Via Aliexpress of course..
Might still need to buy one of those adapter cables via Ebay. Tempted to be the Guinea pig here.
Thoughts on why this might or might not work? Seems like a cheaper alternative to ordering them from the EU.
Chris
B6 A4: 2.0 stroker, IE cams, JHM 01E/Stg4 RS4 clutch/FW, SEM manifold, EFR7163, Motoza, ID1050x, Walbro 450, Garrett FMIC, 034 mounts/RSB, Koni coils, Hotchkis FSB, 18z, VFIZ, etc.
B8.5 S4: EPL DP 57/187 (E40), 75mm TB, Ported SC, Meth, Autotech HPFP, Killer Chiller, Borla Exhaust, Merc HX, JHM SS/3R/Race pipes, Eurocode Sway, 034 springs, CR15
429 whp/431 wtq 93 oct (stock TB)
Insta: QuattroNC
2013 Monsoon Grey B8.5 S4 6MT | ECS CF Wing | ECS CF Front Lip | Canyon Run-15 Strut Brace | ECS Front Strut Tower Bar | Injen CAI | ECS Center X-Pipe | 034 Motorsports Rear Sway Bar | ECS Tuning Lower Control Arm Brace | Ziza Interior Light Kit | Luft-Technik Intake Air Scoop | ECS CF Antenna Cover | ECS CF Rear Diffuser | IE Stage 1 |Do Tinted Windows Count?
Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
SOLD 2015 Daytona Gray S4
Chris
Insta: QuattroNC
