Hey guys,
sorry for the long post...
I've had an intermittent coldstart issue that began a few winters ago and has progressively gotten worse this past winter. I've read a bunch of threads where people experienced similar symptoms as me and swapping heads for the most part seemed to fix the problem but that hasn't been the case for me. I've narrowed down the possible causes but feel i may be missing something, and i'm sure this may be the case for others too? I have access to Vagcom, so any recommended test are greatly appreciated.
I've tried to list any relevant history/information i can think of that may relate to the issue since it started and repairs i did to try and narrow down the issue:
2003 A4 1.8t Tiptronic
Intermittent Hard start issue started 3 winters ago ( winter 2016/2017 ) after i went stage 2 Unitronic with TT injectors, new plugs and stock coilpacks. Car started consuming oil 5 months before performance chip. Car would struggle to start periodically and would skip cold start warm up and idle at 800rpms, , but never threw CEL and condition went away with the warmer weather. As weather got warmer, car would perform cold start warm up procedure normally even if it was warm overnight? Replaced Camshaft and crankshaft position sensors, both O2 sensors and coolant temp sensors.
Installed ECS fuel gauge and fuel filter spring/summer 2017 to narrow down possible fuel pressure issue. Not an issue. Installed 2.0 coilpack conversion kit Dec 2017, no change..but car ran better. Same Coldstart issue continues throughout winter 2017/2018.
Spring 2018 car started smoking on decel and during long hill climbs ( full smokeshow ) so i bought an ecs catchcan. Can catches lots of oil...Summer 2018 Installed new stock fit turbo as the OE one had 250,000kms and a lot of shaft play. Smoking issue was lessened, but still present after turbo swap, but car felt better. Oil consumption about same, but catch can now stays dry/ minimal vapor. Planned on replacing valve seals. Replaced fuel injector harnesses at same time as well replaced all evap/breather hoses with 034 silicone kit and billet PCV and new crankcase vent valve. 034 block breather hose didn't fit soo great at the billet end, but no oil buildup is noticeable around the connection.
This winter hardstart issue returned. Swapped in a good Bw K04 + new CTS HFC over christmas and stayed with stage 2 software for 3 weeks. Switched to stage 2+ software, periodic hardstart continued ( so i guess not a software issue ).
Found a leak around the intake manifold gasket for cylinder 3, so i swapped in a fully cleaned and powdercoated Intake Manilfold with new gaskets and billet fuel injector seats. No more leaks but problem persists after a few days. Also cleaned a spare Throttle body i had painted to match my intake manifold, performed adaptation with Vagcom, problem still persists.
February i started getting misfires with flashing CEL/codes for cylinder 3 when the car would sit overnight. Problem continued to get worse and would misfire with CEL after work and started to happen on cylinder 4 as well. Cylinder 3 appeared to be wet, couldn't smell coolant though. Stuck a wooden dowel down the plug hole and all i could scrape off was oil. Ran pressure test, all cylinders within acceptable specs with 2+3 being a few PSI lower than 1 +4 but still good. Systematically swapped Coilpacks, plugs, and fuel injectors back and forth, problem did not follow movement of components.
Car was loosing coolant so i thought maybe time for an AWM head swap with new valve seals and kill 2 birds at once. Found out coolant loss was from a warped coolant sensor clip on the rear coolant flange. Replaced clip. no more coolant loss. Same time i replaced my shitty coilpack connectors.
Car started misfiring while driving, so i swapped in some NGK copper core plugs as 3+4 were fouling.
Rebuilt a good, straight AWM head while dealing with nonsense above and installed with all new gaskets/bolts/hardware. All Problems go away for a week, car now surges at coldstart again in morning during warm up cycle. No CEL light on, but soft code for cylinder 3 misfire persists. Oil Consumption issue is gone, Oil catch can still dry/ minimal vapor.
Checked old AMB cylinder head, no visible evidence of cracking or warping. Head gasket looked ok too.
short list on Repairs i've done personally since the coldstart issue started that i thought may be related (new to old)
New spark Plugs (May 2019 )
AWM head swap with all new gaskets/seals/hardware/tensioner pads ( apr 2019 )
New Coil pack connectors ( feb 2019 )
Intake manifold swap with new billet injector cups ( dec 2018 )
New injector connectors ( Aug 2018 )
NEW oem MAF ( aug 2018)
034 silicon breather/PCV hoses, billet PCV ( Aug 2018 )
2.0 coilpack conversion ( dec 2017 )
ECS fuel pressure gauge ( aug 2017 )
Replaced Fuel filter ( aug 2017 )
Camshaft and crankshaft poistion sensors, both 02 sensors, coolant temp sensors ( winter 2016/2017 )
thats everything i can think of at the moment
Today:
Watching my boost gauge at cold start ( overnight ), it immediately goes down to -5hg for about halfway through the cold start warm up process, then climbs up to -11, and then settles out to -15/16 once the idle goes back down to normal. Maybe Vac leak at coldstart? Seems a tad low at regular idle even for a tiptronic. Car will hit -20 at cruise with foot off gas.
As it stands right now i'm planning on going back to square one and start checking for some vac leaks. I have a wobbly/poor fitting billet end on the crank case breather hose from 034 that is getting some attention today and I've also ordered a bunch of new vacuum valves from US plastics, so those are on the to do list.
I'm wondering if anyone may have some insight to whether or not a vacuum leak could cause a cylinder specific misfire? Multiple cylinders i could believe but just cylinder 3? Bad PCV? Maybe The Silicon line to the Intake manifold near cylinder 3 from the PCV is sucking in too much air at start up? All i know is once it warms up all seems fine.
Could this be a 30397 driver issue with the ECU that k0mpresd has repaired for other members?
Any ideas or thoughts would be greatly appreciated!
