Results 1 to 17 of 17
    Jul 25 2018
    Boston
    AWE Intercooler installed!
    Finally got around to installing it, I was fortunate enough to get the Intercooler that AWE used for R&D I stumbled upon it on their website on Mothers Day. Got it for $499! What a steal! with that being said, you finally realize how poor the stock intercooler is on this car, albeit I am running a JB4 and mix in E85 at times. If anyone is on the fence on upgrading their stock unit, just do it! it transforms how this car drives!
    Jun 13 2017
    Winnipeg/Manitoba/Canada
    Quote Originally Posted by Cmoy135 View Post
    You had to remove the crash bar to fit it?
    Sent from my SM-G975W using Audizine mobile app
    Established Member Two Rings Nox05's Avatar
    Jan 21 2018
    Quote Originally Posted by danaeroS4 View Post
    Yeah, when I installed mine I had to remove the crash bar.
    Dec 22 2018
    California
    Is it just bolts or does it require cutting?
    Jan 21 2018
    Quote Originally Posted by Blesbok View Post
    Just bolts, no cutting required. Perfect opportunity to paint your crash bar too if need be.
    May 10 2019
    Bikes and 4x4s
    UT
    Please forgive my ignorance, but the main benefit here is just cooling, or are there power gains as well? In order to recognize any power gains do you need to remap at a minimum?
    19 Prestige with all the toys (diff, steering, etc.)
    Jul 25 2018
    Boston
    No exact power gains more or less maintains power as the car stays cooler.
    Aug 31 2011
    17 Audi Q7 Prem+
    Blue Bell, PA
    I got an APR unit in and still on map4... George said I should stay at Map4 after looking at my logs.
    What else did you do to stay at map5?
    Established Member Two Rings thermobryan's Avatar
    May 30 2018
    SoCAL
    Quote Originally Posted by Longtallsally View Post
    Basically with the garbage stock intercooler when you're running it hard or your ambient temp is high you're robbing the car of cool air into the intake. Car has to work harder, etc etc. My main emphasis in engineering school was thermodynamics, so don't let me get going down a rabbit hole.
    Here is a decent explanation:
    http://stratifiedauto.com/blog/the-e...rged-vehicles/
    Jul 25 2018
    Boston
    Quote Originally Posted by jonpark View Post
    My logs on all maps looked good with George, also trying out some custom settings on Map 6. I Daily my car on map 3. If I want to open it up I switch to map 5.
    Jun 13 2018
    Colorado
    Do you have any pictures of everything all back together? I'm debating on whether to paint my crashbar or not...I have a glacier white and a RS style grill, so don't know if it would blend in better if I just left the crashbar silver to match the IC or if I should paint the crashbar black. Curious what others are doing.
    Established Member Three Rings BrockDM's Avatar
    Jan 21 2018
    Frankfort, IL
    Quote Originally Posted by ukan16 View Post
    Definitely paint the crash bar.
    Established Member Three Rings Yabi's Avatar
    Mar 30 2018
    2011 Toyota Prius 5
    Cary, NC
    Quote Originally Posted by BrockDM View Post
    Your car looks so good! I really love the way it's come together. Well done!
    Jun 13 2018
    Colorado
    That looks amazing! Any advice on the paint/use anything special? I'm slightly worried about peppering it with rockchips and having to repaint every so often, but that just might be the consequence of going with the more open grill.
    Jan 21 2018
    Frankfort, IL
    I made the mistake the first time using plasti-dip, do not do that.
    I ended up sanding off the remaining plasti-dip and applied 3-4 coats of rustolium primer and probably 4 coats of matte black rustolium. So far it's holding up well but unfortunately rock chips are unavoidable. I went with the "more the merrier" approach and coated it heavily. Don't go too thick though since it still is partially visible behind the grill. Do many thin coats.
    You can check out the process at post #84 here -> https://www.audizine.com/forum/showt...hoto-Log/page3
    Jan 21 2018
    Frankfort, IL
    Quote Originally Posted by Yabi View Post
    Thanks Yabi! It never stops bringing my enjoyment. I'm excited for what the future holds
    Veteran Member Four Rings CreoSTi's Avatar
    Feb 22 2004
    2016 Acura RDX
    West L.A.
    Another option is to use automotive vinyl wrap. I did that with my S6 when I installed the RS6 grille and I never had any issues with chipping;
    -Mike- : 2001 S4 → 2011 S4 → 2014 S6 → 2018 S4
    Draper & Kramer Mortgage Corp.
    @creoucla
