Hello all!
This is my first post here! My name's Paul, and oddly enough I'm a VW driver (love my German engineering), but I'm here posting for a friend of mine - it's just easier for me to post for him.
He has a 2013 RS5 with 80xxx km's on it, and recently he has been having some transmission issues. He went to put the car in park after moving the car from his garage to the driveway (engine was cold) and the dashboard started to light up with Transmission warnings, TPMS warnings and various other warning lights. It's been about 3 weeks since then and he's consistently having the car stalled on him as well as the car not being able to start. Also noticed that the fan is running when the engine is off as well.
I've attached the VCDS code from my scanner below - I recognize this may be a mechatronics failure, but it seems quite premature given its mileage. Can anyone of you fine ladies or gentleman provide a further prognosis on these error codes? As of right now, I have cleared them but I still have the file with the codes that were displayed.
Thanks in advance, and grateful for your help,
Paul
// Code
Thursday,25,July,2019,13:04:35:49461
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: License Plate: PRAK1
Mileage: 86250km-53593mi Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 1B 22 36 3C 42 44 46 47 52
53 56 5F 6C
VIN: Mileage: 86250km-53593miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1B-Active Steering -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 B HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0004
Revision: NAH04---
Coding: 1A25003225A6080D3000
Shop #: WSC 54637 000 1048576
ASAM Dataset: EV_ECM42FSI0118T2907560B 001005
ROD: EV_ECM42FSI0118T2907560B.rod
VCID: 3B203F2BD3E9B38F8BF-806E
3 Faults Found:
4629 - ECM Power Relay Load Circuit
P068A 00 [036] - Opens Too Early
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: -40 °C
Intake air temperature: 32 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.167 V
Unlearning counter according OBD: 40
AFS dm: 0.0 kg/h
Median injection timing: 0.000 ms
Engine operating condition-Channel 87: full load
Relative load value: 100.01 %
Tumg: 27.0 °C
Psr w: 1012.97 hPa
Engine torque: 0.0 Nm
10543 - Camshaft Adj. Bank 2 Exhaust
P054C 00 [096] - Cold-Start Timing not Reached
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 85971 km
Date: 2019.07.03
Time: 05:04:57
Engine speed: 1196.00 /min
Normed load value: 32.2 %
Vehicle speed: 1 km/h
Coolant temperature: 39 °C
Intake air temperature: 28 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 13.381 V
Unlearning counter according OBD: 17
AFS dm: 49.7 kg/h
Median injection timing: 1.007 ms
Engine operating condition-Channel 87: Idling
Relative load value: 25.69 %
Tumg: 25.5 °C
Psr w: 458.36 hPa
Engine torque: 92.4 Nm
10577 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [047] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 86252 km
Date: 2019.07.25
Time: 10:11:13
Engine speed: 1299.50 /min
Normed load value: 19.2 %
Coolant temperature: 55 °C
Intake air temperature: 31 °C
Voltage terminal 30: 13.688 V
AFS dm: 31.6 kg/h
Median injection timing: 0.926 ms
Relative load value: 15.56 %
Tumg: 27.0 °C
Psr w: 306.72 hPa
Engine torque: 63.6 Nm
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8T0 927 156 D HW: 0B5 927 156 F
Component: 0B5 42 FSINAR H10 0004
Revision: --H10--- Serial number: 0000000635
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 3E26363FC0FBA6A7AC1-806A
3 Faults Found:
18147 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [168] - -
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 40
Mileage: 86187 km
Date: 2019.07.22
Time: 14:28:41
Engine speed: 1028 /min
Transmission input speed: 1028 /min
Transmission output speed: 225 /min
Engine torque: 20 Nm
Transmission fluid temperature: 36 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen können Moment übertragen
Voltage terminal 30: 13.700 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.982 V
8008 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 40
Mileage: 86187 km
Date: 2019.07.22
Time: 14:28:41
18051 - Shift Fork 2
P284A 00 [096] - Stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 86252 km
Date: 2019.07.25
Time: 10:09:54
Engine speed: 709 /min
Transmission input speed: 709 /min
Transmission output speed: 0 /min
Engine torque: 4 Nm
Transmission fluid temperature: 33 °C
Clutch status: Beide Kupplungen offen
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 2C2D1A
Shop #: WSC 06324 000 00000
VCID: 45D459D3A5ADF57FEDB-8010
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 FP HW: 8K0 907 064 FP
Component: BCM2 2.0 H10 0602
Revision: 00002001
Coding: 0D800000000000000000
VCID: 035087CBEB190B4F83F-8056
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2312000092694005
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000028306942
Coding: 00037025002C00000000
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K1 820 043 N HW: 8K1 820 043 N
Component: KLIMA 3 ZONEN H04 0036
Revision: C1000000 Serial number: 01070520121311
Coding: 4802200000
VCID: 3330170BFB397BCF53F-8066
2 Faults Found:
03269 - Functionality Linited due to Energy Management
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 82
Mileage: 86252 km
Time Indication: 0
Date: 2019.07.25
Time: 11:01:33
01314 - Engine Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 82
Mileage: 86252 km
Time Indication: 0
Date: 2019.07.25
Time: 11:01:33
