Yes, loud noise from the back of the head. You can also look at the cam phaser position with VCDS.
My car sounded pretty loud after my ride to work everyday. Sounded decent at start up, different after 40 minutes of driving.
Mine had the worn out cam phaser in my pic. The tensioner has plently of material left but it had a hairline crack.
You can visual inspect the tensioner and cam phaser just by taking the back cover off. You’ll need to replace the gasket and cover oil seals if you take it off. You’ll need a new HPFP and vacuum pump O ring too.
