Page 2 of 63 FirstFirst 12341252 ... LastLast
Results 41 to 80 of 2493
  1. #41
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Johann@Carbnlab View Post
    Thanks Mops I love them.
    I'm glad!! They certainly do look awesome. We need more pics. 👊🏼
  2. #42
    Registered User Four Rings Johann@Carbnlab's Avatar
    Oct 12 2007
    Montreal
    We'll have to book a photoshoot for the our new splitter and the carbon fiber skirts, They will compliment the wheels very well. I don't know why but there is something about CF and bronze mmmmm!
  3. #43
    Veteran Member Four Rings HP18's Avatar
    Jul 18 2004
    Orange County - CA
    Aristo Forged Sport 5 (Duo Block) Wheels in Matte Bronze Finish - 20x10.5 ET 25
    5mm spacers in front
    7mm spacers in rear
    Hankook 285/30/20
    More pics here
  4. #44
    May 21 2010
    Hello B9 5 peeps!
    HRE just released the FF10 and FF11. I am waiting to hear back on the fitments, but it should be the usual 19x9, 19x9.5, 20x9 and 20x10.5. The finish offerings will be the usual suspects - Liquid Silver and Tarmac.
    Hey Mops, Love the bottom one for S5 Sportback in 20. Also like BBS C1 in 20" . How wide a wheel and tire can I use? Offset etc.
  5. #45
    Sep 28 2010
    NW NC / DE
    B9 A/S/RS5 Wheel Gallery
    Quote Originally Posted by Wilbur View Post
    Hello sir!
    Indeed. I think the FF11 looks fantastic!! For the FF11, you'd run the 20x9 ET25 or 20x10.5 ET35. With the CI-R, you'd run the 20x9. I have a clip of the 20x9 CI-R.. one sec.
    https://www.instagram.com/p/B17ZTRKn...d=dnuj90rjeg2s
  6. #46
    May 21 2010
    ^ Thanks. Can I run 275 or 285s?
  7. #47
    Sep 28 2010
    NW NC / DE
    You 100% cannot run the 285 with the 20x10.5. You'll almost certainly rub the arches. And with the 9", I suppose you could, but the 275/30 will look quite meaty. Even the 265 look meaty on a 9", so no, the 285 would not be used no matter the wheel specs.
    Here is our S5 on 20x9 ET25 on 265/30 -
  8. #48
    May 21 2010
    Thanks. Think Ill go FF11, 20x9 et 25 with 265..not 275. Thanks for your help.
  9. #49
    Sep 28 2010
    NW NC / DE
    Glad to help Billy!
  10. #50
    Veteran Member Three Rings Gryphon001's Avatar
    Apr 14 2009
    2018 S5 Sportback, Daytona Gray - 2008 Audi A3, S-Line, Ti, 6MT
    Mississauga, Ontario, Canada
    Quote Originally Posted by Jimminez@Nemesis View Post
    They are real. They are Q7 wheels. Part number 4M0071491LT7.
    Sent from my iPad using Tapatalk Pro
    They are very much real... and that is correct.
  11. #51
    Junior Member Two Rings SportbackMatt's Avatar
    Feb 22 2019
    NH
    Anyone running nice / meaty 19s on an RS5 SB? Post a pic!
    Last edited by SportbackMatt; 09-23-2019 at 04:16 PM. Reason: Found a better thread to ask the questions 😄
  12. #52
    Established Member Two Rings cthan3o3's Avatar
    Mar 11 2011
    Colorado
    Glad to help Billy!
    Hey Mops, i’ve been checking out some Aodhan LS009 in 20x10.5 et35, would that fit my S5 sportback? Their only other option is 20x9 et30
  13. #53
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by cthan3o3 View Post
    As long as the spoke profile clears your front calipers. The maker/supplier should have that info. The actual specs are fine as long as you use 275/30. 👍🏼
  14. #54
    Aug 16 2018
    Oakville, Canada
    Looking for some recommendations on offset and width to get for a set of Niche Misanos. Will be using my stock Conti 255-35-19 tires. This is for a S5 SB.
  15. #55
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by richuwo11 View Post
    I would say 9" ET22 is optimal. Stock is 8.5 ET32 on 255. And 10-12mm spacers work great with those.
  16. #56
    Aug 16 2018
    Oakville, Canada
    Thanks for the response. Couldn’t I just get wheels with a greater offset instead of using spacers? I’ve never had wheels with spacers or rings before.
    For width, the only options I have are 8.5, 9.5 and 10.
  17. #57
    Sep 28 2010
    NW NC / DE
    Certainly!
    What are the 8.5 and 9.5 offset options?
  18. #58
    Aug 16 2018
    Oakville, Canada
    Certainly!
    For 8.5 - Offsets are +25, +34, +42
    For 9.5 - Offsets are +35, +38
  19. #59
    Sep 28 2010
    NW NC / DE
    I would go 8.5 +25. That will position your wheels 7mm outboard from your stock wheels. And you can bump to 265/35 when you need tires for a really nice look.
    MOPS on the Move!
  20. #60
    Aug 16 2018
    Oakville, Canada
    MOPS on the Move!
    Thanks Mops! Will post pics when I get them mounted.
  21. #61
    Sep 28 2010
    NW NC / DE
    For sure, and please do! Another will benefit down the road.
  22. #62
    Aug 16 2018
    Oakville, Canada
    Finally got them mounted. Went with matte black and swapped over my stock Contis. Happy with the look, but would definitely look better with an extra inch.
  23. #63
    Junior Member Two Rings jpas4's Avatar
    Nov 02 2014
    Issaquah, WA
    Hello sir!
    Do you have a photo of the FF11 in 20x10.5 ET35? I'm interested in its concavity specifically; looking to get a set in liquid black if they are concave.
  24. #64
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by jpas4 View Post
    I'll request a photo right now and report back. I only have a shot of the 20x9.
  25. #65
    Sep 28 2010
    NW NC / DE
    Here you go 👍🏼
  26. #66
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Quote Originally Posted by SportbackMatt View Post
    Just noticed this request, I run them for winter. 19x9.5" ET35 plus 15/20mm spacers with 275/35R19 in this set up. Will have new ones on soon in 19x9.5" ET29 plus spacers with same tires.
  27. #67
    May 21 2010
    Just ran into a Pal that did 20x10" Misanos with 285/25/20......said there was no rubbing...perfect fit? I really want to go 285 if possible.
  28. #68
    May 21 2010
    Here you go 👍🏼
    What tire would you put on that?
  29. #69
    Sep 28 2010
    NW NC / DE
    S5 or RS5? Should have been 285/30/20.
    I would personally want to do 285, but those specs will not allow for it. The offset is too low. 275/30 would be the tire size for these.
  30. #70
    May 21 2010
    S5. Is there an available offset that would work with F11 and 285? Would prefer HRE over NICHE I think.
  31. #71
    Sep 28 2010
    NW NC / DE
    The 20x10.5 ET35 with 285 would work with spacers. Maybe a 3mm, could take 5mm. It's not been done AFAIK.
    Do you mind to ask your buddy what make/model 285 he runs and his wheel offset? He's nailed a very slim margin with that fitment - would be good to know what he's running.
  32. #72
    May 21 2010
    Wonder why it hasn't been done? Spacers on FF11 to clear suspension I assume ? I just sent an email to find out Misano spec he did on S5.
  33. #73
    May 21 2010
    Wheel is 20x10.5 et 25. Tire was 285/25/20. I agree 285/30/20 makes more sense as its slightly bigger.
  34. #74
    Apr 14 2009
    Hi guys, quick fitment question... the current wheel specs for my S5 is 19”x8.5” with a 32 offset. Do you think a 19”x9.5” wheel with a 32 offset will work with a stock size 255 tire? If I am understanding this right the increased width of the wheel should bring the offset out about 1/2 inch (12.5mm) out on either side.
    I wanted to run the the tires that came on the car into the ground before upgrading to a 20” setup and my stock wheels are now my dedicated winters. Was looking at the Advanti Hybris 19x9.5 +35 /66.6mm bore. Just not sure that stretch won’t be too much.
  35. #75
    Jan 03 2017
    Picked up our new s5 sportback today. I have my tsw nurburgrings from my s6 to run as my second season set.... (Currently I have my snows on the oems). I was going to have them powder coated black, but the gunmetal doesn't look too bad, right?? The wheel is just mocked up, but it's 20" just like the oem. The perspective makes it look larger! Open to opinions.
    2016 S6
  36. #76
    Veteran Member Four Rings kjeeper10's Avatar
    Dec 07 2017
    2007 Jeep Wrangler JK
    Quote Originally Posted by Gryphon001 View Post
    I had Advanti’s last season.. decent wheel for the price.
    2015 Daytona S5 - Madico Ceramic Tint 35/20 - 6 Speed - Mods - Sprintbooster V3 - APR Stage II - Dual Pulley - CPS Cooler - Eurocode ST Shifter - EuroImpulse weighted knob - USP SS Clutch Line - 034 SD Engine Mounts - 034 Trans Mount Insert - 034 rear SB - CR-15 - ORT Coilovers - SPC Front CA’s - IE Non Res Downpipes - AWE touring w/ 102 tips - CTS intake - ECS Streat Shield - Deval CF Splwitter/Rear Valance - Signature SV901 Forged 19x10.5 wheels - 275/35 Mich PS4S Tires.
  37. #77
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by jasejase View Post
    They're going to fantastic I think. 20x9 ET35? That's 6mm inboard from your stock wheels FYI. But yea, I like black wheels, but I'm feeling the GM finish.
  38. #78
    Apr 14 2009
    If you can make the offset work, I think do look great in gunmetal. It also looks like you have the black optics on your car, so if gunmetal gets boring you can always refinish them black and it will still look good.
  39. #79
    Jan 03 2017
    I agree. Thanks. And you're right, it has the BO. I can't See the offset being an issue. From what I can tell, oem is 34 and the nurbs are 35.
    Since I have the winters on the oem's, and they're likely more durable, I'll probably end up putting the summers on the nurburgrings. Same way I did it on the s6.
    2016 S6
  40. #80
    Jan 03 2017
    I think / hope so!
    Correct, they're 35. From what I found, the oem OEM BO 20'S are 34. I could be wrong.
    2016 S6
