Results 1 to 14 of 14
    Mar 23 2019
    New York
    S6 intake conversion to RS7 airbox and intake hose: or SRM shorts to RS7 box
    I am currently running the Burger Motorsports JB4 piggyback on my 2018 S6 and would like to give it a little more airflow. To keep a stock look, i was planning on the RS7 airbox and either the Rs7 intake hoses to the stock turbos, or the Silly Rabbit Motorsports short tubes to the RS7 box. The RS7 intake hose has a larger inside diameter than the S6 tube, but seems to bolt up correctly to the s6 turbos as does the SRM tube. Do any of the RS7 guys that have done the SRM conversion remember the inner diameter difference between the SRM tubes and the stock tubes you replaced. The SRM short tubes should connect up to the RS7 box and boot kit with no issues except for installation hassles and tweaks to the engine cover as posed elsewhere? Have any S6 guys done the RS7 intake tubes to RS7 box? Issues?
    Thanks in advance.
    Mar 20 2018
    Baltimore
    Google "s6 rs7 intake". Nice thread on audizine pops up
    Mar 23 2019
    New York
    Quote Originally Posted by TruS4 View Post
    yeah, had previously bookmarked that page and knew the RS7 box and pipes worked on the S6. was more interested in finding out if inside dimensions of the SRM tubes were significantly larger than the rs7 pipes to justify the modifications to the throttle body screw and the engine cover. i figure some RS7 guys or S6 guys that did the RS7 tubes, then went the SRM route may have measured the inner diameter difference of the tubes. IowaRS7?, widebodyfx?, brad65ford?, (OlyS6? Actually, SRM is not larger than MRC. They both connect directly onto the face of the turbos, (and have the same large inner diameter) as opposed to the stock RS7 tube that slide into the turbos. The MRC tubes are roughly $1000 USD),
    Mar 30 2018
    long island
    I have an rs7.
    Upgraded my pipes to srm.
    Srm pipes are significantly larger diameter than rs7. I think about 1/4 larger.
    Mar 23 2019
    New York
    did you keep the RS7 Box and accordians? long or short tubes? modify the engine cover?
    Mar 30 2018
    long island
    Quote Originally Posted by NewYorkS6 View Post
    I have long srm version. Removed the airbox and accordians.
    I did have to take a very small notch out of my engine cover, due to bad quality control at srm. Most people do not have to do this for long or short srm intake.
    May 21 2019
    2019 x5 5.0
    chicago IL
    Im waiting on parts, but my take is
    Rs7 box with rs7 accordion tubes, srm short intakes with srm chras
    Aug 05 2014
    NE Ohio
    I can measure my stock tubes if you want. I think the problem is it takes maybe an hour to pull a SRM tube once installed to measure :) Iím happy to measure the ID at the filter side,but Iím not sure itís the same Diameter as the turbo inlet side.
    EDIT:
    Stock RS7 filter side ID - 2.25"
    Stock RS7 Turbo Inlet ID - 1.75"
    SRM filter side ID - 2.375"
    SRM Turbo inlet ID - ???
    '14 RS7
    Mar 23 2019
    New York
    Quote Originally Posted by V10Jon View Post
    EDIT:
    thanks a lot. if the SRM tubes dont neck down like they say, probably that same 2.4 - 2.5" ID
    Sep 04 2011
    Central NJ
    EDIT:
    As one of my next mods, I'd like to install the RS7 air box with SRM short intakes. Do the RS7 accordion tubes fit on the short SRM tubes or do I need a different connector?
    2016 Audi S6 Prestige
    2015 Audi Q7 S line Prestige
    Mar 30 2018
    long island
    Quote Originally Posted by hmuller View Post
    they fit with a little persuasion. a tight fit, but they do fit.
    Mar 26 2010
    US
    2016 S6 Sport
    Sep 04 2011
    Central NJ
    Quote Originally Posted by daytona rs7 View Post
    Is that on the brushed aluminum or the black powder coated version? Looks like the power coat adds some texture which could make it harder for the accordion tubes to slide on.
    Mar 30 2018
    long island
    powder coated.
    see post 418
    https://www.audizine.com/forum/showt...ight=srm+short
