Sorry it’s been so long. Fighting myself to light it up! Should have mentioned I made the mistake of unplugging the battery so it won’t read any codes on an average scan. But with the vagcom scan, there was different codes that I didn’t get on the scan before I unplugged the battery. I’ve been told that there’s two on the vagcom that could keep the car from turning on. One is P1861 throttle position sensor so I took off the intake hose and there’s movement in the flap but it does seem stiff. Should I look more into doing a cleaning? I believe it’s a motor operated one though so I’m not sure if I should just replace it. There’s also a p2138 accelerator position sensor (g79/g185), would that be something in the motor??
The other code I’m trying to look into is p1602 power supply terminal 30 voltage too low. I’m trying to check the relay but I had a hard time finding it. Is it one in the ECU box or is it inside the car under the wheel?
