Results 1 to 28 of 28
    Veteran Member Four Rings rhfosu's Avatar
    Jan 01 2015
    Alexandria, VA
    Was TPMS not standard?
    My 08 had it, but it was not listed on the window sticker as an option. My 07 does not appear to have it. At least, I don't see the antenna when I look underneath.
    "I don't understand Audi enthusiasts. They buy a car that looks like a bar of soap, then they spend money modifying it so it looks slightly less like a bar of soap."
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    It’s not standard unless it is by region
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Wikipedia says the law that mfgs had to include TPMS standard kicked in during 2008
    Mar 12 2016
    The land of Kiwis
    My current 08 B7 is without the previous 08 also was without.
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    I have a 2005.5 Avant which most of them basically came loaded. No TPMS on it.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Feb 15 2016
    Cambridge,Ontario
    Even my 2014 technik has no tpms, unless it is indirect measure but j have never seen a light come on
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Apr 22 2019
    My 07 did not come with it. Makes changing wheels a lot easier!
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    id be surprised if it didnt have it
    Feb 15 2016
    Cambridge,Ontario
    now i just want to let the air out of one tire and go for a drive
    1976 Yamaha XS 360
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Canada never set any standardized TPMS laws, USA did in 2007-2008.
    If you don't have actual sensors it should tell you through indirect wheel speed that a tire is flat, likely you'd feel it before the dummy light.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Jun 27 2011
    Yea but any law passed IN 2007 or 2008 likely would have a warmup period for manufacturers to alter their assembly lines.
    Either way my 2008 has it. I believe it was part of the Technology package? Availability and what options it came with will 100% vary by country/region.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jan 01 2015
    Alexandria, VA
    My 2008 only had s-line and ti packages, but it did have tpms. My 2007 avant has s-line, ti, and nav, folding mirrors, homelink (tech package?) but no TPMS...
    Jun 27 2011
    Weird. I don’t actually remember if my 2006 or 2004 A4s had TPMS. I don’t think my b6 did (not even sure if it was an option on the b6 tbh).
    I should check my window sticker today and see if there is an entry for TPMS.
    -CP
    2017 Q7 3.0t
    Jan 01 2015
    Alexandria, VA
    I'm mostly pissed bc I assumed it had it and I ordered sensors for some new wheels.
    Mar 27 2019
    All it does is make a lot of noise in the winter time
    Jun 27 2011
    I coded mine out for my winter wheels without TPMS. I still haven’t turned it back on though.
    I love TPMS, of course I’ve never had issues with it so I don’t mind it.
    -CP
    2017 Q7 3.0t
    Jan 01 2015
    Alexandria, VA
    I like it too. I wish I had it on my wagon.
    Nov 03 2011
    All Over!
    I’ve got TPMS.
    1986 Type 85 Audi 90 quattro
    Senior Member Two Rings Spetznaaz's Avatar
    May 26 2019
    U.K, South Wales
    How do i check if i have it?
    I took my spare wheel out to clean it the other day and noticed a noise as if something was inside the tyre rolling about. Read online it could either be the tyre pressure sensor or rubber balls that accumulate over time (which would be odd for a spare).
    Apr 22 2019
    Quote Originally Posted by Spetznaaz View Post
    Let some pressure out of a tire and see if you get a tpms warning.
    Jan 01 2015
    Alexandria, VA
    Look under your rear bumper for the antenna.
    Jun 27 2011
    Or go through the DIS menu and see if the option to store tire pressures is listed.
    -CP
    2017 Q7 3.0t
    May 26 2019
    U.K, South Wales
    Thanks guys, i will have a check :)
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Or just look at the stems, if you have OEM wheels. Metal valve stems indicate TPMS on the b7. Newer cars (b8.5) use an indirect measure through ABS module (ie wheel speed) so they have rubber valve stems but still have TPMS
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by PNW Avant View Post
    that's likely what I have then , im gonna let some air out and go for a drive. I wonder what pressure I would trigger at ? its testing time !!!!!
    1976 Yamaha XS 360
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    I know mine triggered at about 3psi low but what I'm not sure about is whether the system triggers based on a differential pressure between tires or all four going a bit low (or both). I also wonder if I increased the pressure by 3 or so psi in one over the set point if that would trigger the warning. Too many unknowns. I do know that when I had a blow out the system went crazy (but don't try that).
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Mine triggered once at like 25 psi. Going to turn my TPMS off when I swap wheels. Have a pressure gauge in the car. Not hard to check each time I hit the gas station, etc...
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Brillo View Post
    well i know for a fact my B8 is indirect if it actually has it ( my b7 doesnt have it at all ) i am sure i would have to go very low before the abs sensor picked up a different angular velocity on the wheel.
    1976 Yamaha XS 360
