Results 1 to 22 of 22
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    How are the RS3's holding up with miles on them?
    Hey guys, I am thinking about trading my modded SQ5 in on an RS3 but my pockets aren't deep enough to buy a low mile one so I have been looking at ones with 30-50K miles on them. I realize there is risk in this depending on who owned the car before but I am doing my best to source a well taken care of example. Also if anyone knows of one for sale with some miles shoot me a PM as I am not finding many out there. Thanks for any tips on this.
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Apr 22 2012
    Norway
    I would first find out if the car was tuned or not. Then use vcds to scan for codes and also check number of launches under auto-trans.
    Check to see if it was serviced and that all oil changes is done. An owner that loves his car would changes oil more often then required.
    Check to see if the stock brakes is still on the car and see how much wear it has.
    (Look at the tire also but you probably did that already)
    Then do all other used car checks.
    Sent from my iPhone
    Sep 15 2017
    QLD, Australia
    Well slightly different as mine is a prefl.
    But 40k, 4 years later, over 100 motorsport events, 100 drag passes + daily driving duties.
    Engine and gearbox are still going strong. No issues. Has been at stage 2+ power on e85 for 20k and 2 years.
    I will say I have spent more $$ than normal on preventative maintenance as well as things like new brakes though, 2 oil changes a year, a dsg oil change, plus the log book servicing. It get's well looked after.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I like the suggestion from context.eax. You can look on carmax, car gurus, auto trader, Edmunds, etc and see if you can find one. I also seen a couple for sale on this forum recently, as a matter of fact, someone just traded a RS3 for a BMW 340M like a couple of weeks ago.
    I think that most of the RS3 for sale on the streets would be un-tuned but you will find some with very light modifications which it should be a big concern. In general, I think is a solid car if you don't go over the board with modifications. I am on the clock to hit 14000 miles my first year of ownership, half of that on a tune.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Veteran Member Three Rings signde's Avatar
    Apr 07 2019
    nashville, tn
    not sure your price range and this one is not high mileage but a local has one for sale and the price seemed good to me. basically every option minus the DA package.
    https://nashville.craigslist.org/cto...937862302.html
    Nov 12 2006
    Michigan
    Quote Originally Posted by signde View Post
    Thanks, I saw that one but am really trying to avoid black or red. Would prefer Nardo, or darker grey.
    Junior Member One Ring
    Nov 03 2018
    Ontario GTA
    I'm at 60,000km on my 2018. Not tuned or modded. I'm still on OE tires, brake pads and rotors (V1) all doing great. Apart from maintenance, I've had the sunroof issue (fixed under warranty) and my full exhaust replaced (fixed under warranty - squeaky valves).
    Veteran Member Three Rings old_spool's Avatar
    Aug 01 2005
    Irvine, CA
    There's a custom code Iroz hybrid turbo car here in SoCal that has around 50k miles and holding up perfectly as a high mileage commuter.
    2002 S4 Nogaro Blue Avant 6MT Stage 3 K04 E85 GIAC X-Treme.
    2019 RS3 Ara Blue - IMS850s, Built Motor, Syvecs, IE Intake, Malaka Inlet/Hoses
    Nov 08 2008
    Toronto, Ontario
    I'm at 79,000km- dealer serviced, fixed sunroof rattle, have O34 Open intake and Unitronic turbo intake- was about to do the Tune 1 and TCU and the VCDS found two minor faults that I am getting fixed at dealer. The car runs and sounds great with no other problems that I can remember.
    May 10 2017
    Lewisberry PA
    Quote Originally Posted by kevin99 View Post
    What is the fix for the sunroof rattle? I have it but I hesitate to violate the integrity of the chassis.
    2017 Ara Blue RS3
    Nov 08 2008
    Toronto, Ontario
    Quote Originally Posted by nesbit View Post
    Not sure. Was fixed under warranty; it came back and they diagnosed that it was a broken seat latch. Got the car back and it was worse but after I opened and closed the roof it seems ok now.
    Senior Member Three Rings keninblaine's Avatar
    Nov 06 2016
    Blaine, Wa
    Quote Originally Posted by S3DUDE View Post
    Did you mean to say "....which it should NOT be a big concern"?
    2018 RS3 Florett Silver
    Jan 09 2018
    ny
    25k miles on mine. daily driver, Uni tuned for the last 5k miles. No issues !
    2018 RS3 [Daytona/Tech/Dynamic/RS design/Unitronic Stg 1+ ECU & Stg 2 TCU]
    Jun 26 2018
    CA
    15k miles here and the only wear/tear seems to be my own fault.. lol.
    The stock tires don't last or go from OK to HORRIBLE quickly. Mechanically, I haven't had any problems. I had a low oil light before first oil change and did that myself.
    I did have a couple rattles in the back that were window sill related but beyond that it's been pretty solid.
    Senior Member Two Rings nicholasdaa's Avatar
    Apr 26 2018
    2018 Tahoe Z71, 2014 E30 Stage 3 Big Turbo Ford Focus ST
    Colorado
    I'm near 40k miles with 0 issues that I didnt cause myself. The only non maintenance part I've replaced was the lpfp, which was only $330 brand new. I've been tuned on E85 for 30k of the miles and the car still feels super strong as I daily it.
    Sent from my SM-N960U using Tapatalk
    Current -
    • 2018 Nardo RS3- 42k Miles - Fully Loaded - Unitronic Stage 2 E85, Unitronic Stage 2 TCU, Uni Port Injectors, APR Intercooler, APR Turbo Inlet, IE Carbon Fiber Intake, IMS Catless DP, IMS Catless Midpipes, Milltek Non-Resonated Catback, 18x8.5 Neuspeed RSe10 Black, 255/30-18 Michelin PS4S
    • 2018 Black Tahoe Z71
    Jul 07 2018
    22 Tesla M3P
    Pleasant Hill, CA
    I'm not high miles yet, but I've put 10k on in the last 8 months of daily driving - mine is almost full bolt on - no downpipe yet - and stage 1 tune. I drive it pretty hard almost daily. No issues at all.
    2024 RS3 - Glacier White - PPF, Tint, ECS Intake
    *SOLD* 18 RS3 - Florett Silver - PPF, tint, Uni Stg 1+ e85/TCU stg 2, APR Intake, throttle inlet & 4in turbo Inlet, CTS Intercooler, Midpipes, fuel-it sensor, sparkplugs, ece dogbone, Uni WG Line upgrade, Eurocode Rear Swaybar w/034 endlinks, 034 Street Motor/Trans mounts, subframe locking collar kit, Neuspeed rse10s, Rotors
    2022 Tesla Model 3 Performance - PPF, Tint, cosmetic mods
    2025 Mazda CX-70 PHEV
    Aug 29 2017
    Tucson, AZ
    Quote Originally Posted by keninblaine View Post
    Good catch.... yes, thanks for the correction. What you said is what I meant.
    at 3100ft elevation
    Aug 29 2017
    Tucson, AZ
    There was a recall like 2-3 months ago about the rear seat latch on a few models. I took mine in.
    at 3100ft elevation
    Oct 07 2008
    Earth
    Whatvwas wrong with the LPFP? Was it clogged? How often do you run 93 octane to keep the fuel pump and injectors clean?
    Quote Originally Posted by nicholasdaa View Post
    Apr 26 2018
    Colorado
    Quote Originally Posted by purekoryo View Post
    I believe I had a bad pump from day 1. I wasn't running E85 last summer in the hot weather so the extra flow wasn't used last year in the heat. But starting at 80+ degrees F this year, I started having low pressure issues randomly on my Stage 2 E85 when WOT above 5k RPM only in high heat. I had 0 issue all winter on the same setup for nearly 25000 miles.
    When I pulled the pump, it looked fine, it just didn't like heat it seemed.
    I've run E85 fuel exclusively since I've gotten tuned without a single tank of Gasoline in between fill ups. I just upgraded injectors about 4k miles ago
    Current -
    Oct 07 2008
    Earth
    How did the old injectors look?
    Apr 26 2018
    Colorado
    Didnt look like any issues, but I didnt get them bench flow tested or anything.
    Current -
