Results 1 to 2 of 2
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    JHM S4 lightweight rear brake rotors
    $325 shipped. Originally $625 new. Used JHM B6 S4 stock size lightweight rear brake rotors. Cleaned up and measured thickness at 21.7-21.8 mm. New is 22 mm so these are almost new thickness. I switched to the JHM rear BBK a while ago.
    Sent from my SM-N960U1 using Tapatalk
    Apr 03 2010
    Northern Virginia
    Bump.
    Responded to messages about these. They are stock sized replacements so they are even lighter than the 330 mm JHM rear BBK and they bolt right up without any additional parts.
