MD
  14. #254
    Dec 31 2018
    Chevy Chase MD
    I also would like to point out that this POS is still for sale and 2 more avants were just added to car gurus.
  15. #255
    Mar 09 2017
    MD
    Wow. Thats been for sale since I was looking for mine, but it was overpriced
  16. #256
    Jul 27 2008
    09 3.0T A6 Avant
    Well that red avant in Bend is going back to the auction block, dealership said it didn't pass their inspection for whatever reason. So if you know someone with access to dealer auctions that could be a good one to follow.
    09 A6 Avant 3.0t
    01 WJ rock toy
  17. #257
    Mar 03 2015
    Dealerships don't want to put a dollar into a car. It might need just new tires, or brake pads, something stupid like that.
  18. #258
    Mar 09 2017
    MD
    Quote Originally Posted by G-Can View Post
    Its a 10 year old car, at minimum. Its not going to be worth putting tires or brakes on. Then they would never sell it for a profit. They would have to go under on it to get the car off their lot.
  19. #259
    Jul 27 2008
    09 3.0T A6 Avant
    Well that'd be good news if it were true. I don't have access to the auction circuit to try and follow it but I bet you could snag it for pretty cheap if you did.
    09 A6 Avant 3.0t
    01 WJ rock toy
  20. #260
    Dec 31 2018
    Chevy Chase MD
    The only way an auction takes a car back is if there is significant problems - ie cats/emissions or a transmission etc. But If it was a sold as a 4 or above grade and truned out to be a turd, then they have to take it back. Its a mechanics special :-) **Paging AJ***
  21. #261
    Mar 09 2017
    MD
    Lol.. I wish I had my dealers license... Shoot right now I'm just trying to get my LLC.
  22. #262
    Veteran Member Three Rings Smooremin's Avatar
    Jul 02 2015
    Chicago, IL
    Just because the dealer is sending it back doesnt mean they are challenging or arbitrating the auction. They could have just realized it was too expensive for them to sell with the work that was needed and turned around and shot it back to the chutes.
    IF you have a VIN send it over and I can do some digging...
    24 S8
    96 Grand Marquis
    88 16v Scirocco
  23. #263
    Dec 31 2018
    Chevy Chase MD
    Quote Originally Posted by Smooremin View Post
    WAU4GAFB1AN076811
  24. #264
    Mar 09 2017
    MD
    Yup! It happens all the time at my dealer.
  25. #265
    Jul 27 2008
    09 3.0T A6 Avant
    Let us know what you find out. My last CQ was red and I really miss having a red car in the garage.
    09 A6 Avant 3.0t
    01 WJ rock toy
  26. #266
    Oct 29 2005
    10speed
    San Francisco, CA
    Not sure if anyone saw this one:
    https://fortcollins.craigslist.org/c...286174547.html
    It's so hard to find a Prestige though.
    https://sfbay.craigslist.org/eby/cto...287989307.html
    This one just popped up in the bay but 135k and Premium Plus.
    - Clint
  27. #267
    Dec 31 2018
    Chevy Chase MD
    "Fully Loaded With Premium Plus Package" UGH
    The 2010 looks like a winner with that low mileage. Though i prefer the non facelift front. I imagine he is on the forum.
  28. #268
    Mar 09 2017
    MD
    That 2010 is absolutely the one if I were to buy. Low mileage and already lowered is perfect.
  29. #269
    Oct 29 2005
    10speed
    San Francisco, CA
    Non facelift front as in pre-09? You don't get the 3.0T then
    - Clint
  30. #270
    Dec 31 2018
    Chevy Chase MD
    well the facelift also had a facelift :-)
    09-10 had the same bumper, all 2011 Avants got the S-line front and rear bumper.
  31. #271
    Jan 28 2018
    Audi B7 A4 Sline
    Columbia, SC
    Quote Originally Posted by LionKing View Post
    Dang...one with lower miles than mine. LOL!! I think I just passed 66K recently. Bought it with 38K 2 years ago. Loveland, CO....great excuse to go to CO to see my sister. If I was still looking or itching for another one, I’d be on that plane to get it.
  32. #272
    Oct 29 2005
    10speed
    San Francisco, CA
    Saw this one and was ready to buy a plane ticket https://philadelphia.craigslist.org/...290013296.html, but 190k miles
    - Clint
  33. #273
    Dec 31 2018
    Chevy Chase MD
    for the money, its worth it despite the mileage. looks like it has been meticulously mainatained.
  34. #274
    Mar 03 2015
    Wanted to say the same thing. Even if it requires a new engine it's still good deal, especially if it's accident free!
  35. #275
    Apr 20 2011
    Hackettstown, NJ
    It's on marketplace for $1k less, lol. https://www.facebook.com/marketplace...90864731056608
  36. #276
    Mar 03 2015
    Yeah at that mileage needs timing and other oil leaks sorted. And rarely anybody wants to do that. They rather sell it.
  37. #277
    Jul 27 2008
    09 3.0T A6 Avant
    Anyone ever find out what happened to that red avant?
    09 A6 Avant 3.0t
    01 WJ rock toy
  38. #278
    Dec 31 2018
    Chevy Chase MD
    I would love to know. there are a few more up for sale:
    A 2010 prestige in Denver: https://www.cargurus.com/Cars/invent...ting=296236293
    a 2009 prestige - no photos yet says its NBPE https://www.cargurus.com/Cars/m-Pors...ting=299104347
    another 2010 in Seattle https://www.cargurus.com/Cars/invent...ting=299469557
  39. #279
    Apr 20 2011
    Hackettstown, NJ
    Popped back up at a Nissan dealer in Oregon
    https://www.cars.com/vehicledetail/d...0661/overview/
  40. #280
    Jun 05 2012
    Portland, OR
    Think they listed it again 4/8, Nissan is still going through their inspection/intake process.
    I've called both Nissan and Audi of Bend, they won't spill the beans on why Audi of Bend dumped the Red Avant. . . It doesn't add up. The carfax shows a significant service at 109k before it was traded in.
    To me what is in direct question is all the suspension and brake components. If it needs new brakes/rotors/and suspension components, that all adds up to a pretty bill both parts and labor. Between 100-120k is usually when I replace all the front arms and do these things, so it makes sense. 11yr old car at 115k...
    I'm considering getting this car, it's in my backyard, but I don't like it's been passed around. . . Makes me uncomfortable.
    What do you guys think? Anyone have suggestions on getting some actual answers?
    I'm sending my mechanic to check it out this week.
