Results 1 to 7 of 7
    Established Member Two Rings mrdouble99's Avatar
    Mar 31 2018
    Montreal
    Wierd steering feel
    Hi all
    It's hard to explain, but it happen 2 times since last month, while turning from a stop the car feel like it's slipping on ice for a fraction of a second, but i'm on nice summer asphalt.
    I have a 2015 S6
    Feb 22 2011
    Las Vegas/Nevada
    I kind of feel something like that every once in a while when Iím just cruising around 40-60 mph also...
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    Sacramento Area
    Quote Originally Posted by mrdouble99 View Post
    Hi all
    I have a 2015 S6
    Sounds like 'quattro walk', which is the jitter you get from low speed turning. You should be able to recreate the issue by idling or under light throttle and making tight turns. It's an expected result of the torsen AWD.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt | LX7U | APR STG2 | JHMotorsports DP + CATBACK | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | EVO2 | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired | JHM Oil screen relocation | Prototype Parts
    b7 a4 2.0t | Stage 2+ | DTM Body | All the bolt-on mods | [sold]
    Mar 31 2018
    Montreal
    Quote Originally Posted by ericw. View Post
    yeah, i had this feeling before and got used to it, but last time it was more like i was on ice for a split second while turning at very low speed but not a tight turn.
    At first i tought i had a loose wheel lol
    Jun 09 2017
    Signature
    GTA
    Understeer?
    Current Line-Up:
    2015 Audi S6 - RS7 Turbos, "Mike's" Catted Downpipes, SRM Intake, APR ECU & TCU, AMS Cooling System, H&R Module, Eurocode sways and Alu Kreuz, 20 x 9 et38 & 21lbs each, 15% Ceramic Tint all windows except windshield, Xpel Ultimate - Entire Car
    2012 VW Golf R - APR in-house build Stage 4
    2002 Audi TT 225 Quattro Roadster - Big Turbo
    1995 Camaro Z28 6 Speed - Just Bolt-Ons
    2008 Kawaski ZX-10R - Kawi Green
    Mar 31 2018
    Montreal
    Quote Originally Posted by 15 Phantom S6 View Post
    Understeer?
    yes
    Mar 11 2018
    2014 A7 TDI, 2009 BMW 750i Sport
    Chicago, IL
    Sounds similar to the feeling I'd get in my 2014 A7. Check out my suspension post. I just completely redid my suspension/steering and posted some more details. I was getting lazy turn-in and a feeling like the wheel slipped or the front dove down a little when turning.
    What I found is that the C7 suspension is designed to float and return to center by keeping tension on the control arms and guide link. You can really see this once the tie rod ball joint is off of the bearing housing. If one bushing is worn, it'll create less tension and make the steering fell sloppy.
    I'd check the guide link's hydro-bearing for leaks and just check the control arm bushings for excessive wear or deformation. The steering tie rods are tough because mine didn't show any visual symptoms or feel that bad, but replacing them made a difference. Also, there are TONS of updated parts replacing earlier versions. From memory, all of the bushings and hydro-bearing have been updated. The easiest to do is replace the inner and outer tie rods, regrease the steering gear and replace the boots, but it requires an alignment afterwards. Doing the lower control arm, ball joint and guide link weren't that bad either. The upper control arms require the fork assembly being pulled, though.
