Hello. I’m having issues lately with the AC on my 2008 Audi A4 2.0T.
I have been experiencing issues with my AC lately (and living in south Florida, a proper functioning AC is definitely needed :).
The AC seems to work somewhat ok (blowing 42-44 F) in the early morning, or late evenings or at night, when outside temperatures are below 90F. But when the sun is blazing and outside temperatures are nearing or above 95F (35C), the AC blows 50F for a short period and then rises quickly to blowing the outside temperature.
I also noticed that the left (driver side) vent blows the coldest, then each vent going to the right blows warmer. For example: at 90F outside temperature early in the morning, the left vent (driver side) blows 44F, left center console vent blows 52F, right center com ole vent blows 60F and right vent (passenger side) blows 74F. That seems like a big difference.
I already checked the heater core air mixing vent door (or whatever the correct name for this thing is), and it closes all the way. Also, all vents blow the same amount of air, just not the same temperature.
Notes: a new compressor, condenser, dryer, orifice tube, etc. was installed over a year ago, when the compressor died. The correct amount of Freon was added to the system at that time (by weight).
I hooked up my gauges (in the evening at 88F) and it showed the following: low side 110 and high side 110 when engine was off, then after running the AC on high for 10 minutes it showed: low side 20 and high side 150.
Does anyone have any ideas?
