Results 1 to 15 of 15
    Established Member Two Rings mike0819's Avatar
    Oct 29 2016
    nz
    Help, lot white exhaust smoke while stop at light
    My 3.0 tfsi supercharged engine, 90 k on clock, recently noticed every time I stop at light, there are bit noticeable smoke coming from my rear end, white smoke, the car run fine I do not notice any problems, can anyone let me know do I need check something or could be sign something going to be wrong soon?
    Sent from my EVR-AL00 using Audizine mobile app
    Oct 29 2016
    nz
    Quote Originally Posted by mike0819 View Post
    My oil do get low around every 5000 k, and weather has been quit cold, but I noticed I got lot more exhaust white smoke than other cars
    Jul 31 2016
    PA
    Is it all the time or just when the car isn't warmed up and then it goes away?
    Sent from my Pixel 3 using Tapatalk
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I would put the PCV valve on a short list of probable suspects.
    Active Member One Ring LtDangle's Avatar
    Apr 04 2018
    Oakland, CA
    Cat failure could be one potential issue.
    2013 Monsoon Gray S4
    6 MT - Sport Diff - AWE Touring Exhaust w/OEM Downpipes - 034 Stage II SP (Burble Beta) - 034 Drivetrain Mount Insert Pkg and Subframe Mount Inserts
    Senior Member Two Rings BigKeshy's Avatar
    Jun 01 2017
    Washington, DC
    I have a feeling this is water vapor in your exhaust gasses condensing it leaves the tailpipe. Does the amount of smoke go down as your car comes up to operating temperature?
    When you say more smoke than other cars, so the other cars have comparable engines? Our engine moves a lot more air than a 4-cylinder commuter car so it would make sense that you'd see more exhaust gas than your average econo-box.
    2013 B8.5 S4 MT
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2011 Acura MDX Advance
    Philly 'burbs
    How's your coolant level? Could be leaking from one or both of the S/C intercooler cores and being burned off.
    Mar 20 2015
    McKinney,TX
    I was thinking supercharger
    Does it only happen only after you’ve just started driving?
    Established Member Two Rings dimonblr's Avatar
    Oct 02 2018
    Boston
    White usually means coolant. Possibly a gasket?
    2014 Audi S4
    Oct 29 2016
    nz
    Quote Originally Posted by Dr GP View Post
    Is it expensive to fix? I noticed my engine oil do get low quit fast
    Jun 08 2005
    Lexus RX 350
    SE, PA
    No but you need to remove the Supercharger to get at it. If you plan on keeping the car for a while,it is prudent to also replace the t stat, water pump and coolant tube while the SC is off . Otherwise, you will need to remove the Sc again when they fail, Labor to remove the Sc is the biggest cost for the project.I had all those things done at an indy shop for $1500
    Established Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Quote Originally Posted by jsh139 View Post
    +1
    If you have no coolant loss, it's probably normal.
    If you do, it's probably PCV.
    196.5/57 - e85 custom tune (EPL) - custom exhaust -
    ported blower - IABED TB - Brembo BBK - APR CPS - AEM Meth - USP intake- 034 sways and drivetrain inserts - cr-15 - 034 density control arms - Koni sport shocks - Eibach lowering springs - VMR v804 -PSS
    Oct 29 2016
    nz
    Quote Originally Posted by Morritse View Post
    +1
    I do notice coolant do get low a bit, I just fill it up, and add some engine oil, the problem seems go away now. By the way what happens if I leave the pcv unfixed, will it just burn out my coolant faster?
    May 08 2018
    Berkeley, CA
    Yea, will continue to get worse
    Established Member Two Rings KLX's Avatar
    Jan 28 2018
    Shaw AFB SC
    What he said...T-stat W-pump, and coolant tubes, as well as supporting gaskets, while you have the SC off replace the gaskets under there also.
    2015 S4 B8.5
    APR Stage 2 Dual Pulley
    ECS Front 2-Piece Tru-Float Wave Brake Rotors
    Akebono pads
    APR Coolant Performance System
    AWE Touring Edition
    H&R Sport Springs /KONI Sport Yellow Shocks
    ECS Kohlefaser Luft-Technik Intake System
    CR-15 Bar..
    @businessklazz on Instagram
