Results 1 to 13 of 13
Thread: Walbro question
    Veteran Member Three Rings Shahek's Avatar
    Feb 14 2018
    Sunland/CA/US
    Walbro question
    Hey guys I need to replace my Walbro 450 but everywhere I look there are two diff part numbers. F90000267 and F90000274. Can’t find enough info to figure out the difference. Any help is much appreciated.
    Thanks
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Walbro question
    Part number F90000274
    This is the updated version with a higher pressure relief valve.
    Credit to SeerLah
    https://www.audizine.com/forum/showt...one-Walbro-450
    Feb 14 2018
    Sunland/CA/US
    Walbro question
    Thanks for the speedy answer man I just placed an order for one! really appreciate it!
    Aug 24 2014
    Newport Beach, CA
    The high pressure version does make a difference. One thing I recommend you do is hardwire the fuel pump to the battery and cut out the stock fuel pump wiring.
    2024 M3 Comp xDrive
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Yes, run power straight from the battery to a relay. Use the factory fuel pump positive wire to trigger the relay. Super easy.
    Aug 08 2014
    New Zealand
    I have hopefully done this but can you confirm the brown and green cable?
    Feb 23 2010
    Emmaus Pa
    Green wire under the back seat.
    Feb 14 2018
    Sunland/CA/US
    Thanks guys!
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by christianb5s4 View Post
    Out of curiosity, why is this preferred over OEM wiring?
    Registered User Four Rings
    Sep 01 2013
    Sweden
    DC current create high Amperage.
    That creats heat which melts non properly sized wiring or best case limits the output.
    Its a must do. Take it seriously.
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by Mocke View Post
    This. I’ve seen melted tank lids because the pump draws too many amps for the factory wiring to handle.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by Tumbler510 View Post
    http://21h1yp1945ct18r0ws184hb2-wpen...re-112-PSI.pdf
    First of all, look at this curve from the pump manufacturer Ti Automotive. This is meant to represent a typical pump (also read as: some pumps will draw higher current [amps], some pumps will draw less current).
    Current is what we are concerned with here. Higher current means the wiring will heat up hotter than if the wiring was subject to lower current. Wiring is rated for a specific maximum current level over a certain length of wire. The standard wiring is sized for the current that the stock pump draws at boost pressures of 10 psi from those ity bity K03s.
    What causes the pump to draw more current? (more heat)
    They way our fuel pressure regulators work is that they increase the fuel system pressure 1 psi with every 1 psi of boost pressure. So, if the base fuel pressure is 58 psi (it is with the stock FPR) and you run 20 psi of boost, the pump must make 58 + 20 = 78 psi of fuel pressure + any additional pressure due to the restrictive stock fuel lines. So if you are running 20 psi boost and stock fuel lines which might have a pressure drop of 5 psi (making this number up, the stock fuel lines could be more restrictive than this!!), the pump must spply at least 58 + 20 + 5 = 83 psi of fuel pressure. 83 psi of fuel pressure should be about 18.5 amps of current according to the F90000274 plot.
    Can the stock b5 wiring handle 18.5 amps? The diagram below says you should have a 14 gauge wire for 18.5 amp draw assuming the wiring is about 10 ft' long (which I believe it is).
    If the wiring is not sized correctly, it could get too hot and start melting... Not something you want near the fuel tank...
    Let's also keep in mind that all of our stock wiring is 20 years old, which could cause additional issues if over-stressed.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by CELison View Post
    My stock wiring had definite signs of high heat when all of it was bypassed. I have 10 gauge wiring and zero stock wiring now, with the exception of tapping into the OEM signal wire to trigger the pump.
    2024 M3 Comp xDrive
