Results 1 to 16 of 16
Thread: Bits and Tools
    Active Member Two Rings dithmartfitness's Avatar
    Apr 28 2019
    2000 A4 Avant 5speed Quattro
    moline Il
    Bits and Tools
    Anyone have any suggestions for end bit sets or tools that aren't egregiously expensive, yet extremely practical for working on these vehicles?
    Sent from my SM-G960U1 using Tapatalk
    Veteran Member Three Rings 2004a4b630QT's Avatar
    Mar 30 2015
    '04 A4 3.0 QTip
    harbor freight for all of that. I use Milwaukee for cordless ratchet and high torque impact, and it usually a good idea to buy better quality torque wrenches, but I've been getting by with Harbor freight there too.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    Dolphin Grey Audi A4 3.0 Q 6MT
    Dirty Jerz
    For seldom use items, I go with Harbor Freight. One thing that I have that has come in very handy are GearWrench bit sockets that are ~6" long for torx and hex.
    Sent from my Pixel 3 XL
    Retrieve your SKC for use with VCDS
    Setup Ross-Tech VCP Drivers
    3.0 JHM Tuned, JHM LWFW & Clutch, JHM Solid Short Shifter, Zingo Airbox Mod, quattro, Vogtland Jr. Suspension, Single Xenon E-Codes, Apikol Snub, 034 Motor & Trans Mounts
    May 20 2010
    Harbor Freight has a security bit set that's pretty inexpensive for what you get (it's in a red case).
    When I first starting working cars and getting tools, it was all Craftsman (and standard) but now it's usually a trip to HF unless it's something special.
    2016 A6 TDI Prestige - S-Line, Black Optics, Driver Assistance, HUD, LED Headlights, Cold Weather, Warm Weather
    2003 allroad 6MT - STUKLR Stage 1, Hotchkis sway bars, RS4 engine mounts, Apikol rear diff mounts
    Apr 17 2016
    kc
    Buying that shit up before the new tariff kick in!
    Apr 28 2019
    moline Il
    Quote Originally Posted by hightime80 View Post
    Why what then?
    Apr 17 2016
    kc
    Haha.
    Mar 22 2019
    Clarksville, TN
    Follow the Harbor Freight rule. Buy it there first. If you use it often enough that it breaks, you should spend the cash on a quality one.
    Most hand tools from HF are pretty solid though. Many carry lifetime guarantee too.
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    Like has been said, unless you are $$, you just get a cheap starter set and replace stuff as it breaks.
    Lowes use to sell individual sockets. Now only autozone has those (I think they are the only ones left).
    Lowes sets are great quality for the $ IMO
    I still have some old box wrenches that were made in India.
    I suggest you get a good used SK or better 16mm socket for the pinch bolt.
    Also some bolt/nut grabbers and triple squares and hex allen head sockets off of amazon.
    later on offset wrenches and swivel head wrenchess are nice.
    allen wrenches as well.
    3/8 and 1/2 breaker bars.
    "But I bought this stuff. Everything in here with my own money."
    "Yeah, yeah. This is not what I meant.
    I mean this is so much shit packed in here."
    "Yeah, well. Every tool in here has a purpose.
    Everything has a job to do.
    They are all used when necessary."
    "It's just.. I can't afford to buy all this stuff."
    "Well, I guess, even a bonehead like you, could understand...
    that a man acquires it over the period of 50 years."
    "Yeah, but..."
    "All right, look, here.
    These three items right here, you can have this.
    WD-40, vice grips and some duck tape.
    Any man who is worth his salt, can do half of the house chores with just those three things."
    -Gran Torino
    Read more: https://www.springfieldspringfield.c...ie=gran-torino
    2002 Audi a4 B6 Q 3.0 6MT
    May 13 2019
    Lakewood, CO
    Quote Originally Posted by shurur9 View Post
    Home Depot still sells individual also. I just bought some last week.
    Also...why is Harbor Freight so highly recommended. What is so good about their products? Just wondering.
    Aug 12 2009
    Dirty Jerz
    They're cheap. If you're only going to use it one or two times, why spend 3-4x as much (or more) on a high quality, name brand tool?
    Jun 12 2014
    Tampa FL
    Quote Originally Posted by imnuts View Post
    I would also add that you might not be able to afford a good set up front, but can replace broken sockets (for example) a few at a time as needed. a cheap set up front gets you most of the tools you'll need to syart off.
    I built my set ad-hoc; so I never really got set up front. I would have been better off with a set and the case to carry it in. My stuff is in buckets.
    May 20 2010
    On top of being less expensive, their return policy is good--bring back a broken socket or something, and get a replacement. And popping over there quickly to get a new tool has been great.
    To date, I think I have broken 3 sockets from them (one being used an impact) and one ratchet (to be fair, I was using the ratchet as a hammer in a dire situation). They've held up to surprising level of punishment.
    My triple square kit (XZN) and spline sets I've gotten off Amazon.
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Metro Detroit Michigan
    I like their sockets, Allens, torx and other tools alike. Torque wrench’s are a negative there. Too inaccurate and break too easy. They are fine for basic torque but if your doing a head or something that needs good values then get a good torque wrench. Their tools are also great to modify. Cut up a set of custom box end wrenches, sure for 9 dollars and a cut off wheel and have fun. Triple bit set go amazon and if you do the head you have to buy the special spline bit. Got to Home Depot or Lowe’s and get pvc fittings and a cap to fit your ic pipes and make a boost leak tester. Worth every penny of about $5-10 to put one together.
    What ever makes sense go with the opposite and you got it
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    03 A4 Quattro, 1.8T, 02X six speed conversion/ GJW (4.11 final drive). RS4 RSB, H&R FSB.
    Veteran Member Four Rings NaiveTurtle's Avatar
    May 20 2013
    Vancouver, WA
    I use the Neiko sets off Amazon for all the specialty bits like Torx, hex, and triple Square. They're decent quality and cost $15-$20 per set where each set has like 15 sizes.
    For normal sockets, ratchets, wrenches, and other hand tools I use Gearwrench. They're kinda the best none truck tools I think.
    Everything I buy came off Amazon Prime.
    2008 GMG World Challenge 6MT []S5 Ibis White Matte Metallic Purple/Black Alcantara
    [Mods - GIAC 91 Tune | GMG WC Sport Downpipes | GMG WC Sport Cat-Back | GMG WC Front & Rear Sway Bars | AP Racing 6-Piston Front BBK | 20x9.5 HRE P40's | Accuair B8 Sport Kit]
    2004 Ocean Blue Metallic A4 Avant
    Instagram: @NaiveTurtle
