Results 1 to 19 of 19
    May 01 2017
    Leawood KS
    '14 S6 with tons of codes (MAP, Turbos, and more)
    Sorry for the data dump below but I'm hoping to shed some light for some of my forum brethren. I've been having intermittent codes go off for a couple of months now, and finally got some time to take it to the dealer about a month ago. Here are the 5 codes:
    1) TPMS Error - Tire Pressure System Malfunction
    2) ACC and Audi Braking Guard: Unavailable
    3) Air Suspension System Fault
    4) Sport Differential: System Fault
    5) Stabilization Control (ESC) Fault: See Owner's Manual
    They would go off in rapid succession upon startup, and typically would go away except the Sport Diff error after ~3 minutes of driving. It also seemed to occur more often after a warm start than first thing in the morning.
    The dealer said the battery was testing bad, and quoted me $450. I figure I'd research prices since they seemed brain bleed expensive, and of course I realize the price isn't outrageous, and since I have a CPO warranty still, I'd rather cough up the difference so they couldn't weasel out of if it if I replaced the battery myself or had an indy shop do it. The difference was probably $50, and they ended up charging me just under $400 anyway.
    I got the car back today with the new battery and after two starts, the faults came back and they are more persistent than ever. It'll be another week and a half before I can get back in there so that's frustrating, but the only noticeable effect is that the car drives like the suspension is locked out. We don't really drive the car on the weekends and the roads are smooth around here, but still not fun.
    Anyway, sorry for the long post, but I'd rather not leave any details out. Let me know if anything jumps out at you all. I'd guess that there's something flaky with the ECU start up sequence and it's tripping all those subsystems off, but we'll see. I'll update the post as I find more out.
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
    46 47 52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
    VIN: WAUF2AFC1EN063529 Mileage: 100497km-62445miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: Malfunction 0010
    28-HVAC, Rear -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    8E-Image Processing -- Status: Malfunction 0010
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    BA-Motor Mounts -- Status: Malfunction 0010
    Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
    Part No SW: 4G0 906 014 E HW: 4H0 906 014
    Component: 4.0l V8TFSI / H62 0006
    Revision: NCH62---
    Coding: 0A2500326546000E1000
    Shop #: WSC 48306 001 1048576
    ASAM Dataset: EV_ECM40TFS0114G0906014E 001006
    ROD: EV_ECM40TFS0114G0906014E.rod
    VCID: 2412E4F55E574C878E1-8070
    2 Faults Found:
    11504 - Manifold / Barometric Pressure Sensor (G71) / (F96)
    P0106 00 [096] - Implausible Signal
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 100468 km
    Date: 2019.07.16
    Time: 15:22:18
    Engine speed: 723.50 /min
    Normed load value: 19.2 %
    Vehicle speed: 0 km/h
    Coolant temperature: 90 °C
    Intake air temperature: 81 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 11.285 V
    Unlearning counter according OBD: 40
    Tumg: 31.5 °C
    Outside air temperature via CAN: 31.5 °C
    Engine oil temperature: 82.5 °C
    Time since ignition off: 3880 s
    Adjustment requirements for basic setting-Bits 0-7: 183
    Rear cat conv temp main cat conv model value: 39.83 °C
    Coolant temperature at engine start: 91.5 °C
    9025 - Manifold / Barometric Pressure Sensor (G71) / (F96)
    P0106 00 [232] - Implausible Signal
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 100478 km
    Date: 2019.07.16
    Time: 15:59:58
    Engine speed: 653.00 /min
    Normed load value: 7.1 %
    Coolant temperature: 84 °C
    Intake air temperature: 77 °C
    Voltage terminal 30: 13.876 V
    Engine status: COENG_RUNNING
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    Readiness: 0010 1101
    Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
    Part No SW: 4G9 927 156 C HW: 0B5 927 156 K
    Component: 0B5 40TFSINAR H02 0002
    Revision: --H02---
    Coding: 000001
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_TCMDL501021 001015
    ROD: EV_TCMDL501021.rod
    VCID: 353429B1E5CDC50F29F-8060
    1 Fault Found:
    8448 - Implausible Data Received from Engine Control Module
    U0401 00 [108] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 100468 km
    Date: 2019.07.16
    Time: 15:22:21
    Engine speed: 697 /min
    Transmission input speed: 697 /min
    Transmission output speed: 0 /min
    Engine torque: 8 Nm
    Transmission fluid temperature: 80 °C
    Accelerator position: 0.0 %
    Clutch status: Beide Kupplungen offen
    Voltage terminal 30: 14.300 V
    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.902 V
    Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
    Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
    Component: ESP PREMIUM H09 0450
    Revision: -------- Serial number: --------------
    Coding: 65B65701A66DEA804B00
    ASAM Dataset: EV_ESPPremiAU57X 004039
    ROD: EV_ESPPremiAU57X_004_AU57.rod
    VCID: 3B203F89C3E9137FDFB-806E
    2 Faults Found:
    0787 - Function Restriction due to Implausible Message(s)
    U1112 00 [008] - -
    [SCL_MO_Motormomente_Invalid]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 27
    Mileage: 100468 km
    Date: 2019.07.16
    Time: 15:22:18
    VzRef: 00
    Bit Info 1: 80
    Bit Info 2: 0F
    Bit Info 3: 22
    Bit Info 4: 1F
    F-Path: 00
    F-Type: EA
    Uz: 98
    0732 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    [SCL_QSP_Ist_Moment_Error]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 27
    Mileage: 100468 km
    Date: 2019.07.16
    Time: 15:22:19
    VzRef: 00
    Bit Info 1: 80
    Bit Info 2: 6F
    Bit Info 3: 22
    Bit Info 4: 1F
    F-Path: 01
    F-Type: 08
    Uz: AB
    Address 05: Acc/Start Auth. (J393)
    No fault code found.
    Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
    Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
    Component: KLIMA 4 ZONEN H13 0088
    Serial number: 20091300040857
    Coding: 688120B84D
    ASAM Dataset: EV_AirCondiComfoUDS 002043
    ROD: EV_AirCondiComfoUDS_002.rod
    VCID: 629EA2ED04C302B7BCD-8036
    1 Fault Found:
    0276 - Engine Off Timer Performance
    P150A 00 [008] - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 100456 km
    Date: 2019.07.16
    Time: 13:46:09
    Voltage terminal 30: 14.15 V
    Terminal 15 status: Terminal 15 on
    Address 09: Cent. Elect. (J519)
    Address 10: Park/Steer Assist (J446)
    Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
    Part No SW: 4G0 907 561 A HW: 4G0 907 561
    Component: ACC3 H19 0410
    Serial number: 00000000000000
    Coding: 7601010102
    ASAM Dataset: EV_AdaptCruisContrAU57X 002010
    ROD: EV_AdaptCruisContrAU57X_002.rod
    VCID: 280AF0C5227FA8E7A29-807C
    1 Fault Found:
    105472 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    [FAULT_CIS_VDC_FAIL]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 27
    Mileage: 100468 km
    Date: 2019.07.16
    Time: 15:22:18
    Control Module temperature: 43 °C
    Voltage terminal 15: 11.846 V
    Velocity_vehicle_reference: -0.01 m/s
    Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
    Address 15: Airbags (J234)
    Address 16: Steering wheel (J527)
    Address 17: Instruments (J285)
    Address 19: CAN Gateway (J533)
    Address 22: AWD (J492) Labels: 4H0-907-163.clb
    Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
    Component: 4 Wheel Drive H16 0013
    Serial number: 002209130001449
    ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
    ROD: EV_AllWheelDiffeQSPFR.rod
    VCID: 2708F3F92F61A79FAB3-8072
    1 Fault Found:
    0377 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    [ESP - Steuergerät nicht verfügbar DTC_FRAY_ESP_SYS_STATE]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 4
    Reset counter: 44
    Mileage: 100468 km
    Date: 2019.07.16
    Time: 15:22:19
    Address 28: HVAC, Rear (E265)
    Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
    Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
    Component: LUFE-DAEMPFER H18 0782
    Coding: 008002
    ASAM Dataset: EV_AirSuspe 003024
    ROD: EV_AirSuspe_VW51.rod
    VCID: 2E0606DD009BF6D7685-807A
    1 Fault Found:
    0648 - Function Restriction due to Implausible Message(s)
    U1112 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 27
    Date: 2000.00.00
    Time: 00:00:00
    Address 36: Seat Mem. Drvr (J136)
    Address 3B: Sensor Elect. (J849)
    Address 3C: Lane Change
    Address 42: Door Elect, Driver (J386)
    Address 44: Steering Assist (J500)
    Address 46: Central Conv. (J393)
    Address 47: Sound System (J525)
    Address 52: Door Elect, Pass. (J387)
    Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
    Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
    Component: EPB-4 H03 0014
    Revision: -------- Serial number: 00000000832395
    ASAM Dataset: EV_ParkiBrake 001028
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 2C020CD5368784C7461-8078
    1 Fault Found:
    464384 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 27
    Mileage: 100468 km
    Date: 2019.07.16
    Time: 15:22:18
    Voltage terminal 30: 11.8 V
    Internal Fault ID: 188
    Network management state: normal
    Function light in parking brake button: OFF
    Red operating lamp: OFF
    Red warning lamp: OFF
    Green operating lamp: OFF
    Yellow warning lamp: OFF
    Terminal 15 status: On
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    ACC requested apply: not active
    Auto Adjust: not active
    General Inspection Function: not active
    Internal Parking Brake state: static
    Status of parking brake button: Not operated
    Status ParkingBrake left: Open
    Status ParkingBrake right: Open
    Address 55: Headlight Range (J431)
    Address 56: Radio (R)
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 4G0 035 746 J HW: 4G0 035 746 E
    Component: H-BNT-NA H40 1038
    Revision: -------- Serial number: 194I00D7557160
    Coding: 060200000203F9EF7D12CB1E00000003100001000000000000
    VCID: 2E0606DD001BF6D7685-807A
    Subsystem 1 - Part No: 8R0 060 884 EN
    Component: NAR 2017/2018 1602
    Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
    Component: DU8 C7 SV H43 0021
    Serial number: AUZ8ZDDD002H9CP
    Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
    Component: E380 BDT C7 H11 0204
    Serial number: 90349MIK0017N
    Subsystem 4 - Part No: 8R0 060 961 F
    Component: CD-Database 5298
    3 Faults Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 100456 km
    Time Indication: 0
    Date: 2019.07.16
    Time: 13:46:14
    Freeze Frame:
    Text: DUA009,Front,M,0,0,6
    01043 - Control Module; Incorrect Software Version
    000 - -
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 100497 km
    Time Indication: 0
    Date: 2019.07.16
    Time: 21:11:43
    Freeze Frame:
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00000000 00000010
    03623 - Invalid Security/Release Code
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 100456 km
    Time Indication: 0
    Date: 2019.07.16
    Time: 13:46:13
    Freeze Frame:
    Hex Value: 0x0004
    Hex Value: 0x000B
    Count: 6
    Address 62: Door, Rear Left (J388)
    Address 6C: Back-up Cam. (J928)
    Address 72: Door, Rear Right (J389)
    Address 85: On Board Cam. (J852)
    Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
    Part No SW: 4G0 907 541 A HW: 4G0 907 541
    Component: ACC3 H19 0400
    Coding: 7601010102
    ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
    ROD: EV_AdaptCruisContr2AU57X_002.rod
    VCID: 2616FEFD286BBE97905-8072
    1 Fault Found:
    U1113 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 27
    Mileage: 100468 km
    Date: 2019.07.16
    Time: 15:22:18
    Voltage terminal 15: 11.874 V
    Velocity_vehicle_reference: -0.00 m/s
    Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
    Part No SW: 4G0 907 107 E HW: 4H0 907 107
    Component: BV-SG H32 0041
    Serial number: 005000121609137
    Coding: 04C19A1A0111
    ASAM Dataset: EV_BC7 001001
    ROD: EV_BC7.rod
    2 Faults Found:
    0028 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    [ESP_ESP_01_Signal_Error]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 27
    Mileage: 100468 km
    Date: 2019.07.16
    Time: 15:22:19
    Outside air temperature: 36.5 °C
    Voltage terminal 15: 12.5 V
    Control Module temperature: 0.0 °C
    0165 - Function Restriction due to Faults in Other Modules
    U1113 00 [008] - -
    [QSP_Signal_Error]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 27
    Mileage: 100468 km
    Date: 2019.07.16
    Time: 15:22:20
    Voltage terminal 15: 14.1 V
    Address 8F: Pretens. Frt Left (J854)
    Address 90: Pretens. Frt Right (J855)
    Address A9: Struct. Borne Sound (J869)
    Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
    Part No SW: 4H0 907 145 HW: 4H0 907 145
    Component: AEM - LEAR H07 0006
    Revision: 00001001 Serial number: 97809002545300
    ASAM Dataset: EV_AEMLearAU64X 002014
    ROD: EV_AEMLearAU64X_AU57.rod
    VCID: 6696BEFDE8EB7E97505-8032
    2 Faults Found:
    0554 - No Basic Setting
    B2010 00 [009] - -
    [FC_AssemblyCheck_NotDone]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 100456 km
    Date: 2019.07.16
    Time: 13:46:11
    1632 - invalid data record
    B2005 00 [009] - -
    [FC_Dataset_Invalid]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 242
    Mileage: 100456 km
    Date: 2019.07.16
    Time: 13:46:11
    End----------(Elapsed Time: 02:51, VBatt start/end: 12.2V/12.1V)-----------
    Feb 03 2016
    Cleveland
    Battery is stupid expensive. I had mine replaced at HS Tuning (NE Ohio) for $300. I wouldn’t doubt it is throwing codes especially if the dealer said it is on its last legs. $300 was cheap, but the electronics in these assume everything is in working order.
    Veteran Member Three Rings 3g_bishi's Avatar
    Mar 03 2016
    07 a6. 13 A7, 13A6, 08 A8LW12, 16A3, 15RS7
    DFW
    The 1 code under the “ECU” is what’s giving you these problems; not the battery, there is no “low voltage” codes anywhere. But the ecu is saying your map sensor is not good, make sure the connection is tight on it. I believe the map sensors are in the throttle body where the 2 hoses coming if the turbo are. But if it’s A CPO under warranty let them worry about it.
    Feb 14 2019
    Turlock, Ca
    If you get it figured out let me know. My local dealership can't even see all those same faults on my car, yet I get them every 400 miles or so an I can see them on VCDS. They replaced the map sensors yesterday and are driving it today to see if at least the map sensor fault goes away.
    2014 S6 - Glacier White - Driver Assistance, Cold Weather, Black Optics
    2006 Dodge 2500 MegaCab 4x4 - 5.9 Cummins - Auto - EFI Live | 2008 Toyota Yaris 4D - Daily
    Sold - 2015 Mustang 5.0 Premium - PP - FR PP Stg 2 - Roush AB | 2011 Mustang 5.0 Premium - Brembo - Catless H-Pipe w/ AED Tune - 12.51 @ 113.2mph | 1999 Dodge 2500 4x4 Cummins - some goodies - 12.3 @ 113.5mph
    Mar 30 2018
    long island
    may seem odd, but check your ABS wheel speed sensors. a broken or dirty one can light up similar lights.
    Mar 03 2016
    DFW
    guys!
    It is all pointing to the code in the ECU, no need to mess with the ABS sensor
    May 01 2017
    Leawood KS
    I've noticed the car is surging when coming to a stop, like it's applying throttle when it downshifts to 1. Pretty un-nerving so I'm going to call the dealership and see what they can do to work this in quicker or get me a loaner.
    Feb 14 2019
    Turlock, Ca
    Mine will do that too when all of the faults show up. I expect it has something to do with the sport differential fault, but I could be wrong. Only does it when the 4 or 5 faults are active.
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    My 2018 that I purchased new in February does this occasionally. Sometimes if I shut it off and start it again, the faults go away...... other times I need to clear them with Carista. I plan to do my first oil change at 5K miles vs. the 10K interval. When I bring it in for that I’m going to have them look into it.
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    May 01 2017
    Leawood KS
    It took the dealer a few days but they had to call in TAC to assist with diagnosis. Thank god for CPO...
    Crankcase breather valve (covered outside of CPO)
    MAP sensor bad (covered under CPO)
    Bank 2 O2 sensor bad (also covered under CPO)
    I asked my service advisor to give me a quote for replacing the other O2 sensors since they are already in there and the sensors are relatively cheap.
    My CPO expires in March, which means they'll probably fail shortly thereafter. ;-)
    How many other O2 sensors are there (I assume 3 others?) and what would be an ok price to replace them? I guess some of them are easier than others to get to...
    Mar 30 2018
    long island
    a stranger on a forum solved this in 3 hours, without looking at the car ( see post 3), but took the dealer days and a specialist? lol
    4 O2 sensors.
    1 primary and one secondary, per exhaust bank.
    changing them isn't difficult if you have basic mechanical knowledge.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    The more I read about various Audi dealership techs getting stumped on simpler stuff the more I am glad I can work on my own cars.
    Feb 14 2019
    Turlock, Ca
    I got my car today back as well (from map sensor errors and all the suspension/ACC faults) they fixed map sensors and adjusted the control arm levelers. Car was with them for 2 weeks, a few days of that was waiting on map sensors. Hopefully my errors don't come back, been at the dealership for 7 weeks of the 4.5 months I've owned the car lol...
    May 01 2017
    Leawood KS
    @OaborbaG that’s rough. I’m glad my ownership experience has been better than that. Some days I still think it’d be nice to have a Tacoma and not have to worry about 4K repairs though.
    Veteran Member Three Rings Vinng86's Avatar
    Jul 20 2018
    Toronto, ON
    Quote Originally Posted by Valpo A7 View Post
    It's a useful skill to have anyway, that way you have some idea if you're being fleeced on anything. It's really, really easy for body shops to over charge.
    2014 Audi A6 3.0T Technik(Prestige) S-line w/ Black Optics
    Feb 14 2019
    Turlock, Ca
    Quote Originally Posted by mperfct View Post
    Tell me about it, there's nothing like buyers remorse than the feeling after what I've experienced. Out of all the S6's I looked at, I think I chose the wrong one. This ones been in the shop more in the last 4.5 months of ownership than all my other cars combined.
    May 01 2017
    Leawood KS
    Well, just got off the phone with my SA and they found one of the turbo impellers was rubbing so I guess I’m getting both turbos replaced. Thank god for CPO!
    That makes me question whether I should try and trade the car once the CPO expires or if since all the common (and expensive) stuff has been replaced that it's good for awhile?
    Mar 30 2018
    long island
    if this is due to failing/clogged oil screen, they should be replacing the screen as well...and the PCV wheel in there. These items are really the only major downfall to the the 4.0t. no point in trading in if they are updated to the "fix" versions of parts.
    May 01 2017
    Leawood KS
    Got the car back a couple of weeks ago. Apparently the tech misdiagnosed the turbos as being faulty (wtf?) so the dealer didn't touch them after all. 2 weeks in the shop to replace breather valve, o2 sensor, MAF sensor, do the PODS recall and do an overpriced oil change. At least I had a loaner.
    Since the turbos weren't replaced and my warranty ends in March, I may start shopping again. We'll see. Mama bear needs a new car first, as well as my 14 year old needs his first car. Maybe I can get a package deal.
