Results 1 to 6 of 6
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    E85 Additive Use
    Question for those using the E85 tune. Do you use or have thought about an additive to add in cleaners and lubricants that are normally in the top tier gasoline?
    I started thinking about all the detergents and additives they put in the recommended top tier fuels and checked around with my local E85 suppliers and confirmed they add nothing to the E85. I know the alcholo technically burns (cleaner) so valve deposits should be less, in theory (since it's DI), but there is something to be said about the 'lubrication' of petrol based gasoline that is missing in the alcohol.
    I found this but just wondering the thoughts of the community.
    https://lucasoil.com/products/fuel-t...th-stabilizers
    My main concern is that I don't use the E85 just on occasion, it's my standard fill and what I use all the time so there's never gasoline going through to lube things up.
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
    Veteran Member Three Rings Jeff_Jeske's Avatar
    Nov 24 2018
    Madison WI
    I know people that have been running E85 straight for years without issue. I usually switch to 93 for the winter months or storage. Its more because E85 is harder to light off in winter weather rather than cleaners and lubricants though. Keep in mind the mixture is 85% Ethanol and 15% gasoline anyway.
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Thanks for the response.
    Yeah, I switch to full gasoline for the winter storage as well and regularly start it up and warm it to full operating with a simulated drive (don't idle it, give it a little RPM just like a normal drive to warm it up).
    True, the 15% gasoline would provide some lubrication but all the additives aren't there (or diluted to only 15% as well), and that's really the definition of top tier is additive packages that protect the injection system, fuel, and engine. Just want to see what everyone else running the straight E85 are doing and thinking, hopefully get some more input. :)
    Veteran Member Three Rings Huey52's Avatar
    Dec 22 2010
    New England
    I'm not, even when I also had an E85 capable allroad. But then rare to find E85 in my area.
    On the flip side, I put an ounce of StaBil 360 in my TT tank every fill-up to help overcome the water absorption of ethanol, especially in Winter (my TT is not a daily driver). Innate high octane of ethanol is a plus but everything else related seems negative to me (lower chemical energy per unit and thereby lower MPG per volume being the most understated; also advanced deterioration of some types of seals). I want our US farmers to make a good living but subsidies .... ok, I better quit there.
    2016 TTS Sepang blue/rotor gray Tech B&O
    Prior: 2013 allroad; 2011 A5
    Jul 12 2018
    UK
    I can't speak for the US but anywhere else in the world I've looked into there are mandatory stabilizers and anti-corrosion inhibitors to be added at a given treat rate for ethanol content, so I would expect them have some kind of additive! Surprised to hear maybe that is not the case in the US.
    I've done some experimentation myself recently to ascertain what the tolerances are. My only issue right now is getting hold of Anhydrous ethanol as it's very controlled in the UK; I can get it in Germany but struggling with logistics right now. I am hoping to get some soon.
    Anyway, here's some findings on my crude garage-lab over the past few days:
    Additive - Lucas Ethanol additive at 1.7ml/ litre.
    Ethanol - 96.6% Hydrous Ethanol (3.4% water), denatured with 2% denaturants added.
    Methanol - 99.95% Methanol
    Gasoline - 99RON with 5% Ethanol, 5% MTBE, 35% Aromatics.
    Commercial E85 - Renegate "E85 Pro".
    • Renegate E85 PRO - no phase separate even at 5% water added and cooled to -18C
    • E62 (60% EtOH 40% Gas) - no phase separate even at 5% water added and cooled to -18C
    • "E62" equiv. (30% EtOH 20% MeOH 50% Gas) - 2% water caused phase separation cooling from 0C to -18C, 5% separated at room temp
    • "E62" equiv. (30% EtOH 20% MeOH 50% Gas) plus additive - 2% water fine at -18C but 5% water is cloudy at 0C and separated cooling to -18C
    My conclusion is that the additive is effective at combatting phase separation, but probably not really neccesary. 2% is over 1l of water in a tank of fuel! And only when using Methanol does it even become a problem at 5% or less. Which is like 3 quarts of water in US measurements, one hell of a lot of contamination.
    My next step is to leave samples of these blends exposed to our nasty humid air for about 6 weeks and then re-test, I don't think it will vary too much but we will see.
    I mixed 10% water into a sample and made E62 from it (no MeOH) and with a bit of additive it remained stable at 20C. At 10C there was a thin film of separation and it became cloudy on agitation. Also worth noting that ANY water about about 0.1% in Gas samples caused separation, no the idea of condensation forming in the tank is really far-fetched, the only way water is getting in is from the humid air and I read one study where it took approx 200 days of warm humid temps and would then need a very cold winter's night to phase separate. Technically possible but not for anyone leaving their tank of E85 for months on end.
    I've also got some copper strip corrosion tests set up but so far even the 100% Methanol control test hasn't made even a hint of tarnish, see how they look in a month.
    The lubrication point is one I'm not too sure on, the only issue on injection I can see is valve wash and this could be valid. However I'm inclined not to add anything for that as I've seen a few failures probably caused by heavier lubricants causing injector gunk. A proper additive could be beneficial, it's hard to say. I figure with most lower-load conditions using DI and only more open-throttle situations making heavy use of the port valves it is even less of a concern.
    I'm more comfortable running E85 longer term including my own home-brew blends from Hydrous Ethanol. I'd prefer to get hold of Anhydrous simply for more head-room. I'll use the additive, it's a low treat-rate and proven to be effective in at least one area it claims. The studies I've seen on DCI-11 corrosion inhibitor suggests that will be massively effective at long-term protection of components also, for that alone it's worth while.
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Quote Originally Posted by Huey52 View Post
    Yeah, the lower MPG doesn't concern me, not my DD and power is the goal. Although having to carry extra to the track is a bit of a pain, so there is that. But yeah, it is NOT some magic fuel to 'save the planet' lol The hippies got it wrong as always, but at least in this case we got a darn good performance fuel out of it. And yeah, I should stop there......lol
    As for the seals, I saw some tests that actually showed the real danger of corrosion and deterioration was due to the smaller percentage mixes. For example corrosion was worse in an E10 sample than in an E50 one. Plus, since seals have to withstand ethanol as all gas contains at least 10% they should resist any issues. It's not like they can manufacture seals to ONLY handle 10% mix, it either resists it or not.
    Quote Originally Posted by Ross_T_Boss View Post
    Lubrication concerns revolve around the fuel pump mostly. As for valves, well I do perform a good Italian tune up regularly so it's not a major concern but still. You have some great info there and some good tests, definitely keep us all informed.
