I have had an 034 rear sway bar and 034 rear endlinks installed on my 08 RS4 for the past year or so. In this time, the M10 bolt that screws into the sleeve going through the swaybar has backed out of the right endlink on a number of occasions causing damage to the upper portion of the endlink. I have had it repaired by a professional shop and also repaired myself (each time using locktite to fasten the bolt when installing and the last time using fresh replacement components from 034), but each time with the same results. The bolt backs out and eventually unscrews completely leading to endlink failure and a very grumbly suspension. FYI, the sway bar is set to the stiffest setting and the endlinks are adjusted to their shortest position. Has anyone else had this issue?
I don't have any clue why this keeps happening - you would think the components would be compatible. I don't autocross or do any track days, so I'm not overstressing the suspension. I'm at my wits end now - any ideas on how to rectify the issue before I throw more money at it would be much appreciated. Thanks.
