Results 1 to 9 of 9
    Senior Member Three Rings Teamnct4's Avatar
    Aug 06 2010
    2015 S4
    Upgrading cooling on a untuned car
    I recently bought an AWE heat exchanger at a price I couldnít turn down. I donít plan on tuning my car for a while, so my question is, Is it worth it to put the heat exchanger on now, or should I wait until I go single pulley stage 2? Iím thinking I should just do it in one shot, bug wasnít sure if this would help me out now. Thanks in advance.
    2015 S4 Premium Plus, Mythos Black, Black/Magma Red Interior, Black optics package, Aluminum Mirror Caps, Carbon Atlas Inlays, Airlift 3P, Airlift performance front and rear shocks, AWE touring with 102MM Tips, E-Codes, 20X9 HRE FF01.
    Established Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    I'd install it when you change the pulley. It's much more convenient labor wise, and I don't think you will gain anything on stock with upgraded cooling.
    196.5/57 - e85 custom tune (EPL) - custom exhaust -
    ported blower - IABED TB - Brembo BBK - APR CPS - AEM Meth - USP intake- 034 sways and drivetrain inserts - cr-15 - 034 density control arms - Koni sport shocks - Eibach lowering springs - VMR v804 -PSS
    Sep 21 2018
    New Orleans
    Even stock the car is going to heat soak if youíre doing back to back runs. If you have time to pull the bumper off and want to do it, it would help the heat soaking. If you plan to do the crank pulley, it is possible to change it out without removing the front bumper and putting it into service position. Itís just a little more tedious because lack of space.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    2019 Acura RDX
    Napa Valley
    I installed my AWE coldfront when I just had Chipwerke. Definitely made a difference, like Morrisse said install it when you do another mod for convenience
    Sent from my SM-G965U using Audizine mobile app
    Established Member Two Rings m1k3d3's Avatar
    Jan 31 2017
    Philly
    Heat doesn't only kill performance, it increases wear. Any opportunity to reduce heat is a no brainer in my book.
    2015 S4 Sepang Blue | 6MT | Tech | B&O | Leather | Carbon Atlas | Black Optics | Sport Diff
    ECS Valved Catback Exhaust | ECS Kohlefaser Luft-Technik | Bilstein PSS10 | ECS 10 & 12.5 mm spacers | USP Stainless Steel Clutch Line | Suntek CXP 35% | 034 Drivetrain Mounts | Chipwerke Pro | RS4 Grille
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by m1k3d3 View Post
    I mean obviously adding cooling surely won't HURT, it's more of a question to whether the degree to which it would HELP justifies dealing with service position again. Different answer depending on who you are. Personally, I don't think it's worth it, especially if you don't live in any sort of hot area. I doubt your IATs are getting to 60į and if they are the OEM tune will tune your car down.
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    +1
    I'm stock and I generally see 60+ degrees celcius IAT in Southern Ontario, Canada at this time of year... bled the stock intercoolers and all... I think the stock heat exchanger is terrible, even at stock power levels...
    2015 Audi S5 Coupe
    Technik | Mythos Black on Black | Black Optics | Carbon Interior Trim | Carbon Supercharged Badges | Miltek Resonated Sport Cat Back Exhaust W/Black Cerakote GT100's | DSG | ADS | Sport Diff | B&O | Pinnacle 30% Tint | H&R OE Sport Springs | 10F/15R H&R Spacers | 20"x9" Black Matte Rotors - 275/30 Continental DWS | 19"x9" Titanium Rotors - 255/35 Blizzak LM-32
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I installed mine a few weeks before tuning my car, went straight to stage 2, and the car definitely benefited from it.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Senior Member Four Rings MSq5's Avatar
    Feb 14 2017
    Gulfport, MS
    There are good videos on service position. If youíve not yet done it, use the HX install to learn. Once youíve done it next time will be easy and take half the time.
    BTW, you do not have to go to full service position to install a HX, you only pull the front bumper cover/grill to get access to the crash bar and remove it to attach the HX to the back of it and reinstall. You donít have to install the long bolts and pull the the front out from the frame. Thatís only needed for the top pulley swap.
    2017 Q5 3.0T S-Line | Brilliant Black | EPL Stage 2 dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57mm s/c pulley - 3.247 total ratio | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX
