I just wanted to help out anyone else that is trying to connect an aftermarket subwoofer and amp to their Bang and Olufsen system. I connected the Posi-Taps to the LOC for a cleaner install since I didn’t want to do any cutting or splicing of the OEM wiring. I then opened up the grill to the subwoofer on the driver's side back seat. In there you can find the cable that connects to the subwoofer. It is a pain to get off but there is a little red clip on the bottom of the harness that you have to pull out to unplug it from the subwoofer. Once you get that harness out, you can then use the Posi-Taps on the LOC to connect to the speaker cables. After that, you can then go into the truck area and remove (2) plastic dowels to gain access to the truck side panel area. I fished my cables down a little precut hole by the subwoofer and ran them down to the opening of the truck. I then fished those cables under the liner into the spare tire location. That is where I installed my amp. My amp was the perfect size to put on the left side of the battery and still had clearance to fit the spare tire. I didn’t strap it down or anything because the spare tire kept it from moving. There is a ground wire by the right side of the spare tire that is perfect for connecting your AMP since you may not want to drill holes down there. I also connected the power cable to the huge red power cable connected to the side of the battery. It is underneath the one that is labeled DSG4 125 amp.
Parts:
(1) SCOSCHE LOC2SL Car Stereo 2-Channel Audio Adjustable Amplifier with Add-On Adapter and Remote Control Knob, Black
(7) Lockitt POSI-TAP 6 pack wire connectors 20-22 awg
(1) Rockford Fosgate Single In-Line AGU Fuse Holder for 4 AWG or 8 AWG Wire
(1) Rockford Fosgate 60 Amp AGU Fuse, 4-Pack
(2) Harmony Audio HA-WR48 Car Stereo Power or Ground 4 to 8 Gauge Wire Reducer - Nickel Plated
(1) Rockford Fosgate Prime R500X1D
(1) TruConnex TC4KIT-4B by Metra
(1) Belva BBIC5
(1) Rockford Fosgate P2-1X12 Punch P2 12" Enclosure
Wiring:
LOC
Yellow = Power on AMP 12v
White = Left +
White/Black = Left -
Grey = Right +
Grey/Black = Right -
Blue/White = Remote wire on AMP
RCA
Red = Right Channel
White = Left Channel
Audi Speaker Wiring
Brown/Green = +
Red/Green = -
Brown/Purple = +
Blue/Yellow = -
Combined
White = Left + > Brown/Green = +
White/Black = Left - > Red/Green = -
Grey = Right + > Brown/Purple = +
Grey/Black = Right - > Blue/Yellow = -
Blue/White to Blue Remote Wire
Yellow to Red Power Wire
20200408_170342.jpeg20200408_170818.jpeg20200408_170851.jpeg20200408_171529.jpeg20200408_172117.jpeg20200408_185107.jpeg
Sent from my SM-N975U using
Audizine mobile app
