Results 1 to 2 of 2
    Jul 12 2019
    Michigan
    Engine help - 03 Audi A4 Cabriolet - AMB
    I recently bought a 2003 Audi A4 Cabriolet knowing it had some overheating issues.
    It has recently had a new water pump, spark plugs, ignition coils, and oil change done (all by me except the water pump which was done by the previous owner).
    Codes I was getting:
    P0118
    P0300B
    P0302
    I haven't ran diagnostics against after doing the tune up but I took it to a shop to have it further inspected. Here is their digital inspection they sent me: Clickity Clack
    They called me saying they found engine oil in the coolant (which I already knew and which is why I brought it to them) but they also said that they found no coolant in the system and recommend replacing the engine assembly ($3300 if I have them do it).
    My question is does this seem accurate and do I need to replace entire engine or just the head? Appreciate any and all insight!
    Jun 09 2016
    u.k
    Usually the heat exchanger (oil cooler) fails long before the head gasket. I would check that first.
    Sent from my ANE-LX1 using Tapatalk
