Results 1 to 16 of 16
    Active Member Two Rings VezSQ5's Avatar
    May 27 2019
    St-Jean-Sur-Richelieu
    Creaking noise from NEW lower rear control arms. Need help
    so I had bad bushings in there, so we replaced all 4 lower control arms. Ever since then, the car makes some creaking noise when hitting bumps. I can also replicate the creaking noise when jacking up and down the SQ5. It comes from the bolt/bushing of the lower rear control arms, where it bolts to subframe. conrol ars are bilstein brand new. If I loosen the bolt a bit, it stops... but if I torque it back to spec at 70NM + 180, its creaks again. VERY annoying. I tired greasing.. no help. I also tried going way above torque spec, and it wont help. Only thing that helps is loosing the nuts a little bit. Not enough to be loose, but enough to stop squeaking/creaking.
    I didnt replace the bolts and nuts.. maybe I should ?
    I also torqued everything while the suspension was loaded to ride height. I tried about everything, but still that annoying creaking sound.
    any advice ? Am I just unlucky enough to have hit bad brand new control arms bushings?
    any help is welcome
    thanks
    Apr 15 2019
    Chicago
    I’m having the same problem With my 84, I’m waiting for my mechanic to look at it, but I found this post on Audi world.com, try it out and let me know if it works for you.
    I had the same creaking noises coming from the drivers side mostly after I had lowered my A6. I went from the base springs to eibach lowering springs with stock shocks. 1.2" drop. Since it wasn't a big drop, I kept the stock shocks on. Shortly after about 50miles or so, I noticed the creaking noises when going over speed bumps or drive way inclines. After some trouble shooting and my mechanic suggested replacing the upper control arms due to worn bushings, the problem was still present. What ended up fixing the noise come to find out is that the lower control arm bolts needed to be loose when the car is lowered resting on the full body weight then re-tightened after new springs are installed. I did two alignments prior with no fix until an experienced VW/Audi tech mentioned the fix to my mechanic. Since the lower control arm bolts were torqued to the higher stock spring positions/travel, when lowering, it added more stress to the bushings/bolts.Been great ever since. Hope this helps...
    Apr 15 2019
    Chicago
    I meant to say my A4, not 84.
    May 27 2019
    Well.. my car was not lowered and bolts were tighten at normal driving height (suspension compressed)
    Thanks for the input though
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by VezSQ5 View Post
    I know greasing did not solve the problem. Maybe try a little grease around the bolt shaft, itself, just above the threads? The bolt shaft and the hole may be rubbing slightly somehow under compression. Strange.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    May 06 2007
    Michigan
    I recently replaced my rear upper control arms for the same creaking symptoms. I replaced with OEM Meyle upper arms and that solved my problem, luckily didn't have to change out the lower arms.
    If you're 100% positive the creaking is coming from the lower arms then it could be a bad manuf. batch. Contact bilstein see what your exchange options are. Could also try installing an OEM arm, or arms from a different aftermarket brand.
    2013 Daytona Grey RS5
    Prev
    2014 Ice Silver SQ5
    2012 Monsoon Grey S4
    2010 Brilliant Black A5
    2003 Denim Blue A4
    May 27 2019
    bilstein has 1 year warranty. Ill check with them. But what about the botl and nuts? should they be replaced ? Or can I just re-use the old ones? I re-used the old ones and im starting to worry about them
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Sounds like you answered your own question.
    May 27 2019
    Hehe wich part? The bolts and nuts?
    Apr 26 2014
    DFW
    Well yeah. . .If you're worried about them, replace them. Couldn't hurt.
    May 27 2019
    I ordered new bolts and nuts. As I read about them, they are strech bolts. Means that they stretch when torqued. So they are only 1 use and needs to replaced. When they stretch, the outter diamater is reduced a little, so if you re-use them and torque again, and again, they keep streching and thinning making that creaking noise .. .that is my theory. :)
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Well, I noticed you said you didn't replace bolts. That torque spec is for new bolts, cuts that extra 180 is to stretch bolt. So I would try torqueing it down little less.
    Sent from my VS995 using Audizine mobile app
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    I’d be willing to bet it’s due to the bolt being stretched already, but you’re applying the torque that is spec’d for a new bolt...which is going to result in more load on the bushing.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Apr 26 2014
    DFW
    I believe they call these "TTY", meaning torque-to-yield, and they should not be reused.
    My understanding is that they are safety-related and designed to give out in a crash situation.
    Have you seen these new cars come apart? At least it's to protect the occupants.
    May 27 2019
    Thanks gents. It has been a great learning experience. I have ordered 2 bolts and nuts at the stealer for 40$ :o what a rape in the ***
    Apr 26 2014
    DFW
    If they had to order them, you might as well have ordered them yourself.
    There are some OEM-parts distributors online that probably charge what the dealers pay them for.
