Here’s how I do it, picked up the concept from working with modern pex plumbing and how a little friction expands the supply hose to the valve. In the pics I already attached my PCV elbow to the PCV...that’s the easy part.
Take a little assembly lube and apply to the male end of the PCV outlet, and female end of the ventilation tube.
Grab a short 3/8” extension with a rachet or cordless impact, and apply a little bit of pressure to expand the opening. Just don’t go too fast if you use an impact, don’t want to heat up the plastic too much. Should start looking like this
Once you have about 1” expanded you should be able to start slipping it on until it’s completely seated. Takes a little force, but once cooled the plastic will form around the PCV outlet and seal effectively.
Nice thing about using a little oil or assembly lube is that it may need to be slightly clocked when installed, and the lubricant will allow for fine adjustments while not affecting the seal as it will go from a liquid to a gas within a few heat cycles. Hope that helps!
Haha it’s been an awesome car. Took awhile to find a USP with a manual, but was worth the wait. Since you’re in PDX and get stuck on something, shoot me a PM.
