Ok I just bought a 2014 Audi Q7 S-line 64,000 km. Now when I did my research I read about the problems with direct injection. So have been thinking what I can do to reduce the carbon build up.
First thing I thought about was the catch can method. Then reading that this can cause even more problems if you live in cold weather conditions in the winter. So that being out of the question because I do live in cold winter climate. But then I can also just disconnect it in the winter months. that can be an option. Any-one having success with this method? And what catch can system works best.
Second thing is Meth Injection. Now this sounds like a good thing to run because it should wash the intake side before the cylinders and keep them somewhat clean. Another thing with the Meth Injection I was thinking you could probably mix some Sea Foam into it to help a little more.
So is anyone using the Meth Injection and what system did you buy? How is it working and what are you using for mixture? I have read that you can just use windshield washer fluid, not sure how true that would work. How about winter months?
Thanks
Bruce
